Question about Cameras
Write protect shows on screen - Cameras
    Problem Solver:
  • 9 Answers
Take out sd card flip the switch sometimes the switch is there for safety. Or go into settings
Posted on Feb 17, 2012
How do I get to and clean screen of a Hitachi 60fx20b
honestly you will probably cause more issues than you will solve. If you separate the layers it will allow dust to get in and that will show up worse than water. If you are sure you can do it, then the front needs to come off. but be really careful.
Sep 07, 2015 | Hitachi Televison & Video
My korg x5d doensn't show bank A anymore. Instead of A01 - pipedreams lcd screen shows blinking A01 and InitProg01???
You can try this.
STEP 1:
Set Program protect and Combi Protect to OFF.
- GLOBAL
- Using PAGE+ or PAGE-,
find untill the display show "3A-MEMORY PROTECT".
Set the parameter to OFF by using YES or NO button.
STEP 2:
Data Load.
- GLOBAL.
find untill the display show "05A-PRESET DATA".
Change ALL to PRG (your case).
Use Left/Right Arrow button to moving cursor.
Choose "PRE-a" (your case).
Move cursor to "OK?".
Press YES when "OK" blinking for confirm.
Exit (Go to PROG button).
Feb 26, 2013 | Korg X5d
Olympus T-100, write protect shows on the screen & won't operate ??
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 09, 2012 | Cameras
Memory card is write protected as my nikon coolpix screen shows and no any option is getting for picture click
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 24, 2012 | Nikon Coolpix 4500 Digital Camera
My nokia 2760 will not turn on. it shows only - test mode - on the screen. what is wrong with he mobilphone
Hello
This solution provide some simple tricks on how to diagnose this problem, if encountered that only test mode showed on the LCD screen display, you may try to replace a new battery on the device. If after changing the battery doesn't fix the problem, you may refer to the solution below for it shows the certain components that needs to be remove or replace to fix the problem.
Try to remove or replace the ESD protection diode. This components were composed an ESD protection diode and a capacitor and it result to test mode problem if being damaged.
Hope it helps, if so do rate the solution
Good Luck
Dec 28, 2010 | Nokia 2760 Cellular Phone
MY kenwood KDC-W3044 is showing protect on the screen....... what should i do to remove??????
Dec 11, 2010 | Audio Players & Recorders
"protect" shows on the led screen and CDs cannot
When the "protect" indicator goes on, it's the system's way of protecting itself from a more serious problem. What has likely happened is that an internal component has failed. If there wasn't a protect circuit, the system could overheat, catch fire, or cause an electrical shock. There isn't too much you can do about this... taking it into a shop to get it fixed will very likely cost much more than if you bought a used and working version of the same model. Extracting your CD's will require you to partially disassemble the until.
One last thing you can try is to check the manual's troubleshooting section. If you don't have the manual you might be able to download it. In that section, it may provide some advice about what to do when the "protect" indicator appears, or how to extract the CD's if the unit fails somehow.
Nov 07, 2010 | Sharp CD-C3900 CD Shelf System
My screen just got hit very hard and the picture does not show but the sound is still on what to do and should i think about calling a tech out?
Unfortunately your TV is totaled. The LCD screens do require protection as they offer little to protect itself. The cost of a new screen and labor would not be cost effective. Sorry!!!
Mar 11, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Protect on the screen.
PROTECT shows up on your screen when one of the speaker wires is grounding out on something. Check all the speaker wire connections and re-insulate any that may be suspicious. Look behind the player and check those and you may have to check at the speakers as well. If your car has an amp or subwoofer installed, check at the connections there as well. After finding your grounding issue hit reset on the radio and you will be up and running.. Happy listening. K
Jun 06, 2009 | Kenwood KDC-MP232 CD Player
"Write Protect"?!
It's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 27, 2007 | Olympus Stylus 600 Digital Camera
Cameras Logo
11 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
