Question about Echo Garden
No spark in 2 stroke echo trimmer - Echo Garden
    Problem Solver:
  • 9 Answers
Check if the trimmert is wet in the inside
Posted on Feb 17, 2012
3 Suggested Answers
moretons
  • 155 Answers
SOURCE: weak spark on an Echo GT 1000 trimmer
Recomended spark is 6mm or more if there is no play in the crank bearings you can try closing the magneto air gap to 8 thou if that does not work you will need a new ignition module.
Posted on Jul 26, 2009
philwalker78
  • 608 Answers
SOURCE: Need to know the spark
Hi, .8 mm or 30 thou. Regards Phil.
Posted on May 09, 2011
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
Echo hedge trimmer replaced carburator still wont start getting spark
Hi, There are 3 things that you need for the motor to start.
1) Fuel 2) Air 3) Spark. Check all 3 and it should run. Good luck.
Jul 27, 2015 | Echo Garden
ECHO SRM 2100 GRASS TRIMMER HAS NO POWER
For all others with String trimmers, blowers and other 2 stroke style engines...
If no power on high, tends to bog, won't run once choke off, check these:
  • Fuel Filter - It's IN the Gas tank; Just replace it
  • Spark Arrestor at Muffler, it's a screen that tends to clog up and causes very restricted exhaust flow
  • Spark Plug - again just replace it
  • Carburetor, clean or install rebuild kit
  • And adjust sorta hidden High/Low carburetor adjustment screws
Take a look here...
And here:
And one more...
Aug 10, 2012 | Echo Garden
No spark in 2 stroke engine
If you have checked the switch, the switch wire and fitted a new plug, you must face the fact the ignition unit itself requires replacement ( assuming it has electronic ignition ) if it has contact breaker points you may need to clean/replace the points.
Feb 17, 2012 | Echo Garden
Can i use ECHO Two-Stroke Oil on any cars or motorcycles?
Echo 2-stroke oil is designed to be used in 2-cycle, air-cooled equipment. Motorcycles and boats that are 2-cycle use a different formulation of 2-cycle oil. Therefore, I would NOT recommend to use your Echo oil in anything other than lawn equipment.
Thanks for your question.
Oct 27, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Whats correct gas mixture for 2400 echo edger
Your owners manual states: 50:1 Echo High performance 2-Stroke Air Cooled Engine Oil
That would be 2.56 ounces of oil to 1 US Gallon of gas.
Oct 18, 2010 | Echo Garden
Whats the recommended 2-stroke fuel/oil ratio for echo brushcutters?
50:1 is the ratio. the easiest way to do this is to get a small bottle of the 2 stroke oil premeasured for one gallon of gas.
Feb 25, 2010 | Echo Rapid Loader, Trimmer Head
What is the correct ratio for fuel mix for a ECHO weed trimmer..SRM-210
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Use only fresh gasoline with a minimum octane rating of 89 through 93 (mid-grade to premium) at all times. The gasoline suppliers blend mid-grade and premium gasoline with greater amounts of detergents and anti-oxidizing additives to keep the engines clean. Lack of these detergents and additives in a 2-stroke engine will cause a heavy build-up of varnish and gum deposits on the piston surface and ring grooves. Regular unleaded 87 octane or lower gasoline may not contain enough of the detergent additives that are needed in a 2-stroke engine to keep varnish, gum, and tar deposits from forming. Use of 87 octane fuel may shorten the life of the engine.
ALL TWO-STROKE OILS ARE NOT EQUAL!
ECHO POWER BLEND OIL, is manufactured exclusively for ECHO, Inc. and meets the (ISO) International Standards Organizations highest performance rating of ISO-L-EGD for Air Cooled 2 Stroke oils and is JASO M345 FC/FD REGISTERED. Years of research and testing have resulted in an oil that is fully compatible with fuels containing 10% ethanol and can be used in all air - cooled, outdoor power equipment 2-Stroke engines at 50:1 ratio. ISO-L-EGD and JASO M345 FC/FD rated oils must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines. Always look for the JASO M345 FC/FD square logo and registration number to ensure you are using the highest quality 2-stroke oil for your ECHO product.
ECHO POWER BLEND OIL is made for high revving, (7,000 RPM and up) air-cooled 2-stroke engines that are E.P.A. and C.A.R.B. emissions certified. Make sure the oil has a EGD and FC/FD certification. Oils that meet ISO, EGA/EGB/EGC and JASO FA and FB are of lesser quality, designed for applications such as water-cooled boat engines, low RPM lawnmower engines, or snowmobile engines and should not be used in ECHO Engines. Prior to 1997, oils were not manufactured to these higher standards. Some or most of the oils were simply 30 or 40 weight 4-stroke engine oil with minimum amounts of additives. ECHO POWER BLEND OIL is the highest quality 2-Stroke oil available and will provide maximum protection against engine wear and carbon buildup.
Sep 04, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Open Questions:
Garden Logo
97 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
