Question about Car Audio & Video
How to install a JVC Bluetooth head unit KD-BTP52
I am tying to figure which wires go where the most simple thing and i can not figure it out 3 wires A Blue with a White strip wire, Black Wire, Brown wire. I have established that black is ground but as for the other two wire i can not place them please some one help me, also i am reading the instructions and it does not state where it goes so please help me
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
Tech Jenkins
  • 359 Answers
SOURCE: where do you connect the blue wire
Next time don't lose the instructions.....
Black is your answer...
If just simply hooking the blue and black together with the black from the switch/power supply does not work you need to replace the wire going to the fan with a 12/3 wire(white,black,red,ground) along with a switch, what you have now is a 12/2(white,black,ground)
Here is the following way it should be hooked up using 12/3 romex to the fan from wall switch.
White,Black, ground power supply
Make sure 12/3 is fed to the fan location.
From the power you Y off the black to the red with a piece of red wire to the switch.
Then from the switch is red wire.
Then at the fan red connects to blue, black connects to black, white to white, and ground to ground.
Posted on Nov 15, 2008
MPetro302
  • 298 Answers
SOURCE: is jvc kd-g335 blue tooth compatable
If it is a "Ready for BlueTooth" model you will need this adapter JVC KS-BTA20
Posted on Jun 04, 2009
XSdB
  • 80 Answers
SOURCE: I want to wire the kd-s640 to my boat. I need to
Usually it's....
black = ground
red = switched battery power
yellow = constant batery power (for clock...etc)
orange = illumination
blue = amplifier turn on or accessory (electric antenna, amps etc)
green/white/purple/grey are speaker wires.
Posted on Jun 12, 2009
erpaalai
  • 999 Answers
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Posted on Jun 17, 2009
What is the brown wire on JVC KD sr60 wire harness
That's the "mute" wire. If you ground that wire, it will shut off the audio output for the head unit. It's typically used in combination with add-on Bluetooth units or hands-free phone kits. In a typical installation, you wouldn't connect it to anything, and you'll want to make sure it's insulated.
Aug 04, 2015 | JVC Car Audio & Video
Jvc kd-bt11 will not turn on
Its is definitely the extra wire, i had this problem and took it to a shop the power wire has to be ran from the battery with a fuse in between them, you can find a live wire in the dash and splice and put a fuse between them, if you dont feel confident, i would take it to a local shop i did the same thing and they installed for 40$ but i had all of the hardware and the radio was already in the dash just needed power
Feb 20, 2013 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
Why does my jvc kd-r526 reset to factory default everytime i turn it off
Try connecting the yellow wire to a constant power source. That is, a source that still has power when the key is turned off. The yellow wire controls the memory of the radio.
Jun 02, 2011 | JVC KD-R800 Car CD/ MP3 Player
Hey guys, I've just installed a CD changer in my car - having some difficulties getting it to work. After some Googling I came across this forum so I figured I'd see if any of you guys know where I'm...
there should be a small connector on the changer itself for the power ground and remote wire for power to the changer unit. the cord coming from the unit to the changer doesn't supply this power and this is why it wont eject and also your head unit wont recognize it until it gets powered up and able to communicate with the head unit and then it will show up as a selectable source when switching between sources of music. check the back of the changer for a small connector containing 3 or 4 pins and you should have a connector with the corresponding wires coming from it to plug into this spot after connecting the wires properly. if you bought it on ebay it is possible you didn't get this piece which is critical when connecting this changer.
Apr 03, 2011 | JVC CH-X1500 12-Disc CD Changer
Bluetooth turn on
Hello imback2009,
The JVC KD-G140 does not have a Bluetooth option, either built-in or with an adapter. And as far as I can tell, it doesn't have a "mute" or "phone" wire which would allow installation of a generic bluetooth adapter, such as the Parrot. If you want to connect your cellphone, I'd recommend you look at an upgrade here.
Hope this helps.
Sep 11, 2009 | JVC KD-G140 Car CD Player
Unmarked wires
your jvc is pretty standard on hook ups.red wire is on a keyed power wire,black is chasis ground, blue is remote wire to amp.yellow also keyed power wire.speaker wires there will be 8,usually whit violet so on. white solid for exzamle is + white with black stripe is - you can figure out front and rear with an old speaker and buy fading front to rear on your head unit youll know front and rears.same for left and right.did you look on the unit usually the have the wiring diagram on the unit itself.mine all do
Jun 21, 2009 | JVC KD-S580 CD Player
JVC drains battery when OFF, puzzling
The problem is actually the wiring. Check the installation manual, I guarantee the "pro" installer took a shortcut.
There are two power wires (yellow & red +) and a ground wire (black -).
Now, black goes to chassis grounding point. Easy.
Yellow goes to a live terminal in the fuse block for constant 12V.
This retains the settings and clock etc.
Red goes to an ACCESSORY terminal in the fuse block (so key must be turned to at least ACC to allow it to be switched on).
But in the case of my car, the idiot who installed it ran the red wire directly to the + battery terminal. That's wrong, and will drain the battery.
Google for an installation manual, I'm certain your JVC head units will be the same procedure.
Jan 12, 2009 | JVC KD-HDR1 CD Player
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Nov 11, 2006 | JVC KD-S580 CD Player
My l/o works but my speakers running from head unit does not
You have to find the subwoofer setting on your head and turn it all the way up.
Aug 26, 2006 | JVC KD-G320 CD Player
Car Audio & Video Logo
276 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
