Question about KitchenAid KSF26C6Xyy Side by Side Refrigerator
If my Kitchen Aid KSF26C6XYY00 door is in fact made of stainless steel, why do fridge magnets stick to it? Ohter people I know that have stainless steel fridges say that the magnets do not stick to t
Are there different levels of quality in stainless steel finishes on appliances? I would think that this KitchenAid would have real stainless steel trim.
  • 3,961 Answers
Stainless steel is a term for a family of high chromium steels, some of which do in fact stain, although they do not rust as ordinary steel does.
The more expensive 'austenitic' stainless is non-magnetic, but harder to work into product shapes. 'Martensitic' stainless is a little more prone to staining and corrosion, but easier to work with, and is magnetic. Then 'ferritic' stainless is even cheaper, but less corrosion proof, and is also magnetic.
So yes, many stainless steels are magnetic, and if the manufacturer has not used the very most corrosion proof but expensive grade, then you will see it in that way. I would not see much reason for a fridge door to be made from austenitic stainless.
Posted on Feb 17, 2012
3 Suggested Answers
  • 17 Answers
SOURCE: Model Number
Open the drawer or bottom cover panel and look on the facing where the door closes to
Posted on Dec 05, 2007
  • 360 Answers
SOURCE: I HAVE A SIDE BY SIDE KITCHENAID FRIG. THAT THE
yes, they can be replaced, for pricing and availability, use your model number to look them up at this site.
http://www.appliancepartspros.com/
Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 26, 2009
Fridge leaks from freezer
Sounds as drain is plugged. Remove rear cover in the freezer and check drain . Also clean drain pipe in the fridge at the top part and clear drain tube
Aug 26, 2014 | KitchenAid Kitchen Aid 19.8 Cu. Ft....
My kitchen aid refrigerator is not cooling
Could you tell me if the compressor is running?
Nov 12, 2012 | KitchenAid KBFS25EVMS Stainless Steel...
KitchenAid - Is it real Stainless Steel?
The fridge freezers are called stainless steel but it is a term that is used more for marketing than an actual statement of what they are made of, the grade of stainless steel they use is very very low grade and the manufacturers of the appliances coat the steel with a protective clear coat to stop corrosion. This is why it is magnetic.
Mar 06, 2012 | KitchenAid Refrigerators
Rust spots appearing on the front doors of my Bosch refrigerator
Stainless steel does rust - or at least that is the theory.
There is in fact two types of stainless steel; the original categorised austenitic which is instantly recognised due to it being unable to attract a magnet due to the absence of iron. Austenitic is relatively expensive and difficult to work but adding iron in various quantities to the alloy produces a cheaper, lighter metal that looks good and is easier to work while still providing some resistance to corrosion. The more iron that is added to the ferritic type of stainless, the lighter, cheaper and easier it is to work but the corrosion resistance is substantially reduced.
Cars have been fitted with stainless steel exhaust systems of the ferritic type for many years and although they last a long time they soon show surface rust and sometimes will rust through.
I expect your fridge wipes are either acid or alkaline that are suitable only for austenitic and good grades of ferritic and Bosch have used a particularly poor grade of stainless. I expect fridge magnets stick very well...
Mild discolouration could be removed with a mild abrasive cleaner though that would tend to ruin the brushed finish. Clearly future cleaning should be carried out with a neutral ph cleaner and the surface protected with a hard wax polish.
I suggest you check the cleaning instructions in the Bosch instruction book. If you feel you have done nothing wrong you might be able to claim from your household insurer as accidental damage. It would be a good idea to inform the manufacturer of the cleaning wipes...
May 27, 2017 | Bosch B26FT70SNS
Rusty Exterior
good day,
hope this link below will solve your problem.
kitchen appilances
Jul 09, 2010 | KitchenAid Superba Architect KSCS25INSS...
Why does a magnet stick to Frigidaire Stainless Steel?
some stainless steel has enough iron in it to be slightly magnetic. not all stainless steel is truly non magnetized.
Feb 07, 2010 | Frigidaire FRS-26DR7D Side by Side...
Rust on stainless steel
1) Take rust off with Bar Keeper's Friend and a damp sponge.
2) Rinse and dry
3) Wipe with mineral oil.
Will be good as new
Sep 24, 2009 | Whirlpool GC5THEXNS Stainless Steel Side...
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
Finish on "stainless steel" door is deteriorating
Refrigerator was sold as 'stainless steel', but is not, a magnet won't stick to it.
There are many different alloys that are called 'stainless' steel but all of them have some chrome, some nickel and some steel. Depending on the strength of the magnet and the specific alloy, it may or may not adhere. Generally, the higher chrome and nickel content, the less magnetic it will be.
I think that the brushed surface of your fridge was coated with a kind of clear-coat to prevent fingerprints from adhereing to the brushed surface and that clear-coat is now missing in the areas of concern.
The only cure for tha would be the wholesale removal of the doors and the remaining clear finish and then respraying it with a quality clear finsh.
Ain't progress grand?
We considered all stainless stuff for our new home a couple of years ago, decided we liked black better and now hate that too.
Dec 10, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid KSF26C6Xyy Side by Side Refrigerator Logo
435 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
