Question about Ardisam Garden
Honda fg100 rotortiller parts diagram
Not getting fuel
    Sergeant:
  • 316 Answers
Hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, ff
Posted on Feb 21, 2012
3 Suggested Answers
  • 122 Answers
SOURCE: Where can I find Honda FG100 replacement fuel
http://www.planopower.com/store/honda/index_tillers.shtml
Posted on Feb 08, 2011
My Honda FG100 tiller's tines spin when not in the dirt but as soon as I put them in the dirt they stop. What could be wrong with it?
My guess is the clutch shoes bite enough to turn when unloaded but slip when loaded. Try www.hondalawnparts.com for a view of the parts. You will need your chassis number off the machine label as there are several versions of the FG100. A good handyperson/home mechanic should be able to change these / establish the fault. Parts are at your local Honda garden agent or online.
Aug 14, 2016 | Honda Garden
My honda FG100 has a broken primer bulb. What other parts should I replace at the same time -- is there a name for the membrane under the primer bulb?
Check the fuel lines when you replace the bulb. If they are hard and brittle replace them also.
The membrane unless damaged is fine. If you need to replace it you will need to purchase a carburetor rebuild kit
May 05, 2015 | Honda Garden
Hello. I have a new Honda carburetor for a fg100 tiller with new gaskets. Is it possible to get the order of assembly for all of this?
Several of the small engine parts websites have parts diagrams that you may find useful. These usually show the order of assembly if you study them carefully. You will need your model # and sometimes serial number.
Nov 02, 2013 | Garden
What type fuel; and mixture for honda fg 100 mini tiller
the Honda FG100 is a 4-cycle engine do NOT mix oil with the gas, - you will cause damage to the engine (head, valves, piston rings etc) not to mention if will not run well.
Mar 08, 2010 | Honda 25cc 4-cycle Mini Tiller
I need a worm wheel for a Honda minitiller FG100.
You can buy parts for this from www.petessmallengine.com
I had to replace the tine shaft w/worm wheel assy. This is usually the weak point in the transmission. The worm is made out of brass.
Jan 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda fg100 stalls when warm
Try giving it a quick tune-up. First dump the old gas (todays fuel can be considered old if its been setting for more than 30-days), pour it back in to a fuel can and put it in your car (it will be fine). Now add fresh "premium" grade (92 octane). Change the spark-plug. I just bought one at a discount auto parts store for $2.26. Finally, check the air cleaner. If it's a foam type clean it with water and liquid dish soap. If it's a paper filter you'll have buy a new one from a lawn equipment dealer (call first not everybody carries parts for Honda's). This should cure most engine problems, if it doesn't you may need to take it to a professional.
Apr 10, 2009 | Honda Garden
I am looking for fender for honda fg100 rototiller?
If It is a Honda FG100 like in the title the part number is 65141-V06-003
If it is a FG110 like in the description the part number will be 63411-V25-000 FENDER, RR. and 65141-V25-000 FENDER, FR.
Nov 24, 2008 | Honda Hmantis Mantis Garden Tiller with...
Garden Logo
384 people viewed this question
Top Ardisam Garden Experts
Jay Finke
Jay Finke
lnbn1975
Shehu Pro
Shehu Pro
Are you an Ardisam Garden Expert? Answer questions, earn points and help others
