Question about HP Mini 1000 Netbook
Hpmini311 display logging screen for windows 7 then after logging in just black screen
  • 338 Answers
This worked on my wife's hpmini, remove the battery and the AC adapter from the unit and turn the unit on and hole the switch in the on position for about 5 seconds. This will do a hard reset. Replace the battery and if necessary, re-attach the AC adapter and turn it on and it should work for you.
Posted on Feb 17, 2012
Tip
Customise the log-on screen in windows 7
Changing the Windows log-on screen used to involve some complicated and potentially dangerous hacks, but not any more - Windows 7 makes it easy.
First, browse to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Authentication\LogonUI\Background in REGEDIT, double-click the DWORD key called OEMBackground (not there? Create it) and set its value to 1.
Now find a background image you'd like to use. Make sure it's less than 256KB in size, and matches the aspect ratio of your screen as it'll be stretched to fit.
Next, copy that image into the %windir%\system32\oobe\info\backgrounds folder (create the info\backgrounds folders if they don't exist). Rename the image to backgroundDefault.jpg, reboot, and you should now have a custom log-on image.
Alternatively, use a free tweaking tool to handle everything for you. Logon Changer displays a preview so you can see how the log-on screen will look without rebooting, while the Logon Screen Rotator accepts multiple images and will display a different one every time you log on.
on Jan 10, 2010 | Computers & Internet
Desktop not accessible/ full black display
Presumably you see items on the screen while the os is loading and you are able to see the login prompts?
If this is a windows OS start it up in safe mode (tap f8 when first turned on to get a boot menu) to see what happens. Sounds like a resolution issue. If windows opens in safe mode look for evrror messages in the system logs relating to graphics gards or look at lowering the graphics resolution, also try attaching an external monitor. Post back if you get stuck
Dec 09, 2013 | Toshiba Computers & Internet
Vmfusion emulation of windows 7 language change
How to change the Windows 7 Display Language:
1. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
2. Switch the display language in the Choose a display language dropdown menu.
3. Click OK
4. Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
May 05, 2012 | Apple iMac Computers & Internet
My laptop came on but my screen is black. I can hear my coputer on but my screen is staying black.
Here are some discrete steps you shall also take besides fixing your Windows 7 registry which is inevitable for safer and stable computing:
* Conduct an antivirus and antimalware scan. Fixing for malwares after a registry scan gives an extra protection to the PC and saves PCs from lots of dangerous infections.
* Start Windows 7 in safe mode and restore your PC/system to the previous date after which you received the Windows 7 updates. It is believed that some updates may be behind these screen issues in Windows 7.
* Adjust your display settings since the wrong settings may also cause the Windows 7 black screen also called the blank screen. You can do this by starting Windows in safe mode.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen.use registry cleaner reg in out to solve the issue
Sep 13, 2010 | HP Pavilion dv6000z Notebook
Laptop is working fine until the screen goes black
The problem of black screen can also happen in other versions of the Windows. However, the symptoms and effects of the problems in all operating systems are almost same. For instance, when a user starts his Windows, everything goes fine. But when he logs into it there awaits a black screen instead of the normal desktop layout. An average computer user finds it very disturbing and has no clue how to fix Windows 7.
However, the best way to find a solution to this problem is to fix the registry errors in your computer which become the cause of all major Windows errors and crashes. The registry in Windows 7 is a very important component of the entire operating system and it stores information about the Windows settings. If these settings are not adjusted properly then there start to appear strange computer problems such as Windows 7 black screen.
Follow all the guidelines and start from registry repairing scan for Windows 7 to fix Windows 7 black screen. The best available tool to repair registry and fix PC errors such as this is Reg In Out.
Sep 12, 2010 | Acer Aspire One PC Notebook
Acer Aspire boots from hd or cd to black screen with mouse in center. No windows logo just the Microsoft Corporation copyright. Can this be fixed?
go to BIOS change the primary boot up from HDD to dvd.cd rom . it willl automatically boot from dvd/cd and then preoceed installing/repairing windows
Jan 13, 2010 | Acer Aspire 5315 Notebook
When I log on to my laptop, windows screen goes
By going into the Task manager, type windows explorer in the new tab. That should bring up your desktop icons, The reason for this could be that you have a lot of applications trying to load all at once and it can cause some lock up in the system.
A full system repair should be your last choice.
Apr 22, 2009 | Acer Aspire 7520-5757 Notebook
HP Mini 1000 Netbook Logo
20 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
