Question about Sylvania LC320SS9 32 in. LCD TV
How can I control the volume on my 32 Sylvania TV
    Problem Solver:
  • 9 Answers
Ummmmm pick up remote and press the volume arrow pointing up .
Posted on Feb 17, 2012
4 Suggested Answers
  • 362 Answers
SOURCE: Need remote code for Sylvania 32" LC320SS9 for Dish controller
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Let me know how it goes and please rate this solution
Lone99star
Posted on Feb 24, 2009
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
ladywinn
  • 5138 Answers
SOURCE: Will not operate power/volume for
What kind of remotes do you Have?
Posted on Dec 31, 2009
Why does my volume keep going down on my sylvania tv
Just check whether the volume down button on the remote or on the TV is jammed. Else, the TV needs attention by a qualified service technician.
Jul 14, 2012 | Sylvania LC320SLX 32 in. LCD TV
The front panel on my SRT2232S Sylvania TV has began acting weird. The menu button will turn up the volume and the volume buttons change channels. When I let go of the menu button the volume goes back to...
This can be due to moisture build up or dirt accumulating with a static charge to induce voltage and so change the customer control panel switchings.
You can try with a good cleaning of the board and panels. Make sure to dry if moisture is seen. Also check for static conducion of high voltage to the control panel that can induce the inputs to work erratic.
if not check the processor section- processor damage- and the board for a possible weakness.
Oct 09, 2011 | Sylvania SRT2232S 32" TV
What is rca remote code for sylvania model srt2232s
Hello
Four digit codes for Sylvania TV with RCA RCR 311W remote control are:
1003, 1004, 1014, 1046, 1051, 1060, 1061, 1062, 1066, 1067, 1072, 1073, 1074, 1075, 1076, 1077, 1078, 1082, 1150, 1151, 1165, 1192, 1199, 1206
Five digit codes for Sylvania TV with RCA RCR4373N remote control are:
11864, 10054, 10030, 10171, 10096, 11271, 11314, 11394, 11963
OK.
Sep 29, 2011 | Sylvania SRT2232S 32" TV
002,
008,
155,
198,
227,
231
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Jun 18, 2009 | Sylvania LC320SS8 32 in. LCD Television
Please help!
The code for the Sylvania 6432te 32" TV with the "Innovage products- Jumbo universal remote" is 189. you push and hold down the code search button, when the light starts to flash, hit tv, then the number "189". Finally, push the power button off on the remote control. if the tv turns off, then it worked. :)
Nov 05, 2008 | Sylvania 6432TE 32" TV
Codes for sylvania tv
I purchased a sylvanis lcd tv and it won't work with my comcast cable remote...I can't turn it on or off with it or turn up or down the volume. i've called my cable company 3 times and they can't seem to help me. Can you help?
Feb 10, 2008 | Zenith ZEN450 Remote Control
Cannot program Direct TV to Sylvania 32"LCD TV LC320SS8
Here is a link to your manual:
http://www.directtv-advisor.com/support-...
here are the code for your tv: Sylvania 10054, 10030, 10171
Dec 01, 2007 | One For All URC-3021 Remote Control
Sylvania LC320SS9 32 in. LCD TV Logo
160 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
