Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
How to replace door gasket on LG WM0642HW Washer?
I have a hole in the door gasket after only 15 months. How do I replace the door gasket? Is this a do-it-yourself type job?
  • rjk118 Oct 26, 2008
    Thanks for the response. I was afraid I'd have to take the front of the machine off.
    I removed the first ring and can see the second ring. Not a lot of room, but it looks I can get to it.
  • Anonymous Apr 19, 2009
    Ok, so this is the deal... I have an LG WM2277HW front load washer. It was giving me a "TE" error so i did tons of googling and figured out that the thermistor was the problem. I am not the most mechanically inclined -- but i figured i'd give it a try.
    I got the whole thing apart on my own. Found the thermistor's wiring harness had broken -- so long story short i cut the wires, used a **** connector, and VIOLA!!! WORKS!!!
    Now, i saw all kinds of people having problems getting the spring that holds the door gasket OFF. I did not. Was actually not difficult at all. Getting it back ON!!!!! TOTALLY DIFFERENT STORY.
    So this is the deal.... how the heck do you get the gasket back on and then get the wire around the drum and the spring mechanism in place?
    This is what I did.. and i'm sure there has to be a better way.... I had the door open as I pushed the gasket onto the drum from inside the cavity... got it all the way around the drum and then opened the cabinet cover enough to get my hands in there... and tried to get the metal wire all the way around it in the groove, but how do you get it to stay in the groove???? i had one person hold the one side as i man-handled the spring side in. I got it MOSTLY there, but i think the bottom of the gasket popped out because its leaking a bit... and i can see at the bottom of the gasket where its not all the way seated...
    But before I go doing this ALL over again, i need to know a couple things...
    1 - is there an easier way of doing this?
    2 - i read about this spring clamp tool... what do i get? one that squeezes the eye hooks from both sides together??? or one that separates the spring far enough to latch it?
    3 - how do i ensure that the wire stays in the groove?
    I need some simple help!!!
    Thanks,
    Dennis
I also had a door gasket tear that caused water to spit out all over the floor so I had to replace it. It's a fairly simple job in theory, you can even find LG repair manuals online. The front panel comes off easy and removing the spring and wire clamps from the gasket is fairly simple. Getting the gasket back on is a different story. Seating the gasket is a bit tricky but I found that some lubrication helped greatly. Don't use oil based lube though because it could soften the gasket. I opted for a water based lube in the form of KY jelly (***insert crude joke here***) The drum side wire clamp was a bit of a challenge. My model had a hook on one end of the wire so that it came apart when removed. I think this made it much easier. Some models don't have the hook so you would need a tool that could stretch the spring. Something like a reverse pliers. Even with the hook, it was tricky. I found that jamming something around the gasket to hold the wire in place was helpful. I ended up using some vice-grips and needle nose pliers and all the strength I had to get it hooked. In fact, to sum up, the secret is to get enough force to stretch the spring. Once you figure out how to do that it's easy.
Posted on Oct 04, 2009
    President:
  • LG Master
  • 2,651 Answers
If you can call lg and have them ship you the part its not all that bad of a job, a little patience but not that terrible.. theres a spring under the rim around the front of the unit holding the boot to the unit, you can "roll" this one off.then once removed youll gain acees to the rear spring holding the rear of the boot to the outer basket.(honestly cant remember if its a simple spring or a screw that holds the inner spring in place), but it will be apperant when you remove it. reverse teh steps and your good to go. its a liitle like changing a bike tire as a kid, youll need to work it around the rim, and itll pop off a few times, but as you see how it works youl get it( might take 45 min-1hour) remember patience.
Posted on Oct 26, 2008
I used a set of bicycle tyre levers to ease the wire retainer on. The trick appeared to be to start at the opposite side to the spring and work towards it with a tyre lever either side. Popped on easily although it took an hour and a lot of cursing to get to that point
Posted on May 07, 2011
Water does not drain
Is the drain line clear? Also sounds like time on water inlet is running to long. Front loaders don't use that much water.
