Question about Kenmore Refrigerators
I have a bottom freezer kenmore refrigerator. it started making a loud grinding noise and has an ice build up in back of the freezer. model #795.71302.011. please help!
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
  • 833 Answers
SOURCE: LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Posted on Jan 10, 2008
aborcass
  • 2651 Answers
SOURCE: water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Posted on Feb 23, 2008
SOURCE: Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
your drain is blocked and it causes blockage and then ice forms..turn of for 24 hoyrs and it should be alright
Posted on May 25, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Amana French Door Bottom Freezer Refrigerator making noise but not making ice
The noise you hear is the ice maker trying to make ice without a water supply. Check the line to make sure you didn't knock anything loose or kink it when changing the filter, and check for a plugged line. It could be that there is ice build up in the line, a defrost will cure that.
Posted on Jul 08, 2008
Kenmore 795.7130 bottom freezer model, loud noise when fan kicks on. from what I have read it is the evaporator fan. how difficult to change?
We had a problem with a loud noise when the motor turned on. Didn't know what it was but after a week or two, the noise went away and the Refrigerator was no longer cold (even though the freezer was fine). At this point, instead of temperatures showing inside the refrigerator read out, there was an error code: ER FF. The circulator motor was no longer working. This I read was due to an ice build up which binded the motor. We shut off the unit for 24 hours to defrost it and it worked fine after that. Do this before calling a repair man for service.
Oct 23, 2013 | Kenmore 73502 / 73504 / 73509 Bottom...
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
My refrigerator side is making a grinding noise and today I noticed that it is warm. the freezer side is fine. I have a frigidaire frs26kf6e.
Hi and welcome to FixYa, I am Kelly.
That grinding noise is usually ice build up on the evaporator coils to the point that the evaporator fan blades strike the ice build up. i.e. Possibly an automatic defrosting problem.
Here is what you can do to find out.
1. Unplug the refrigerator
2. Remove the contents from the freezer section
3. Place a fan blowing into the freezer compartment for a little over 2 hours. THIS MAKES A WATER MESS so be prepared.
4. After the manual defrosting period with the fan then reload the freezer.
5. Plug the unit back in
6. After 4 hours recheck your freezer and fresh food section temps.
7. You should no longer hear the grinding sound
It is highly probable that the ice build up will repeat. If it does then for sure you have an automatic defrosting problem and will need to service the defrosting problem. At least you will know what caused the grinding noise.
If after all of this that grinding noise you heard is still present you will have to check the evaporator fan assembly for signs of bearing wear.
If the grinding noise is coming from the compressor... bad news the compressor rotor is dragging and that requires a compressor replacement.
Your parts can be found here:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=frs26kf6e
(there are 2 missing digits from the model number)
Click on the model number of your exact model and the parts page will appear.
Thanks for using FixYa
Kelly
Apr 25, 2010 | Frigidaire FRS26KF6E Side by Side...
Refrigerator was making a 'Thump'' noise every so often and just stopped working. Freezer is still working It's a kenmore elite 3 door bottom freezer refrigerator model number 76539
Unplugging for an hour won't allow it to defrost if that is what the problem is.
Look inside the freezer at the back wall. Look for heavy accumulations of ice building on the cooling coil, which is behind the back wall panel. You may have to look in the louvers or past where the evap fan is located.
Once we know if there is heavy frost or ice there, we'll have a better idea how to resolve. Is there any warranty on this refrigerator that you know of, besides the 5 year compressor warranty?
Dec 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Ice/frost buildup & loud noise
this is classic compressor failure. the core is freezing due to unregulated pressure in the lines. repairing the compressor will correct this issue.
Mar 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
Model # 795.75286.402 Motor running load
The evap fan motor most likely is running loud due to a ice build up around the fan and the fan blade is hitting it and making a loud , irriting noise. Shut the ref off. If you are mechanical, remove the draw and the back cover, clear out the ice. Also, the ice may have been caused because the sensors-- thermistors--- are not located properly. look at the ceiling of the freezer and you see a small holder piece. the part is located there. tahke the cover off and take the thermistor that may be buried in the ceiling and pull it down and locate it in the holder, reinstall the holder. Not also, there is another one in the ref section to do the same thing
Sep 04, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice build up and loud noice when fan comes on
you have a defrost proble you will need to acess the timer and advance it to defrost post the model number so i can direct you most likely your heater is out in the evaprator
Apr 05, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
