Question about Hardware & Accessories
Wire diagram for metal halide wall pack with photocell
3 Suggested Answers
  • 56 Answers
SOURCE: i want to wire a photocell to overide my T101
You need to come off the line side of the clock to feed your photocell. And then from the load side of the photocell you can feed to the load side of the time clock. Leave the time clock wired the way it is now. What this will do is feed the light with the photocell or the time clock, but keep in mind by doing this the light will always remain on when it is dark. There is no other way to do it.
Posted on Sep 30, 2010
SOURCE: I would like a wiring diagram for an outdoor
If I understand correctly, you want to add a photocell to existing receptacle.
Start by looking at receptacle:
Receptacle has 3 different colored screws.
Green screw for bare ground wire
Brass screws with black Hot wire connected.
Silver screws with white Neutral wire.
How to wire photocell to receptacle.
Remove black Hot wire off of brass screw and connect black wire to photocell-black wire. This will power the photocell switch.
Connect photocell-red wire to brass screw on receptacle. This will turn receptacle on-off whenever photocell switch turns on-off.
Connect photocell-white wire to silver screw, and this will complete circuit to photocell switch so the switch is able to operate.
All white Neutral wires are connected to silver screws.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 08, 2011
When could I get an answer to my question
Have you tried contacting the manufacturer?
Oct 05, 2015 | Home
How do you connect a photo cell to a 220v HID fixture?
You can connect photo eye white wire to ground wire, and it will work, since each hot wire in 240V circuit carries 110V to ground.
But this installation is not code.
It is not necessarily dangerous if you are only person working on electric circuits, and you remember what you did, and don't work inside main box without turning off power.
See illustrations.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
Running a White neutral wire from nearby outlet is best solution.
Or buy 240Volt photo eye.
Oct 12, 2012 | Cooper Wiring Devices 1301-7LTWBOX LIGHTED...
When do I need to use a glass shield for my aquarium lighting?
When you are using a metal halide a glass shield is a necessity. Metal halides get really hot and one drop of water could cause the bulb to explode. A glass shield would also filter out the UV rays.
Aug 21, 2012 | Fish
What is a metal halide lamp?
The metal halide lamps come in two versions the regular one and the HQI version. These lamps are very useful to the aquarist needing a lot of light. Their commonly come in 250,400 and 1000 watt sizes. The bulbs range in lifetime from 6000-10000 hours.
Aug 21, 2012 | Fish
I need a replacement ballast and capacitor for a 400W metal halide outside light, I need to know who would carry it and also a wiring diagram
most home depots will have a replacement ballast for this light, inside of box will have the correct wiring diagram, and how to wire it, if not sure as to how to wire it call an electrician
Nov 22, 2011 | Home
My house is wired thru a 120v photocell for the exterior lights. It will not turn off and the lens is clean. There is no wall box behind it. There is just a small black photocell in the exterior stucco....
If you can't remove or replace that photocell, you can bypass it. Since the lights stay on, you could locate the circuit elsewhere and wire into that location another photocell or timer or both.
Gary
May 19, 2011 | Garden
The lights do not go off ?? Is it a bad photocell? They are on all day..and night..
Photocells go bad.
If photocell was working before and stopped working, then photocell is bad.
If photocell never worked, then check wiring.
I buy cheap 120Volt photocells at home center, and when they go bad, buy same brand again, and return bad one in new package if bad one still looks new.
Intermatic has 120V and 240V photocells.
Open following link for Intermatic resources and ez photocell wiring diagram
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#photo
Apr 21, 2011 | Intermatic K4221C Photo Cell Control 120 V...
I would like a wiring diagram for an outdoor receptacle controlled by a photocell. Photo cell has 1 each black wire, red wire and white wire.
Feb 07, 2011 | Intermatic K4221C Photo Cell Control 120 V...
I want to wire a photocell to overide my T101 timer for cloudy overcast days. Please provide a wiring diagram. Thank you
Sep 30, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Need a wiring diagram to connect a photocell to LS 70 sodium fixture
please give me wiring diagram to connet photocel with auto and manual switch
Sep 26, 2009 | Cooper Wiring Devices 1301-7LTWBOX LIGHTED...
Hardware & Accessories Logo
414 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
