Question about Infinity Reference 7541a Car Audio Amplifier
Amp not working
I built a new box to house my amp and hide the wiring, when I hooked everything back up exactly the same as before when it worked, I now get the clip light and the protect light flashing together and there is no sound. I have never seen the amp flash these lights before. please help!!!!
Thanks, Chris
  • 631 Answers
Does it do the same thing if you remove the RCA input and disconnect the wires from the speaker terminals of the amp?
Posted on Oct 26, 2008
Why doesn't my Receiver tell my amp to turn on
Ok get a test light and test the remote on the amp and on the back of the radio if it is good in both places then check power and ground
Apr 24, 2014 | Kenwood Remanufactured KDC-HD548U CD...
How hook amp up to a oem integration SNI-15 line output convertor
The amp needs an RCA input to communicate with the head unit. SOLDER the wires that come out of the head unit for the front speakers to the SNI-15, making sure that the polarity and right/left is correct. Do this for the front and rear speakers if you have a 4 channel amp. Cut the wires if you add new speakers and run the new wire from the speakers or sub box directly to the amp, or skin back the wire insulation and tap on if you use the factory speakers :( then plug your RCA cable from the SNI-15 to the input side of the amp. Don't forget that most new cars have their own amp so you might have to locate it and bypass the speakers wires around it. Don't make a mess in case you have to put everything back to factory for resale. You can avoid all this by installing a new/modern head unit with built in RCA outputs for front, rear, and sub woofer. I hope this helps. Ray
Apr 23, 2014 | Car Audio & Video
My 12inch speakers work in my house but when I hook them back up to my truck they dont work . My amp used to have a red light on it but now it doesnt work i bought a new amp and speakers and still nothing...
Could be a number of things. Check all the fuses (the power wire, the amp). Make sure your ground wire hasn't worked loose. Make sure your remote wire hasn't worked loose either (sometimes vibration causes loose crimped wires to come out behind the head unit). Happy Hunting
Aug 20, 2011 | Car Audio & Video
Why is my 50 amp GFIC breaker tripping out? I have just installed a new hot tube.I had one there before(smaller 40 amp) so there was already #8 wire there.The new hot tub requires a 50 amp. #6 wire. I just...
There might be a few things here:
1) Big problem >> the #8 wire is a fire hazard connected to a 50Amp breaker
#8 is a 40 amp breaker
#6 is a 55 amp breaker
We put #6 on a 60 amp breaker
Are you saying you hooked the #8 wire to the new 50 amp breaker, and the hot tub called for #6 wire?
Upsize your wire and breaker to meet code
2) After putting the correct wire and breaker, you can still have a short in the circuit somewhere
We used to set equipment out in the field in early morning >> the grass was wet >> our equipment was fine, but the tiniest short would cause the GFCI to trip
I don't know where the problem is without a thorough checkout of every possible grounded surface. You need a good multi-meter
3) You better get an electrician over there to have a look before the place burns down or somebody wakes up dead in the hot water.
If I sound a bit scary here, it's because something doesn't sound right with your installation.
Oct 19, 2010 | Inline 60 Amp Circuit Breaker
I have a 200 amp service panel i have a 100amp
Theres a few different ways to set up the secondary panel. The most efficient way, in my opinion, would be to set it up as a subsidiary. This is a really great way to allow power to be shut off for sections of a house instead of killing everything. This requires wiring it to the main panel on a breaker which will serve as the main for the 100amp subsidiary. Obviously this will require that a comparable breaker be installed in the main 200 amp panel to support the new subsidiary 100 amp panel.
Here's where it gets tricky and you really should either consult or contract a licensed technician. Because the amperage rating does not dictate the amount of power that is supplied to your house on the primary line you are essentially using the new box as a splitter. The danger in this is that just like any common electrical outlet, the more stuff you plug into it the more likely you are to overload the circuit and risk catastrophic failure, like a house burning to the ground or worse.
Knowing that your panel is side by side, you should be fine with #2 AWG, I would confirm electrical code before installing and ensure that grounds are diverted to the main panel to avoid the risk of running live current through the otherwise 'safe' ground.
If you are installing the panel to increase the amount of breakers it is probably safe to assume that there has been some previous work done that fills up the main panel. I would strongly encourage you to talk to an electrician about your needs and the changes in your house that require the additional breaker slots. There is a certain amount of artistry involved in 'designing' the house and you could probably accomplish the same end result with one panel and a more efficient wiring plan.
Mar 08, 2010 | Your One Source Homeline Load Center, 200...
I hooked up a car sterio and everything works but there is no sound. Is it possible I have a + and - crossed on one of the speakers? I am pretty sure everything on the deck is hooked up right because i had...
some cars come with a built in amp that is probably located in the rear of the car and the only you can put in an after market stero is to bypass that amp so that means that you would have to run new speaker wires to all the speakers.
Dec 28, 2009 | 2000 Chrysler Cirrus
My fiance purchased a pair of P1 RF speakers and their matching amplifier. when he hooked them up in our car everything worked well. we unhooked everything and then ran all the wires and re-hooked...
well let me see i can bet something happened so what happened??? i bet the amp is not working right? hahaha here's my sign right!!! all right enough fun. is the light on the amp coming on? you might also need to turn the key all the way to the run position, if not wired exactly right then amp will only power up when vehicle is running or key is in the run position i need to know this before we really go any further. let me know so i can get you up and running quickly.
Mar 07, 2009 | Rockford Fosgate Car Audio & Video
Rear door speakers don't work w/ aftermarket radio in 94 suburban
You need to attach the blue wire on the stereo harness to the blue and white wire on the car adapter harness. they installed a small amplifier to power the rear door speakers and unless you connect those two wires then the speakers will not work.
Jan 05, 2009 | 1994 Chevrolet Suburban
Amp protection
Does it go into protect if you disconnect the speaker wires from the speaker terminals of the amp?
Feb 16, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp help
it might not be the amp that is not working it could be the sub or sub's. Try takeing a sub out of the box and look down the hole in the center of the magnet on the back of the sub and look and see if you can see any wire's or any thing that has come unwound in the sub and if you do see wire's then you have blown your sub. If you dont see any wires then you could completly disconect your amp for 20 to 25 minutes and then plug it back in and see if that fix's your problem. If none of this works then you can take your amp to an audio store and have them test the circut board in your amp.
Dec 22, 2006 | Sony Xplod XM-1652Z Car Audio Amplifier
Infinity Reference 7541a Car Audio Amplifier Logo
160 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
