Question about Spark Plugs BR4HS Plug 10/BX #3322
Spark plugs gap seting for plugs for 99 pon bonevile 3800 eng
  • 211 Answers
Posted on Dec 13, 2008
Wot is the spark plug gap seting
Hi Brian:
Best you tell me what machine and the plug make and ID
Then I'll use google to look up the specified gap.
you could do that yourself.
Aug 26, 2015 | Cars & Trucks
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Need to know proper spark plug gap for 1995 buick park avenue, 3800 engine
The correct sparkplug gap for a 1995 buick parkave is .060 gap. good day
Aug 27, 2011 | Buick Park Avenue Cars & Trucks
Where are the spark plugs located on the 1999 Intrigue???
Your Intrigue is equipped with the 3800 V-6 motor...The motor is mounted transversely...(sideways:) You can trace the spark plug wires from the spark box to each of the 6 plugs...I recommend you use AC platinum tip plugs, verify the gap...should be 45 mm...spark plug gap tools are inexpensive and available at all parts stores...Use thread lubricant...and plug wire tip lubricant...As your mileage is over 80,000 you should also consider replacing the wires too...:)
Dec 20, 2010 | 1999 Oldsmobile Intrigue
Do you know the firing order on a 1981 fiat x19 1.5 engine
X1/9 1500,
Ignition system type: CB
Ignition coil make/type: Lu/DLB101
Supply voltage: n / a
Primary resistance: 2.4-3.3 Ohms
Secondary resistance: 3330-4070 Ohms
Distributor make/type: Ma/S135LX
Contact breaker gap/air: 0.4 mm
Dwell angle: 52-58 Deg
Ignition Timing - unleaded: n / a Deg eng/rpm (without vacuum)
Ignition Timing - leaded: 5/800 Deg eng/rpm (without vacuum)
Timing mark location: Pulley
No 1 plug location: N/S/R
Firing Order: 1-3-4-2
Spark plug make: Bosch
Spark plug type: WR6DC
Electrode gap: 0.7 mm
Mar 25, 2010 | Fiat X1/9 Cars & Trucks
Need to find gap setting for autolite spark plugs for ford contour 2000 model 2.0 eng. double overhead cams
The spark plug gap is usually on a sticker under the hood or in the owners manual. It is usually in the range of 0.045 to 0.060. Don't believe the guy at the parts store when he says the plugs are pre-gapped.
Sep 15, 2009 | 2000 Ford Contour
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
Zachary Reed
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
