Question about Frigidaire GLEQ2152ES Electric Dryer
Stops working and gives error code 68 - Frigidaire GLEQ2152ES Electric Dryer
2 Suggested Answers
praky16
  • 744 Answers
SOURCE: error code e-68
hi..
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.
thank u
rate me!!
Posted on Jul 15, 2009
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
Avanti AT 380 gets an error code 68
556a61de-db92-4886-91ce-2e6c36b807f6.gifyou must LUBE the deck belt, front rollers and rear. This happen because the electronic system , shut down for to protect the system.
see the video and proceed according. See the diagram for REED switch clean it, test for open or faulty, tight the connector very well.
God bless you
Jun 16, 2013 | Avanti Fitness AT380 Treadmill
What is code F1 mean on the Whilrpool Cabrio. The washer stops about 5 seconds when I first put it on.
Ok the Cabrios have alot of problems. In your owners manual there is a big page where it gives you errors codes and what to do it also givees you a diagnostic feature which helps determine the problem. This site gives you the fault codes and what to replace. F1 means primary control failure. Also sometimes when the control board is bad something else could also be wrong. Good Luck
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies. F1 (F60-68)
See Accessing & Removing the Electronic Assemblies.http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Jun 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Hi any idea what causes this Brivis error. err
go to the brivis web page and type in serial number and error code theywill give you a code and repair instructions.adrian,,,,
Jun 29, 2010 | Heating & Cooling
ERROR CODE 68 WILL NOT CANCEL. IF YOU PRESS CANCEL AND THEN START IT RUNS FOR ABOUT A MINUTE AND STOPS
code 68 [aeq7000es series]relates to "stuck buttons, or control panel issues. Try to see if your dryer will give you the code for which button is stuck and try to wiggle it to free it up if stuck. If all buttons check out good then you most likely have a bad control panel ,and its time to find your best deal on one
Sep 29, 2009 | Frigidaire AEQ7000ES Dryer
Fridgidaire Error 68 (model No. LE02152EEO) and constant beeping!
this fault code means there is a stuck key on the control board.you need to disassemble the display panel and free up the stuck key if this does not work then the display panel and or control board need to be replaced
Sep 02, 2009 | Frigidaire AEQ6000ES Electric Dryer
Error code e-68 won't clear the message. Dryer stops working
hi..
thank u
rate me!!
Jul 15, 2009 | Frigidaire Dryers
System error 1 light code E 68
error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
Aug 24, 2008 | Microsoft Xbox 360 Console
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
May 04, 2008 | Frigidaire Affinity ATF7000E Front Load...
F68 error
The F1 code(60-68) means primary control failure. The treatment for this problem is to replace the primary control panel. It is very easy to replace. Here is my story, I had the F50 code appear and my machine would not drain or spin a load of clothes. My machine was only 7 months old thus still under warranty. I called for service and they came in 2 days, I watched as the repairman popped the top of the machine up. He used a screwdriver that he placed in the crevice on the front of the machine, just below the lid. Inside the machine, he pulled out a book. I asked if he took that out of my machine, he hesitantly said "yes" and then told me that every machine has a service book in it. It has a list of codes and gives the serviceman step by step instructions. He ordered parts and rescheduled another service date. Well the service date was this morning, however I had not yet received the parts for the repair. This made me very upset that I once again had to schedule another date a week later. OK, mind you I have not done laundry in 2 1/2 weeks. The part came tonight and I took it upon myself to fix the damn machine myself because I am stubborn like that. IT WORKS!!!!!!!!!! Who needs a repairman, my husband thought I was joking that I was going to fix it myself. Good Luck!!!
Oct 29, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Frigidaire GLEQ2152ES Electric Dryer Logo
35 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
