Question about Panasonic Lumix DMC-FZ3 Digital Camera
Camera says "Memory Card Full" when it's empty
My camera says "Memory Card Full" every time I try to take a picture, even though I have completely emptied all of my pictures onto my computer! When I go to the view/preview mode (the green arrow on the rotating dial), it says "no valid image to play." It is a 256mb card. I also tried my 8mb card to see if the card itself was defective, but had the same problem with the 8mb card. The battery is fully charged. What's up? Thanks, Fiona
  • Anonymous Apr 22, 2009
    I have a CANON POWERSHOT SD1000.
    It says "MEMORY CARD FULL" with any memory card and even without one. There are no pix on the internal memory.
  • Brett Duxbury
    Brett Duxbury Jun 26, 2017
    Fiona check the recycle bin on your computer with the camera plugged in or the memory card plugged in. The files may be deleted but still on the memory card via the recycle bin or trash bin (apple type systems)
ginko
  • 19396 Answers
SOURCE: viewing pictures on camera
When you rotated pictures you changed picture size and definition, that is the reason why camera does not display them again.
If you check file size, you will see that rotated pictures are smaller than regular ones.
There is no way to get picture to original definition once you reduce it, however if you use a program like Photoshop you can check size and definition on original pictures, and re-rotate and resize rotated pictures to send them back to the camera, quality will be poorer than originals. Attributes to check are length and width (preferably in pixels) and definition, then you save pictures as best quality.
Posted on Aug 10, 2008
  • 11967 Answers
SOURCE: I have a Lumix DMC-FS3 camera and if I don't put a
First of all, forget about using the built-in memory...it's very small. Does your camera work properly when a memory card is inserted? You could also go into the setup menu to "reset". That would set your camera back to factory defaults.
Posted on Aug 30, 2009
Testimonial: "Thank you for quick reliable service!"
  • 11967 Answers
SOURCE: cannot download all of pictures onto pc.
First of all, you should forget about using the internal memory...it just causes problems (as you can readily see). Always use a memory card. If any of the pics on your camera are important, you should download them to your computer before continuing. Then, go into the menu and find "reset"...follow the on-screen instructions. Then, with the card out of the camera, go into the menu and find "format"...follow the on-screen instructions. Then insert a blank memory card and go into the menu and find "format" again...follow the on-screen instructions. From this point on, your life will be wonderful.
Posted on Feb 02, 2010
Testimonial: "I will try your suggestions and meanwhile I will get back to the ranch, thanksamillion."
  • 11967 Answers
SOURCE: i have an sd card
With no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory.
Posted on Dec 27, 2010
  • 11967 Answers
SOURCE: I have photos on the
Go into the menu and find "copy"...from there, you can copy the internal memory to a memory card.
Posted on Feb 03, 2011
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
SD Card Problems with Vivitar Vivicam 5118!
What size is the memory card. If it's larger than 4GB then it won't work in the 5118.
Try using another card. Don't format it in your computer but do format it in the camera before trying to take pictures.
May 05, 2012 | Vivitar ViviCam Cameras
When i try to use my camera on my phone it says that my memory is full even though its empty.
To resolve this problem:-Turn off the camera and insert a new memory card.
-Transfer or delete pictures from the memory card.
-Change the storage location to use the internal memory.
Apr 21, 2011 | Cameras
It says that my "Memory Card is full" even though
1. Make sure you are saving all your images to what is called the "external" memory, not the tiny internal memory.
2. Format your memory card using the format feature on your camera.
Mar 08, 2011 | Panasonic Lumix DMC-FX12 Digital Camera
Camera doesn't access the memory card. Used it til it was full then emptied it and it won't load pictures to card now. Tried format but still no luck.
If you have even one picture on the camera's internal memory, it can prevent the memory card from working. You should try formatting the camera with no card in the camera to erase anything on the internal memory.
Dec 14, 2010 | Samsung BL103 Digital Camera
CAMERA SAYS INTERNAL MEMORY FULL. I PUT NEW CARD IN. STILL SAYS INTERNAL MEMORY FULL
The internal memory is the memory built into the camera, not the memory you put in with a memory card. This internal memory is rather small. If it is completely full, it will stop your camera working even with an empty memory card.
Take the card out of the camera, and delete some of the photos on the internal memory before you put it back in.
Nov 25, 2010 | Kodak Easyshare C190 12MP Digital Camera...
How do i empty my memory coming up memory full even though only 6 pictures on
the camera is meant to be used with a SD memory card - the internal memory is very small and probably will only hold 5-10 pictures. empty it just by deleting the pictures. memory cards are cheap and available everywhere. good luck!
Jun 20, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Memory card is always full even though it is new
Hi, The solution is to format the memory card or initialize the memory card. Note formatting the memory card will delete all the pictures or data stored. Formatting memory card
1. Press the MENU button in any mode.
2. Move the 5-way scroll button to the right and press the confirm button to enter the SETUP menu.
3. Move the 5-way scroll button down and enter the FORMAT menu. Press the confirm button and the "Format?" dialog box appears. Select "Yes" to start formatting. Select "No" to cancel.
Apr 12, 2010 | DXG Technology DXG-409 Digital Camera
'Card full' with no pix??
First make sure that the camera is able to recognise the card and is not defaulting to the internal memory only. Power off the Camera, then remove the additional card. Power on the camera, then power off the camera. Put the memory card back in the camera and then reformat it before using it. Fuji and other digital cameras do not like being used with memory expansions if they are not reformatted every time the pictures have filled the memory card or you choose to download them. Its like the memory is still allocated to something even though you cant see it. So a good practice is to reformat after every download. If the problem persists then try another card and if this still gives an error then you will have to get the camera serviced.
Oct 13, 2009 | Fuji FinePix S5200 / S5600 Digital Camera
Panasonic Lumix DMC-FZ3 Digital Camera Logo
167 people viewed this question
Top Panasonic Cameras Experts
skyblue007
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
