Question about Motorola Mobility Defy Cell Phone
Motorola Defy can use it without a sim card for just wi-fi?
How can you start the Motorola Defy without a sim card? It powers on, but you can't get past the first screen.
Tablet froze up and can't open up do I need a SIM card?
try holding in power button for up to a minute to force tablet to power down and then try powering it up again. Do you need a sim card depends if Tablet accesses mobile data from the mobile phone network. Some tablets only have Wi-Fi and would need a Wi FI network or WI FI mobile phone router device setup to work together in tandem.
Aug 29, 2014 | Tablets & eReaders
Connecting my motorola defy to wifi router
Go to 'Menu > Settings > Wireless & networks > Wi-Fi settings', and, if the 'Wi-Fi' checkbox is unticked, tick it. After a little while, a list of available networks will be shown. If you want to refresh that list, tap 'Menu > Scan'. Anyway, if the network you want to connect to is in the list, tap over it and tap 'Connect'. You will be prompted to fill in the passphrase (if any). Otherwise, i.e. your network is not shown (e.g. it is hidden), tap 'Add Wi-Fi network', fill in its name, under 'Network SSID', the security encryption method, and the password (if any). Then, tap 'Save'. You can also specify your Wi-Fi sleep policy and other settings, by tapping 'Menu > Advanced'. After you finish, tap 'Menu > Save'. Again, press the back button as many times you need to go back to where you were before.
By the way, if your phone's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can help you out any further.
Regards, Carlos
Oct 08, 2011 | Motorola Mobility Defy Cell Phone
I dont seem to have internet access i did 4-5 days back but now nothing Its a Motorola Defy I must have dissabled it unintentionally....
If you mean you want to access the internet through your mobile data plan, go to 'Menu > Settings > Wireless & networks > Mobile networks > Access point names', and make sure your carrier's data plan name is shown there. If so, tap over it and change the data, mainly 'APN', 'Username' and 'Passowrd', according to your carrier's instructions. Otherwise, i.e. if there is no data plan shown at all, tap 'Menu > New APN', and fill in the required data. In both cases, after you finish, press 'Menu > Save'. Then, press the back button as many times as required to take you where you were, before you started changing these settings.
On the other hand, if your intention is to access the internet through your phone's Wi-Fi card, go to 'Menu > Settings > Wireless & networks > Wi-Fi settings', and, if the 'Wi-Fi' checkbox is unticked, tick it. After a little while, a list of available networks will be shown. If you want to refresh that list, tap 'Menu > Scan'. Anyway, if the network you want to connect to is in the list, tap over it and tap 'Connect'. You will be prompted to fill in the passphrase (if any). Otherwise, i.e. your network is not shown (e.g. it is hidden), tap 'Add Wi-Fi network', fill in its name, under 'Network SSID', the security encryption method, and the password (if any). Then, tap 'Save'. You can also specify your Wi-Fi sleep policy and other settings, by tapping 'Menu > Advanced'. After you finish, tap 'Menu > Save'. Again, press the back button as many times you need to go back to where you were before.
Regards, Carlos
Jun 11, 2011 | Motorola Mobility Defy Cell Phone
I want to unlock my motorola defy can u send the unlock code
Sorry i don't have the Unlock code with me.Also no one provide the Unlock code for Your It's differ from Network to Network ,IMEI number and Country it locked Now...You can get the Unlock code at low cost from the website Named as Superunlockcodes.com and remove the Network Lock,If it asks for Security Unlock code means call the service provider and get it,Subsidy Code and Unlock code is Same,SPECIAL CODE is also same in Motorola Category,Motorola has Unlimited Unlocking tries,,Follow the Free unlocking instructions below :
Motorola DEFY Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola DEFY mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola DEFY mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola DEFY with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola DEFY is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola DEFY ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Each Motorola DEFY mobile phone has an unique unlock code. You can buy the unique unlock code for your Motorola DEFY mobile phone using the form above.
May 25, 2011 | Motorola Mobility Defy Cell Phone
My Motorola Defy will not hold a charge. Had full charge at 8:00 Am and by 2:00 PM battery was dead. No apps running or Wi-FI on. Second day in row this has happened
The DEFY is feature-rich and can run a virtually limitless number of applications, making it useful for many tasks. Your particular usage will affect how long you can go before recharging your battery. Playing games, running applications, and surfing the Web increase the power use of the computer-like functions of the DEFY Calling and texting utilize its phone functions. Depending on your use mix, time between charges will vary. We know you want to use the device to its fullest and offer you these tips to help you get the most from your phone while going as long as possible between charges.
