Question about General Electric WCVH6800J Front Load Washer
GE WCVH6800J1MR wont spin or drain
I CAN TURN IT ON AND PICK A CYCLE WASHER FILLS WITH WATER SPINS LIKE 3 TIMES THAN STOPS SPINNING HUMS FOR THE REMAINING OF THE CYCLE AND WONT DRAIN THE WATER EITHER. I HAVE FREE HAND SPUN IT, BELTS GOOD, AND MANUALY DRAINED IT AND CLEANED OUT THE FILTER STILL NOTHING.
  • 1 more comment
  • phr3ak38
    phr3ak38 Feb 17, 2012
    AS I ALSO NOTICED WHEN I TRY TO START A CYCLE IT STARTS FOR ABOUT 5 MINUTES THAN UNLOCKS AND STOPS AND LIKE SOMEONE PAUSED THE CYCLE
  • martin contreras Feb 19, 2012
    mine did the same thing and come to find out it was the dispenser motor
  • phr3ak38
    phr3ak38 Feb 19, 2012
    well to replace the motor that turns the drum and the 4 shocks that are no good as well as the possible water pump its gonna come out to about 545.00 found the exact same model but white at home depot on sale saturday for 536.00 and a 4 year warrenty for 100.00 more so i went that option instead of fixing the one i have
    Problem Solver:
  • 17 Answers
Sound like the water pump is shot
Posted on Feb 17, 2012
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
Sep 16, 2009 | Washing Machines
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
General Electric WCVH6800J Front Load Washer Logo
282 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
