Question about Troy-Bilt 32cc 4Cycle Backpack Blower
Ignition module air gap troy-bilt tb4bp - Troy-Bilt 32cc 4Cycle Backpack Blower
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: lost my manual,what engine oil to use for my troy
You can find your manual here:
http://manuals.mtdproducts.com/mtd/Safety.do?BrandCode=10001&pid=235248&model_num=TB4BP&serial_num=100063&filename=769-03148c.pdf
You must choose accept to open or download the manual.
769-03148c.pdf is the file name.
Or go to this page and click View manual after entering your model and serial number:
If you do not know your serial number enter 100679 and you will still see your manual.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
7.9 Mb download! The informatiion you seek is in the manual on page 8.
SAE 30 SF or SH or SG (3.04 fl oz total capacity to be changed every 25 hours)
Thanks for choosing FixYa,
Kelly
Posted on Aug 29, 2011
Diagram of tb4bp troy bilt backpack blower fuel line assembly
Troy-Bilt would be the most likely source.
Jul 17, 2017 | Troy Garden
Can i get piston rings
sorry not from us perhaps a troy built dealer can order some for you
Aug 01, 2015 | Troy-Bilt 32cc 4-Cycle Gas Backpack Blower...
Adjust ignition timing gap
CLOSE! put two pieces of paper against the Flywheel, then put the Coil in place loosely. rotate flywheel until magnets hold the coil to the flywheel ( with paper in between) then tighten
Nov 21, 2013 | Troy Bilt Tb320bv Spring Assist Blower/Vac
TB4BP won't pull
crankcase could be full of fuel causing it to hydro lock take plug out and see if it will pull over be carefull though if it's hydro locked with fuel it will pump out of the sparkplug hole. the rope may be off of the starting pully as well
Aug 26, 2012 | Troy-Bilt 32cc 4-Cycle Gas Backpack Blower...
Whats the gap on the spark plug on troy bilt tb20cs
Hello, Johnny -
The correct gap is .020" (0.5mm).
Link to specification page in owner's manual attached.
Troy Bilt TB20CS Operator Manual Specifications
Mar 06, 2012 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Tiller will not start, changed the spark plug and there is no spark.
If this model is a 2 stroke engine, it may need the air-gap adjusted between the ignition coil modules legs and the magnets built into the flywheel.
Apr 19, 2011 | Troy-Bilt Garden
I have a troy bilt trimmer...it is getting gas,spark,compression,and i rebuilt the carb.... what else could be the problem
You have all the elements of a running engine. Final items to check:
1. Muffler. Can become clogged with insect homes or carbon deposits. Restricts back pressure and it will not run or will run poorly.
2. Your spark could be insufficient in which your Ignition Module/CDI would need to be replaced.
3. Insure that the 4-screws holding the carburetor holder / lower crankcase are tight and that the gasket is in good condition.
4. Spark plug gap may be too large.
Insure the engine will run by putting about a tsp., of premix down the spark plug hole and pull over. If you are not getting it to run for about 5 seconds, you likely have an electrical problem at the Ignition module/CDI nothing out sufficient spark. This would likely be cost prohibitive to repair.
I'm betting on the muffler...
Sep 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
What is the gap between the ignition module and the flywheel magnets on the Kohler M8 ST motor,used on the Horse tiller.
The gap is between .015" - .020" when you tighten it down it gets closer so if possible use a .023" shim between the pick up and the magnet to hold it in place.
Jul 22, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
What should gap be between ignition module and flywheel magnets on troybilt 575ss 4 cycle weed trimmer? It is a year 2006 model.
Pull the module back, tighten it up and align magnets on flywheel with module. Put a business car between them and loosen the module. It will move against card. Tighten the screws there. It's set.
Jun 27, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt 32cc 4Cycle Backpack Blower Logo
237 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
