Question about Garden
What size chain does a poulan woodshark model p3314wsa use?
Poulan chain saw p3314 what is the gas to oil miture
3.2 ozs of two cycle oil to 1gallon of gas 40:1
Oct 17, 2016 | Poulan P3314wsa Chainsaws
What damage can i cause by hooking the fuel line up backwerds
None, it shouldn't run if your connect the two pipes wrong. I am thinking it is a simple carburetor, one flow pipe in and the other is a float bowl overflow.
Your manual isn't much help.
http://www.poulan.com/ddoc/POUO/POUO2010_USen/POUO2010_USen_545186804R2.pdf
and there is a zoomable exploded diagram here, but resolution isn't high enough.
Here is your carb connected to the filter in high res. And that carb doesn't have a bowl or overflow.
http://www.amazon.com/Carburetor-P3314WS-P3314WSA-P3516PR-C1M-W26/dp/B00SGLD8M2
Chainsaw Shed Poulan P3314WS WoodShark P3314WS Type 1 Parts List for...
Jan 31, 2016 | Poulan Garden
My poulan woodshark model # p3314wsa bogs when I start to cut how do I fix it runs fine when not cutting
Remove the muffler, and check the spark arrestor to see if its clogged with Carbon. Clean it by either wire brushing the carbon, or heat the spark arrestor with a propane bottle torch, and the carbon will burn off.
Nov 17, 2013 | Garden
I have a poulan woodshark i traded for a old tv it has great compression and great spark but it wont start i think they might have messed with the carb what should i do thanks
Turn the carb adjustment screws all the way in and then turn them 1 full turn out and try that. If it starts it will probably require some fine tuning or some tweaking to get it to start. I also suggest you clean and kit the carb just to you know it has a good diaphragm and no clogs
Jan 17, 2013 | Poulan Garden
Need a owners manual for p3314wsa chain saw- poulan
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006_545137250.pdf
Sep 04, 2011 | Poulan 14" Chainsaw
Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Jun 24, 2011 | Poulan Garden
Disassembly of poulan woodshark model p3314wsa to
This is an IPL for a Poulan P3314 (may not be your saw), It seems there are 2 different size hoses, I suggest you disturb only what is necessary, take a digital photo, then a small sample of both sizes to a local saw outlet. 12" of both sizes should be ample, ask for his guidance before you order.
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://weborder.husqvarna.com/order_static/doc/NIUS/NIUS2008/NIUS2008-P3314-530165402-952802026.pdf
Many also find this helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If not your saw try here (there are 3 "P3314WSA"s available):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The IPL can be used as a disassembly guide too, although you should not need disassembly beyond removing a cover or 2. Good luck with your project If I can be of more help you can reply below. HTH
Lou
Jan 28, 2010 | Poulan Garden
Woodshark poulan 14" slack chain
make sure the little tooth on the end of the adjuster for the chain is locked into the groove its supposed to go into and tighten it down.
Note: the chain is supposed to get loose on you but not as quickly as it is. maybe after an hour or so of cutting.
and as for it not cutting well, the chain may need sharpened.
if it has been sharpened once by someone than take it to someone esle if it is not satisfactory.
Jan 11, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Have poulan woodshark, the chain oiler is feeding
send me ten bucks and I will tell you.
Aug 03, 2009 | Poulan Garden
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
