Question about HP Computers & Internet
Laptop power cord reset
Power cord fairly new...wont turn on now and the power box from cord has a high pitched beeping
    Scholar:
  • 106 Answers
The surge protector that is sometimes included in the power supplies for laptops will emit sound when they have failed. it is also possible that there is a building power fault (ground not connected).
what model is the adapter? it would help a lot. also, which laptop is it?
Posted on Feb 17, 2012
2 Suggested Answers
  • 5 Answers
SOURCE: power BOX supply cord problem or hardrive problem?
Check these settings first. In a clear spot on the screen where no icons are, right click and go to properties, box opens and at top should list from R to L, themes-desktop-screensaver-appearance-advanced. click on screensaver, close to bottom click on power, another box should open, click on power schemes, make sure it's set to portable/laptop, and at bottom make sure settings for plugged in are are set to never. If it's not that then you have a bad power supply cord, or a bad power supply unit in laptop. If it's new and under warranty take it in and have replaced if not warrantied then will cost you about 100-150, just a guess!! hope this helps. But it sounds like the supply cord making the beeping noise might be bad. Make sure it's plugged all the way in as well.
Posted on Nov 17, 2008
Computer wont turn on
Are you sure you have power at the outlet you are using?
Do you have a VOM so you can check the output of the power cord? If you are getting power to the laptop it should provide something, either BIOS beeps or a flicker of the screen or the indicator lights should at least flash. Do you get a power available or a charge indication?
Dec 01, 2014 | Computers & Internet
Alarm beeps and orange light flashes when power is switched on.
If you unplug the power cord from the wall and the PSU, then flick the little red voltage switch on the back up and then back down again, plug it back in and it should work again
Feb 15, 2014 | HP Pavilion Computers & Internet
High pitched noise/beep on emachine e440 laptop
In Windows 7 ,Try the Power Options in Control Panel. Set to High Performance, select Change Plan settings, set Sleep to never, select Advanced Power settings, scroll through the Advanced Power settings, set Sleep and Hibernate to Never and Power Buttons and Lid to Shut down. Always shut down and unplug the Laptop when not in use to prevent damage due to a power surge and a possible Fire hazard IF the battery malfunctions. Not to mention unnecessary wear on the components.
Apr 16, 2013 | eMachines Computers & Internet
Tv wont stop beeping every time i turn it on. It is a very high pitch beeping that doesn't stop. I have tried plugging the tv in several different plugs by itself but the beeping still didn't stop.
Ur High Voltage is dead.The FBT the flyback transformer is dead.The big block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced the FBT get power back.
Jan 19, 2010 | Televison & Video
My new Acer P191W LCD Monitor has a high pitched whine that is extra loud on pages with rich and dark colors.
The PSU "power supply unit is taken on a lot of noise from the outlet. Can you tell us if you have it streight plugged into to a 120V AC outlet or is it plugged into a strip? The Solution for both is NEW strip i recommend APC or plug it into a strip and check the outlet and make sure its properly grounded this should shore up this problem or the unit itself is going out.
Apr 24, 2009 | Acer P191WBD LCD Monitor
Power pack beeping, no lights turning on
Unfortunately your laptop is suffering from hardware failure. You may try removing the battery and using only the power cord.If this solves the problem then you either have a defective battery or bad power circuitry on your laptop. Aside from that if its still under warranty sending it to Toshiba for repairs will be your safest and cheapest option.
Apr 16, 2009 | Computers & Internet
Continuous Beep
i had the same problem this morning and i press a pin into the reset button hole thing at the back. then turn it on and it'll work
Dec 03, 2008 | Samsung YP-T10 Digital Media Player
Alesis M1-Active left speaker emitts a very high pitched wine that sounds like feedback
have your built-in amp checked for trouble. there should be trouble in the output stage feedback loop. this is something to be done by a repair technician
Apr 11, 2008 | Alesis M1-Active MkII Main / Stereo...
High pitched whine
I have the same problem. Replaced the module and still a continous beep....
Dec 28, 2007 | GE 24 in. Profile PDW9880JSS Built-in...
Computers & Internet Logo
46 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
