Question about ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Power on just get continious two second beeps
Trying to boot but as soon as I start the PC I get a two second beep one second pause two second beep one second pause that just continues and continues
  • justin8034
    justin8034 Feb 17, 2012
    I reset cmos even shorted on the #1 and #2 like the manual said to do graphics card works in other computer Wierd thing I do not see the 4 pin connector nor can i find it in the manual been at this for about 2 hours now (<3 asus but im just not getting this one
    Scholar:
  • 106 Answers
Sounds like not enough power. have another look at the board, the 4 pin connector should be near the I/O shield near the top of the board, just above or beside the CPU. sometimes it is on the edge of the motherboard (so the plug pins are parallel with the board surface)
Posted on Feb 17, 2012
SOURCE: pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Posted on Sep 12, 2008
ginko
  • 19396 Answers
SOURCE: my computer does'nt boot
One long and 3 shorts beep on Asus Motherboard is video error, either the video adapter is malfunctioning, or the video card is not well plugged int its PCI or AVG slot.
If video adapter is built in motherboard you need to buy an external video adapter, or to replace the motherboard.
If video card is an external one, must be taken aout and placed back to test it, if it is faulty replace it.
Posted on Jan 20, 2009
preachw996
  • 1179 Answers
SOURCE: My pc doesn't boot anymore.
This code usually refers to a Video card or RAM issue. Try reseating both the video card and then RAM to see if it fixes the problem. If not then try removing the video card and rebooting. If the system starts without the beeps then you'll know the video card is bad and you can replace it. If it still beeps then try removing the RAM one stick at a time, rebooting after each removal. When it boots you'll have the bad RAM stick isolated and can replace. Hope this helps.
Posted on Oct 11, 2009
colliewob
  • 781 Answers
SOURCE: beep
have you recently fitted new hard ware to *********** board if so remove it and replace with old one.
especially video card and memory
What the beeps mean is that something is not correct on the board
and is telling you before further trouble
Posted on Jul 30, 2008
grantg1983
  • 218 Answers
SOURCE: continious beeping
sounds to me if the beeping is like that its the ram but it could be a bad board try the ram first
Posted on Jul 12, 2010
Computer won't start, solid amber light, no fans, no keyboard, nothing. There is power to monitor and modem. What's wrong and how can I fix it?
That my Friend is the Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, during a power outage with no surge protected, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Sep 21, 2010 | Dell Inspiron 530 Desktop Computer
Continious beeping
Jul 12, 2010 | ASUS P5PE-VM Motherboard
Sony vaio athlon 2800+ started beeping,one long beep lights flash
listen carefully to the beeps
One Long Beep, One Short Beep= motherboard problems.
One Long Beep, 2 Short Beep= video problems.
One Long Beep, 3 Short Beep= video problems.
Repeated long beeps = memory failure
continious long and short beeps = Cpu overheating
hope this helps
Jan 24, 2009 | Computers & Internet
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
Booting up
one light is for hardrive activity , the other is to show the power is on.. the flashing one is most likely the power light as most computers will tell you when thier ill....the beeping is an error code and should be in some pattern EG: Power LED blinks red twice, once a second, followed by a two second pause. Or something like that. Take note of the pattern and repost it here, then we can give you a specific area to look at.
Sep 16, 2008 | HP Compaq d530c PC Desktop
PC won't Boot Up
Here is what is says in the owners manual in what to do in this case, Hope this is a Help, Happy Holidays
Red Power LED
flashes five times,
once every second,
followed by a two
second pause.
5 Pre-video memory
error.
1. Reseat DIMMs. Power on the
system.
2. Replace DIMMs one at a time to
isolate the faulty module.
3. Replace third-party memory with
HP memory.
4. Replace the system board.
Red Power LED
flashes six times,
once every second,
followed by a two
second pause.
6 Pre-video graphics
error.
For systems with a graphics card:
1. Reseat the graphics card. Power on
If you need anymore let me know and I will post them for you.
Dec 15, 2007 | HP Compaq dc5100 PC Desktop
ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard Logo
75 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
