Question about Gateway Computers & Internet
How to upgrade a Gateway 450SX4 Laptop to accept 2 GB of ram instead of 512 max
  • 188 Answers
Please refer the following link and this has the solution for this
http://751b3dfe.linkbucks.com
Posted on Feb 17, 2012
5 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: Gateway 450SX4 512MB max
Go to the gateway site, and select the option to allow gateway to tell you about your machine. It will tell you maximum ram capability
Posted on May 01, 2009
SOURCE: Can't upgrade to 2GB RAM
I just installed 2 1gb chips in my mt3705 and it works perfect  so it might be a problem with your hardware.
Posted on Oct 03, 2008
  • 20 Answers
SOURCE: laptop monitor hinge needs replacing and ram
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena22
Posted on Jan 03, 2010
drifterK
  • 4924 Answers
SOURCE: Laptop max RAM is 2GB. Had 512mb single stick. Won't accept upgra
the problem is the frequency ...you have to set into bios on the memory to read it on the lower one..so it will read both ....also if it is booting with both on but not showing into the windows properties..you have to reinstall the operating system to do that ...In-fact this is a standard procedure when you upgrade the Ram memory ..even if it reads it all ok ..you still have to reinstall...
You was kinda messy in explanations and I didnt quite understand what kinda memory you put in and it do not boot at all..but remember that this laptop will not read anything bigger than !G on one slot ..and ..if it reads them separately ...but when you put them together it is not even starting on reading devices..than you have to insert them and short the bios to reset all to the factory defaults with the memory in ...in that moment the bios settings will force to the lowest frequency ..in this case the one from the 512 unit ..
Posted on Mar 01, 2010
Just installed 2 512 mb memory but when i turn the laptop on the fan turns on and the lights blink but it works fine with old memory. and others have upgraded memory to 2 gb when the max is 1 gb and theirs...
Sound like you have two questions:
1) Why does my new memory not work?
2) Can I upgrade to 2 GB?
For Question #1, my thought is that maybe the new memory does not match up the laptops specifications. According to Gateway's website, "This notebook has two 200-pin industry standard DDR-SODIMM sockets that can accept 266 MHz DDR RAM memory module." Is the new memory 266 MHz? If not, that could be your problem and you should get the appropriate type of memory.
If the memory you purchased is 266 MHz, you probably have defective hardware and should seek a refund or replacement.
As for Question #2, you can try it but you may waste your money. If the manufacturer says the max memory allowed is 1 GB, it probably is true. I would only try it if you could get free, cheap or borrowed memory.
Mar 11, 2011 | Gateway M305CRV Notebook
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Fitting RAM
Here are some instructions that should work for all 3000 series laptops.
http://support.gateway.com/s/Manuals/Mobile/8512061_Apache_RPL.pdf
Mar 31, 2010 | Computers & Internet
Trying to upgrade memory in a toshiba satellite a105 s1013
Pls Check this link, in reference to your memory upgrade...it seems that your laptop could only accomodate max 1Gb of RAM
http://support.gateway.com/s/Mobile/Q106/Magic/5948sp2.shtml
Feb 14, 2010 | Gateway MX3215 Notebook
May 01, 2009 | Gateway 450SX4 Notebook
No display after upgrading RAM
Are you saying that there are only 2 slots for ram or 4, if 4 then you may have a dual channel lap top, in which case you need all of the ram to match, they all have to be the same exact ram.you cant mix and match, also is the bios recent, it sounds like you may need a bios flash if the laptop isn't recent.And there may be a limitation on the amount of ram it takes, I just setup a brand new acer and it only two gig max, see if they offer a bios update
Dec 23, 2008 | Gateway M-6866 15.4" Widescreen Laptop...
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
Upgradeable?!
RAM - 512 MB (installed) upgradable upto 2 GB (max)DDR 2 SDRAM ( 1 x 512 MB ) that means your laptop has only 1 slot for memory.. ____________________________________________________
Was this solution helpful .Show your appreciation by rating it.
dilipbagdi - Technical Associate
Jun 09, 2008 | HP Business Notebook 530
Computers & Internet Logo
165 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
