EF fault code on a swt605sa - Washing Machines
EF ford fault code 289776 can someone please tell me what it is?
Ford fault codes start with a P then a 4 digit number
Mar 31, 2015 | Ford Cars & Trucks
Temp display on door is giving wrong display
this is a fault code.. take a picture of the panel and post it here also picture of the model and serial tag.....I can find the fault codes with the info asked for............ ken
Sep 30, 2014 | Refrigerators
WHAT IS ERROR EEF
E.EF = External Fault.
E.EF is a programmable error triggered by user programmed conditions. This can be triggered by a digital input or a software input which is programmed as E.EF.
Most F5 inverters have "I3" (terminal #12) programmed as External fault. If a 24Vdc signal is applied to this terminal the unit will trip into E.EF. *This is programmable and may not be the functionality of a programmed inverter.
Jul 17, 2014 | Inverter KEB COMBIVERT F5
Electrolux fault codes
on a electrolux fghb2844lf6 fridge I have afault code of sy ef
Jul 24, 2012 | Electrolux Refrigerators
I have an error code "EF" for my Electrolux
Generally, EF error is showed with an additional number on your display... EF 1, EF 2, EF 3, EF 5, EF8, or EBF.
Each error code will depict a different cause and solution. Out of these solutions, the most common is the control board and possibly the UIB (User Interface Board), or too higher mains voltage coming into the house, causing damage in this UIB device.
Test and check voltage, if this isnt solve it, relace UIB device.
Hope this helps.
Mar 05, 2012 | Electrolux EW1200i Front Load Washer /...
Fault code EF electrolux EWT806 what is the problem
So we just fixed our EWT806 after it suffering the dreaded EF fault... The problem... Too higher mains voltage coming into the house! Albiet within specification from the supplier, the Electrolux EWT806 doesn't like anything around 250 volts! Obviously a poor design on the control board which is unable to accept a wide supply voltage!
Solution, isolation transformer inline with the machine. Now it runs like a dream!
Jul 31, 2011 | Electrolux Washing Machines
Fault code EF is flashing on my Electrolux fridge FSC23R5DSB6. What does this code mean?
EF on the Electrolux refrigerator digital display means "evaporator fan."
The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Turn the power off on the digital display and carefully unplug the refrigerator from the power source. Leave the refrigerator unplugged for three to five minutes. Plug the refrigerator back in and give the refrigerator a few minutes then turn the power button back on. Press the default button on the display and see if the EF code goes away.
Electrolux recommends that you do not plug the refrigerator into an outlet that has a reset button. If your refrigerator is plugged into one of these outlets, try plugging it into another outlet and see if the refrigerator resets itself.
Hope this helps.
Jul 21, 2011 | Refrigerators
What does "Sy EF" mean on dispenser led?
Error Code SY EF is the System Evaporator Fault.
This usually means there is NOT enough air flow over the sensor, this can mean a faulty sensor, or fan.
Above is the latest service sheet to do with your machine, you need to check this.
Hope this helps (remember to rate and commnent this)..
Jun 03, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Code for501a area
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 30/11/2008
PROVIDER CODE: 5C 01
KEY 00 = 2F 1E 90 1B EA 7F A0 26
KEY 01 = 60 1F 48 73 19 D6 CA 99
TELEWEST KEYS -- KEYROLL 30/11/2008
PROVIDER CODE: 5A 01
KEY 00 = 3F 32 37 03 D0 73 84 84
KEY 01 = C6 64 1D EF 47 5A 0E EF
PURE NTL KEYS (UK) -- KEYROLL 30/11/2008
PROVIDER CODE: 54 01
KEY 00 = 5A 35 D6 3B 4D A0 75 EC
KEY 01 = 28 98 21 38 22 BC B9 EF
IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
PROVIDER CODE: 5E 01
KEY 00 = 51 0F 32 A7 D9 34 BE 3E
KEY 01 = 8D A3 88 1B 4E 32 C5 8F
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview codes 30 nov please telepest
codes for 30th nov 2008
00= B7 19 92 E2 9B 15 AF 06
01= C6 64 1D EF 47 5A 0E EF
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
