Question about Sony MHC-GX450 CD Shelf System
Cooling Fan Question
Does the fan on this unit run continuously or only when it gets hot?
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: SONY VGNFJ270 LAPTOP BECOMES HOT AND GIVES LOT OF NOISE
If the fan is noisy and the laptop is running hot, then most likely the fan is faulty and spinning slowly. Therefore the fan is not providing sufficent air flow to cool the laptop's CPU. The fan needs to be replaced and possibly the heatsink assembly needs cleaned to remove dust buildup.
Posted on Jun 25, 2009
When I turn the engine off the engine cooling fan stays on and does not shut off
depending on the engine temperature the fan is supposed to remain on after you turn the engine off, until the engine reaches a preset cooler temperature. when it reaches cooler temperature usually within 5 minutes or so it should cut off... if you cut it off and it is running 30 minutes later.. then there is a problem with the fan relay or temperature sending unit.
Sep 28, 2015 | 2009 Dodge Grand Caravan
How do i get my condenser fan to stop running. it is cooling fine but won't shut off unless i shut it off.
Are you sure its the condenser fan? The fan is attached to the compressor power and wont run unless the compressor is running. On the other hand the fans inside the cooler will run 24/7 and are designed for continuous duty. If someone has worked on the compressor wiring you may have to re establish the wiring following the wiring diagram. I have seen condenser fans wired in hot areas to run continuously to attempt to cool down a hot compressor or compensate for a worn out or damaged condenser that doesn't get rid of the heat from the system. If that is the case a new condensing unit is probably in your future. Hope this helps good luck.
Oct 09, 2014 | True GDM-47 Refrigerator Merchandiser -...
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
My r1 2009 is getting hot when im idle or in the stop light
1. make sure that the coolant is at the correct level.
2. when it is running hot the cooling fan(s) should be running or it will get hot. If the fan(s) are not running check the fan switch, fan relay, and the fan for correct operation. The fan switch should have continuity once engine is about 195+. The relay should click taken out of the system and 12 volts is applied to the smaller two relay terminal; at the same time it clicks, the larger two relay terminals should have continuity. Unplug the fan at the connector and apply 12 volts dc to fan side of the connector and the fan should turn on.
Jan 22, 2013 | Yamaha YZF-R1 Motorcycles
Running very hot and shutting down
You are running into a CPU overheat issue.
1. can you feel or hear the cooling fan come on at all? If so try and use compressed air can to clean it out.. they get tremendously dirty. You can also try a vacuum hose, but cover nozzle with hand and only hold next to cooling fan outlet and nowehre else with laptop off and unplugged. Dont get near keys or other parts as will damage. Dont use SHOP VAC either.
2. If Cooling fan is NOT Coming on you can try a laptop cooling pad. these are external units by Targus and other companies that have cooling fans to supplement a laptop units cooling fan. You can try this to see if airflow is your problem.
3. If you recently ran encryption software, a new antivirus program, or upgraded to Windows 7 it is possible that your culprit is the unit is not cycling. Meaning the hard drive is continuously being accessed and the CPU is in constant service... this can cause overheating as well.
Jun 02, 2010 | Toshiba Satellite A135-S2276 Notebook
My coolant light continues to come on after I replaced recommended coolane and my car runs hot after driving 5-10 min.. What does this mean? 1998 Chevy Cavalair
check fuse ,wiring ,and connections ,check for proper fan operation,clogged radiator ,water pump and belt and for possible bad sensor
Nov 16, 2009 | 1998 Chevrolet Cavalier
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Where is the fuse or relay for the cooling fan in
You have to refer to your owners manual or an after market service manual for fuse locations but that is not the issue. There is a sending unit screwed into the block with a temp sensor that closes the circuit on the ground side when the cooling system reaches a specified temperature. There is a fuse between the hot side and the fan for over current protection (see manual). A bad sending unit is most likely the culprit. Measure the resistance or continuity when the engine is hot from the sending unit body which is grounded to the block, and the output terminal or black wire running to the fan motor. It should be closed or read less than 0.5 Ohms. If it is open or very high resistance replace it. Good luck to you. I hope thishelps
Jul 26, 2009 | Pontiac Grand Am Cars & Trucks
The a/c unit cooling fan shuts down shortly after unit kicks on.
If a fan motor quits working during a cycle it usually means that the thermal protector is turning it off. If you had an amp meter on it, you would notice that it is exceeding the listing on the nameplate, Nine times out of ten this is irreversable, the motor needs to be changed. Sometimes if there are oil ports on the motor, you can add a few drops of zoom spout oil and that does the trick. But usually the motor is already damaged. Good luck.
Jul 11, 2009 | Carrier 38CKC036 Air Conditioner
Sony MHC-GX450 CD Shelf System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
