Question about Car Audio & Video
My car starts to give out a grayie white smoke from the back end from the time i start the car untill the time i turn the engine off can someone please help me
  • active1345 Oct 25, 2008
    my car starts to give out a grayie white smoke from the back end from the time i start the car untill the time i turn the engine off can someone please help me
  • 94 Answers
Sounds to me like the cylinder head gasket has gone or even worse the cylinder head has cracked. check your oil to see if its turning creamy, seek the help of a garage ASAP
Posted on Oct 25, 2008
  • Andy Bathgate
    Andy Bathgate Oct 25, 2008
    i forgot to add keep a close eye on the water level in the radiator
I have a Ford Focus 2.0 litre zetec engine on a x plate. When I start it up from cold it bellows out white smoke for about 2 mins then clears and is fine until the next day. It is not losing water and is...
White smoke on start up of a cold engine is water vapour created by cold moist air and hot combustion ( steam). Mostly all cars will emit a whit wispy smoke until temperatures are elevated enough for the cat converter to turn it in something you cannot see. To be sure have a compression test done to check for gasket and have a coolant system pressure test done to check for coolant leaks
Dec 16, 2014 | Ford Focus Cars & Trucks
Mitsibushi pajero oil light time
White SWEET smelling smoke, or white OILY smelling smoke? If it's white thick SWEET smelling smoke, you have a blown head gasket - that's the smell of antifreeze burning in the engine, which it should NEVER do. If it's white OILY smelling smoke (smells a lot like diesel), then you're getting too much fuel into the cylinders.
If it's sweet-smelling smoke (antifreeze), pull the oil dipstick & check the oil level. If the oil level is HIGH and the oil looks like a mocha milkshake, that's absolutely conclusive - that's what happens when antifreeze gets into your oil, and it's nasty corrosive to engine parts.
I'm not at all surprised that the oil light is on if it won't start - you won't get much oil pressure until the engine is running.
Nov 05, 2013 | Cars & Trucks
Ford focus tdci white smoke problems
What happening is you have a bad head gasket or its starting to go bad. As long a little oil is getting in to cylinders causing that smoke once it warms up that gasket is expanding thus the smoke stops. I would keep an eye on oil levels if it gets milky replace gasket asap. Could also be intake gasket but highly doubt it this sounds like a worn head gasket.
Nov 27, 2012 | 2006 Ford Focus
After starting car it sputters and white smoke from exhast. I drive the car for 5 min, sputtering the whole time, and turn it off - will not start until it is cranked and gas pressed for couple min. Then...
White smoke is usually from water and water will make the car splutter. Did you get water in your tank at some time. If you have water in your fuel, you will have to drain the tank and refill with good fuel. The engine will run fine once it is hot but if a lot of water goes into a hot cylinder it can cause a lot of damage.
Apr 01, 2010 | 1998 Oldsmobile Intrigue
White smoke coming from my 95 Geo tracker, Standard shift, only on start up any ideas. Just had a tune up, new clutch, and cable.
most deffinately an internal issue. 2 possible problems oil seeping through valves when engine not running. sitting in combustion chamber and burns off during start up. 2 piston rings in one or more cylinders bad and letting oil blow by and start up is only time it is really noticeable.
Oct 09, 2009 | 1995 Geo Tracker
White smoke from buick tailpipes, wont start
I had the same problem with my '87 Buick LeSabre 2 years ago. But it didn't seem to fit right, the car was running fine up until it just didn't. I had 3 professional mechanics swear it was a blown head gasket. I researched thoroughly and found out this particular engine make has a DEFECTIVE upper intake manifold which can break down and cause coolant to leak into oil, simulating a blown head gasket. The NHTSA had issued a recal on SEVERAL GM cars with this engine, EXCEPT for the '97. I filed a complaint with the ODI and as of today it is now COVERED as a "Defect & Recall". NHTSA ID number 96V116000. This MAY be your problem if it is NOT the "usual" blown head gasket. Hope this helps.
Jun 30, 2009 | 1997 Buick LeSabre
Smoking horribly
The white smoke indicates the need for new valve guide seals. The black smoke indicates that the fuel/air mix is far too rich. Re-jet the carb to stock #137 main jet. Don't mess with the pilot jet if the bike idles okay. No other settings to mess with. Install a new stock plug ; NGK R CR9E
ALWAYS have a fire extinguisher on hand when working on carburetors.
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Check the jet needle clip on the top of the needle. Put it in mid-range. Put the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine.
I just thought of somthing. You may be creating the rich mix problem yourself. See the following starting instructions.
There is a proper way to start the engine. Four controls are on your bike to assist in starting.
  • The choke, used when the engine is cold. Pull the red knob for choke.
  • The " Hot Start " Lever, used when the engine is hot. Pull the lever to lean the fuel mix when the engine has been running.
  • The de-compression lever, always used.
  • The throttle, used to prime the cylinder.
Don't kick, instead, push the kick lever downward. You will feel the back pressure as the piston is going upward on the compression stroke to the point the pressure is great enough that the kick lever "locks up". You are very close to TDC. NOW, pull in the de-compression lever. Push the kick lever a little bit more to get the piston past TDC. Now release the de-compression lever. Give the throttle a 1/4 turn then let it snap closed. A diaphragm in the carb gives a shot of gas when this is done. DO NOT do this multiple times because you will flood the engine. Leave the throttle closed when kicking. Now give a strong kick through the full sweep of the kick start lever. Quickly get your foot off the kick lever at the end of the kick to avoid any chance of "kickback" from the kick lever. This happens in the case of a misfire, aka > backfire. It can be very painful, and can even break a leg. I am serious about that. Repeat the process (but without the throttle priming), until the bike starts. A good battery, a clean spark plug, a clean carb and clean air filter will also aid in starting.
A “very helpful” rating for this answer? Thanks!
Jun 20, 2009 | 2002 Yamaha TT-R 250
2001 Jetta 1.8T, 100K miles. Smokes when hot.
Ouch! you've got engine coolant in the exhaust from a leak somewhere...DO NOT run this engine until you get someone (dealer is best in this instance) to diagnose ($50-125)
Jun 14, 2009 | 2002 Volkswagen Jetta TDI
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
