Question about Monster Cable Products Monster Beats By Dr Dre Headphones
How do i rewire my powerbeats headphones?
Rewire headphone jack
2 Suggested Answers
dylandidiano
SOURCE: I have a pair of dr dre monster headphones and the
You would have to open up the headphone casing (voiding the warranty) and re connect the wires on the inside.
Posted on Oct 17, 2011
Sound from headphones on computer terrible
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards You will need to open up your computer to check the back of the input headphones plug look for dusty and bad soldering or loose connections. b> Computer Headphone Jack Has Fuzzy Noise b> When building a computer system, making headphone and microphone jacks are one area where computer manufacturers use the lowest-cost parts. When it comes to computer audio, no perceivable difference in sound quality exists between that of ordinary parts and higher quality ones. Very low-quality parts, or parts that are installed with sub-par wiring, however, can lead to fuzzy sounds and static on headphones.
Symptoms and Component Isolation Start the diagnosis by using different headphones in the jack. If the fuzzy noise or static problem persists over multiple headphones, even if it doesn't happen with all of them, it's probably within the jack on the computer. This is also probably the case if the static increases when you do other things on the computer, like dragging windows around on screen with your mouse, then stops when you stop dragging windows. Causes b> The leading cause of headphone jack static is electromagnetic interference from other components in the computer's case. When electrical devices draw current, they also generate a magnetic field. Overlapping magnetic fields cause static. To combat this effect, the manufacturer provides for the components on motherboards to be grounded - the wiring from the microphone jack will have an extra lead that goes directly to a grounding agent. When your computer headphone jack has a fuzzy sound, or static, the ultimate cause is usually bad grounding on the wiring that the jack plugs into. Rewiring The Jack b> If you're comfortable with a soldering iron, and know enough about electronics and wiring, you can remove the wire to your microphone jack and put in one with heavier shielding, or a better ground. If you're not comfortable with this, a computer repair shop may be willing to tackle this for you; the actual cost in labor is about an hour to an hour and a half of labor time. It may be less if the shop technician is familiar with this sort of repair, as opposed to only knowing how to swap cards on the motherboard. Using Different Ports for Audio Cheaper alternatives exist than rewiring the headphone jack on your motherboard. One of them is to put in a dedicated sound card - which will cost $15 or so, and you may have a compatible one from an old computer that can be scavenged. This will require researching the make and manufacturer of the card to download compatible drivers off the internet, and then installing them on your computer. If you have an unused USB port, the easiest solution is a pair of USB headphones. This has the advantage of working with future hardware as well.
How to reduce static in my audio http://www.miracletutorials.com/how-to-reduce-static-in-audio/
Feb 27, 2013 | Computers & Internet
Is it possible to fix the fiber optic wiring on a pair of Dre Powerbeats headphones, the wire was cut clean through?
I don't think if that is possible. I have mine laying for two years now hoping that a miracle will happen ..;-)
Feb 13, 2013 | Beats By Dr Dre Monster PowerBeats -...
Jack on my monster beats broke what do I do?
The warranty will not cover it, it will be called abuse.
Go to your local electronics store(radio shack) and buy a plug you can rewire with.
Feb 17, 2012 | Monster Cable Products MH BEATS IE...
I'm trying to rewire my Harmon/Kardon M6531 speakers to a 3.5mm headphone jack. Thanks, Henry
thats easy get a headphone jack and solder two wires to the center pin of the jack then solder two wires to the other two connections then connect one set of wires to the center and top wire connection and the other two wires go to the center and the lower wire connection. plug it in and now sound will come through the speakers
Feb 28, 2011 | Office Equipment & Supplies
Do I need to buy a seperate headphone jack adapter in order to put my headphones in? The headphone jack seems too small. If so what should I buy?
What type of headphone connector do you have? The Yamaha keyboard headphone jack is a 3.5 mm stereo jack (like on a computer headphone jack). So if the headphones have a 1/4" plug, you need a 1/4" to 3.5 mm adapter.
I hope this helps.
Dec 26, 2010 | Yamaha YPT220 PAK 61 Key Keyboard wAC...
Toshiba A10 headphone jack problem
I think you are on the right track, if the headphone jack is worn and shorting out itll kill the speakers because it thinks headphones are plgged in, ebay would be a good start for parts, maybe even call toshiba and speak to their tech support.
Dec 13, 2008 | Toshiba Satelite A10 Notebook
Rewiring
First of all we need to know which part of the headphones were eaten, but most of all wireing is available thru Radio Shack. Good luck.
Jan 26, 2008 | Bose on-ear TriPort Headphones
Sennheiser hd555
white = tip. red = ring. blue and black = sleeve
Jan 07, 2008 | Sennheiser HD 555 Consumer Headphones
How to Rewire Sony MDR-7506 headphones
Okay, cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Nov 26, 2007 | Sony MDR-7506 Professional Headphones
Monster Cable Products Monster Beats By Dr Dre Headphones Logo
584 people viewed this question
Top Monster Cable Products Audio Players & Recorders Experts
Jason Morris
 Grubhead
Grubhead
 Mikey
Mikey
Are you a Monster Cable Products Audio Player and Recorder Expert? Answer questions, earn points and help others