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tip: It may take several charging cycles for your battery to reach optimum performance.
The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
Tips to extend battery life:
  • During initial set up of your MOTOBLUR account, your phone's battery may drain faster than usual due to the amount of data transferred. After the initial sync, and a few charging cycles, your battery will reach its maximum capacity.
  • We strongly recommend to keep the phone attached to the charger during the MOTOBLUR initial sync.
  • When not transmitting a lot of data or surfing the Web, set your device to connect to 2G network.
  • When setting the phone down after use, quickly press the power key to invoke a blank screen. Selecting a shorter back light duration will also help conserve power by blanking the screen when not in use.
  • Lower the display brightness.
  • Use the AC adapter to charge your phone whenever possible.
  • Toggle Bluetooth, Wi-Fi, and GPS on or off as needed. There are some apps that can help do this easily. While we do not endorse or guarantee these solutions, or provide support for them, some owners have reported success using an application called "Battery Widget " which can be downloaded from Android market.
  • Ensure applications are closed when not in use.
  • Clear all notifications from the notification bar as much as possible. Click Here to learn more about notifications.
  • We suggest charging each night so you start the day fully charged and ready to go!
Motorola DEFY Battery Manager - Benefits
A feature called Battery Manager is now part of the DEFY software
  • It provides options for significant battery savings by reducing data traffic when not needed, and by dimming screen when battery is low.
  • Two optional settings:
Data Timeout
· With this feature: After a period of inactivity, background data updates stop until the user starts using the device again.
· Without this feature: background data is constantly updated (Email, Social Networking, News Feeds, etc.), even overnight.
Auto Brightness
· When Battery Level gets low, screen automatically dims.
Battery Manager: How To Use It
To access battery manager
  1. From the home screen press the menu key
  2. Tap settings
  3. Tap battery manager
Three Modes are available:
  1. Performance Mode (default) - Data Timeout and Auto Brightness are OFF
  2. Smart Mode - Data Timeout and Auto Brightness are ON with different settings during Peak and Off-Peak times of day. User can change various settings.
  3. Battery Saver Mode - Data Timeout and Auto Brightness are ON with settings to maximize battery savings. User cannot change the setting
May 24, 2011 | Motorola Mobility Defy Cell Phone
How do i turn off internet on Motorolla Defy?
Hello Tony,
To turn off Wi-Fi power: Touch Menu > Settings >Wireless & networks > Wi-Fi.
Note : Turn off Wi-Fi power to extendbattery life or stop connections. Turn it off and on to search for networks.To add a quick switch, touch and hold a blank spot on your home screen, then touch Motorola widgets > WiFi toggle.
May 08, 2011 | Motorola Mobility Defy Cell Phone
Wifi is set up, how do I connect to it without going on line via vodafone? Thanks
When you are connected to an Wi-Fi network, internet data should flow through it, instead of your carrier's data plan. You can verify this behaviour looking at the notification bar: the Wi-Fi icon (blue bars) is in the positition usually reserved for the mobile network one (G, E, 3G, H), and not side by side with it. To be sure that your carrier's data plan won't be used, go to 'Menu > Settings > Data manager > Data delivery' and untick 'Data enabled'.
Hope it works for you.
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Apr 27, 2011 | Motorola Mobility Defy Cell Phone
I need an unlock code for my defy
Hi, are you know how to unlock a mobile device? I think you didn't know, since you must give specific data before get Motorola Defy Unlock Code, like your IMEI phones, your mobile service provider. The easy way to get Motorola Unlock Code is buying from online unlock code seller, it will not time to much.
Apr 13, 2011 | Motorola Mobility Defy Cell Phone
How do i transfer my phonebook contents over to my motorola defy?
copy them all on the Sim card ...and after that insert the Sim card in the phone ..and copy them in the other phone's memory ..or ..sync the first one with your computer 's phone book ..then connect the second phone ..and sync again ..and all the data from the computer's newly updated phone book ..will be synced with the Motorola..
Mar 16, 2011 | Motorola Mobility Defy Cell Phone
Motorola Mobility Defy Cell Phone Logo
701 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
