Question about Starrett Jobbers Drill Gage Gauge No. 187 1/16"-1/2
How to use?
How to use of jobber drill gauge? when need to check?
  • 425 Answers
It is used to check either the size of a drill bit or to see what size fastener you have and decide what size bit to use. Just insert a bit or fastener into a hole. It should fit snugly and if it doesn't fit the next smaller sized hole then you now know what size you have.
Posted on Mar 07, 2012
What type catalytic converter do I need and approx cost for repair.
Your vehicle has 2 catalytic convertors. The replacement used should be one made expressly for your vehicle. Cahoots told you that a convertor is defective? You may only need an O2 sensor.
Apr 03, 2015 | 1999 Cadillac Seville STS
How to get my ignition lock out
Instructions
Test fit a drill bit in the lock cylinder. You want a bit that is just smaller than the cylinder. You will be using hardened drill bits to cut through the cylinder, since ordinary bits may be damaged by drilling metal.
Lock the drill bit into the drill chuck and tighten the chuck.
production in very fast delivery! special threading taps, plug gauge
Drill a starter groove into the lock cylinder. Start the drill on a low speed and create a groove in the end of the lock cylinder. You don't need to create a deep hole, just enough of a groove so that the drill bit will not slip on a higher speed.
Increase the drill speed to the highest setting and drill out the lock cylinder. Let the drill do the work. If you force the drill into the lock cylinder, you could burn out the rotor inside the drill motor
Jul 10, 2012 | 1999 Pontiac Sunfire
Just purchased a bostitch air compressor and three air guns , i am having trouble with the sb 1850 , will not shoot nails and lack of power
First, check all the air connections to see if there is anything that prevents the air to flow (pieces of cadrboard, packking chips or seals that need to be broken)
Check also if there is any manual valve and also if the quick connects are not entirely plugged in.
Dec 31, 2010 | Stanley Bostitch HP118K 23 Gauge Headless...
Original oil plug came out
there are thread repair kits made for drain plugs that have the oil pan threads stripped. go to napa auto parts or a jobber that retails to the profesionals and ask them for the kit
Aug 02, 2010 | 2001 Hyundai Elantra
How do I get it to work. It is loaded with staples but I cannot make it work. Would it be locked>
check the safety actuation mechanism. If that doesn't work, the feed and staple receiver are damaged.
Dec 20, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
I am trying to fill a pillow for my above ground pool-can't figure out how to use my bostitch air compressor
Plug the compressor in, turn on the start switch, one gauge reads the tank pressure, the other gauge indicates the pressure in the air hose. The dial adjusts the pressure to the air hose.
Nov 05, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
Shooting two nails instead of one
i would double check the plunger to make sure its resetting after each fire.
Oct 30, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
Starrett Jobbers Drill Gage Gauge No. 187 1/16"-1/2 Logo
89 people viewed this question
Top Starrett Drills Experts
Are you a Starrett Drill Expert? Answer questions, earn points and help others