Mar 21, 2014 | LG WM0642HW 4.0 cu. ft. Front Load Washer...
The door gasket on my LG Tromm WM2377CS washer always has water trapped in it. The three tiny drain holes have been getting more and more clogged with "gunk". How to get the drain holes cleaned...
I use nylon cable (zip) ties to clean them. (Not sharp, so no danger of poking holes in the gasket) You may want to run a washer cleaner through the machine occasionally, such as Affresh or Washer Magic, or one made by Tide or Clorox.
Jul 23, 2011 | LG WM-2277HW Front Load Washer
I have mold all around the rubber gasket on the fromt of my LG washer. How can I eliminate this?
Problem:
The seal design on the washer traps water causing mildew to grow.
Solution:
If the door gasket has a small hole at the six o'clock position--it is clogged with soap scum. Use compressed air to blow this hole clear.
This allows water to drain back into the tub
If there's no hole--this is an older model LG which did not have this upgrade
Wiping the door gasket with a rag after the LAST cycle of the day helps prevent debris from accumulating. Some consumers add (1) teaspoon of bleach to a spray bottle with water--and spray the older type gaskets after the final laundry load finished--to keep the gasket clean.
Service manual and more HERE
Feb 10, 2011 | LG WM-1832C Front Load Washer
Our lg washer model wm0642hw tub clean cycle stops
software problem. regarding smell, after wash keep the door opened for ventilation, use fabric conditioner etc. also check whether any rodent has gone inside and messed up the place
Mar 18, 2010 | LG WM0642H Front Load
"UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Aug 07, 2009 | LG WM1814CW Front Load Washer
When I start the washer, water seems to seep in through the back and not through the sprayers? After the cycle is finished, clothes are still dirty, as if they never washed due to lack of water entering,...
I have a (2009 )WM0642HW.The new ones don't have the Forced Water Recirculation Nozzle that's in the top of the door seal. LG quietly (discontinued) that feature. If you do see a WM0642HW with a spray nozzle in top of the door seal in a showroom somewhere, it was a WM0642HW manufactured ( assembled ) a long time ago.Currently produced WM0642HW will not have the Water Recirculation feature installed. There may still be some older version "new" WM0642HW units out there somewhere? But most of them are display models or unavailable ,and with a shorter motor warranty. 7 years instead of current 10 years on new versions of the WM0642HW.But getting back to your question, the washer fills by water entering the cylinder through the back top left side of drum as it flows from the dispenser compartment via a hose.The opening is right behind the cylinder baffels location. It has no fill nozzle at the front gasket edge like some other brands have. My washer did not clean well at all with full loads. Only after i turned the water level switch under the top lid "clockwise" a half turn ,does it now fill up to the bottom of the door rubber seal.My clothing now tumbles in a pool of water instead of a WICK WATER RUB WASH that it was doing previously. It's a 100 times better with the few gallons of extra water inside, BELIEVE ME. What i say is from experience with this exact model.Turn up the water level so it can tumble in some water. TRUST ME ON THIS ONE! You'll have nothing but grief until you've had enough and have the desire to turn it up alittle.Just have it set to fill to the bottom of the door gasket.Everything will be saturated at the start of the wash and not towards the end of the wash segment.
May 12, 2009 | LG WM0642H Front Load
Water leaking from my front load LG washer
My LG WM2277HB also leaks after 4yrs of use. I found a hole in the front door gasket at the 3 o'clock position. I also have LE errors constantly.
Mar 09, 2009 | LG WM-2277HW Front Load Washer
LG WM0642HW washer gives error during spin cycle and stops.
I have this problem and you can find the solution on this same web page by searching. It is likely the Hall Sensor that needs to be replaced (see proflevy posting on Jul 16, 2008). According to the postings, it is from soap build up on the sensor and replacing it costs $18 for the part and is easy (many responses on this). I am waiting for the part and will try to fix mine soon.
Mar 06, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
4,791 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
