Question about Sony God of War Collection for PlayStation 3
Stuck in temple
The room with a button in the floor that flips a wall section
God of War 2 walkthrough in english, THE TEMPLE OF EURYDALE,
The Temple of Euryale
Down the stairs, smash the petrified Legionnaires to shatter them, releasing red orbs. Continue on to the right and quickly shatter the petrified enemies before they break free. You can use Golden Fleece to reflect the Legionnaires attacks back at them. Prepare to reflect when their weapon begins to glow blue and they leap up into the air. Start climbing down the ladder at the end of the hall. Down below, some petrified enemies break free and a hulking Minotaur appears.
Quickly shatter the Legionnaires that have yet to break free and then immediately turn your attention to the other enemies. The Minotaur is surprisingly easy to kill if you have a full magic meter. By using Typhon's Bane you should be able to bring the Minotaur down to its takedown stage. When the Circle appears over the Minotaur's head, approach it and press the Circle button to start the takedown. Press the two buttons that appear on screen then finally rotate the Left Analog Stick as shown to finish the beast off.
Unfortunately, once you have killed enough enemies, another Minotaur appears, but at least if you kill off the first quickly, you won't have to face two of them at the same time. For the Legionnaires use Plume of Prometheus (Square, Square, Triangle) and most importantly, use Golden Fleece to reflect their leap attack. If done successfully, you can damage the surrounding Legionnaires with the reflection as well.
After the battle, head through the doorway to the right of the ladder. This hallway leads to a lift. Grab hold of the handle and rotate the Left Analog Stick to lower the lift down to the level below.
PHOENIX FEATHER (12/30): When the lift has reached the bottom, jump up and attack the snakehead on the wall to reveal an unmarked chest that contains a Phoenix Feather.
The two lifts in this room influence the height of each other. Since the soldier removed the handle from the lift on the other end of the room, you must use the lift that still has a handle to raise the lift that does not have one. Raise the lift that you used to reach this room as high up as you possibly can while still allowing you to drop down from the lift to the room below. This raises the broken lift up to that same height, allowing you to then climb up onto the raised lift and scale the wall using the ridges along the wall
Feb 10, 2014 | Sony PlayStation 2 (PS2) Console
How do i pass the room with all the mirrors on b2 in the Earth Temple
Use your R trigger and your joy stick to move the mirrors. You can only move some of them, but those are the only ones you need to move. If I'm thinking of the right spot, there should be a hidden door somewhere that you can reveal using your mirror shield.. and you will need Medli(or Melody.. I forget her name.. Lol) to help you by controlling her with your windwaker's Command Melody. left blank right blank. You will need to aim her instrument and point the light onto the parts of wall with the symbols until the wall pieces break away. If there aren't any lights in the room, you'll need to fly medli up to the button on top of the rock thing in the middle of the room. Hope this helps. I've played the game all the way through about 10 times, but I haven't played in about 2 years because my brother stole my controller and destroyed it.
Jan 19, 2012 | Nintendo The Legend of Zelda: The Wind...
My roomba 530 runs in a circle and does not move forward. After 2 minutes it stops with 11 beeps and a flashing red light to the left of the power button. It has no clicking noise. Does anyone know what is...
Hey'
This means Roomba is not registering obstacles. Roomba may be stuck in one place.
Roomba may be in extremely large room, try setting up virtual walls to create smaller area.
If Roomba is not in a large room, tap Roomba's bumper to confirm it is properly working.
Hope this helps
Avi
Nov 09, 2009 | Roomba Robotic Floor Bagless Vacuum
A Floor Master grabbed Medli in the Earth Temple,
She is in the room between the two wings with the gas and and "sunface"once ur in there play the command melody and fly over the wall in front of you.
Aug 16, 2009 | Nintendo The Legend of Zelda: The Wind...
Can't get to Bellum!!!!!!!!
Put the stones in this order Square(middle), Circle(left), then triangle(right)
Jun 13, 2009 | Nintendo The Legend of Zelda: Phantom...
I cant find the big key on the lakebed temple on The Legend of Zelda: Twilight Princess for wii not for gamecube
Do you remember the room where you get to a door by Claw shoting to a vine then another then a third? Enter the room I'm discribeing at the lower level and claw shot your way across(make sure the wheels are spinning). When you go in the door, jump in the water and make your way to a crack at the bottom of the water. After you go through the crack head right and swim up to a under water bomb rock guarded by a fish that blows up. Hold Z on him and grab him with the Claw Shot. When he's in your clutches throw it at the bomb and go through the hole. Now go down and you'll notice another bomb rock. Blow it up to find ****. Kill it and go up to find a door. Go through the door and aim up with the claw shot. Lower your self through the newly open hole to find the Boss Key chest. Now go through the door in the water quickly to ovoid the fishes to end up in a tunnel. Go through killing the Bari with the claw shot to find yourslf back at the section where the second bomb rock was. Work your way back to the room with the stairs to fight the boss. As an extra go to th 2nd floor in that room and aim your claw shot at the medallians at the celing. A chest with a Heart piece awaits. Now go to the first floor and travel west(left according to the map) and make the water flow through the door with the stairs. Go through the door and go on the floating bridge. Defeat the lizard and use the claw shot to get the last heart piece in that temple.
Apr 22, 2009 | Nintendo The Legend of Zelda: The Twilight...
I cant find the big key of the lakebed temple (wii)
Missing key
Once back inside the temple, the first three floors will be basically the same,
with a few minor exceptions. When you get to B1, head up to the switch you
went to the first time, but instead of hitting it, bomb the rocks to the left
for a shortcut to the key. Grab it and run to the door, saving you a lot of
time.
For the second floor of the temple, you will still need to hit the two switches
to drop the key down, but instead of pulling the lever behind the Phantom, you
can bomb the wall directly south of the entrance for another shortcut. Grab
the key, then proceed the same way as the first time, through the blue and red
blocks. Head for the locked door, but this time stop at the safe zone for a
bit, and head just west of there and bomb the wall, revealing a 30 second bonus
to your Hourglass. Then you may proceed downstairs.
The third floor follows an almost identical procedure as the previous run.
First, grab the Force Shard in the northwest corner and take it to the
pedastal. Once that's taken care of, head east and bomb the rocks for an
additional 30 seconds. Then, head just south and use the Boomerang to hit the
switch, stopping the nearby spikes. Then, head to the southeast corner, grab
the second Force Shard and return to the pedastal. Now, instead of going to
hit the switch to lower the fires, you can use the shovel to reveal a rising
wind that will carry you to the top platform so that you can get the key.
Kill the Phantom, grab the key, and head to the locked door. Grab the last
Force Shard and return it to its pedastal, then proceed through to the next
room. Run to the far left side of the room, grab the 30 seconds, then head
back to the Door of Wisdom and proceed through and down the stairs.
Jan 23, 2008 | Nintendo DS Lite Console
Sony God of War Collection for PlayStation 3 Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
