By mistake I had installed my software upgradtion CD in my DAV DZ100 home theater and its started running automatically the CD and started upgrading and Copying the files to my player and meanwhile, I have ejected the CD during this process and after that my player stopped working...Even I can't able to Eject the DVD ot insert the DVD..nothing works only I see that its showing message reading............
Can you please help me, how to sort this out ?
Regards
Comments:
Oct 26, 2008
- Hi Welcomejee
Many Thanks for your reply, but when I am inserting the CD manually, still its showing reading on display but nothing goes further....and I don't know which is the digital process board ad what is ROM board and how much it costs to me...
Is here anyway, I can reset the player to factory setting...
Your help is much appreciated...
Regards
Oct 26, 2008
- Hi..
Do you sell this boards ? How much the cost for the same ?
Regards
Oct 27, 2008
- Hi
I live in UK.
Thanks / Regards,
Oct 27, 2008
- Dear welcomjee,
In UK where can I find the digital process board and how much is the price ?
Regards
Oct 29, 2008
- Can I repaired it in India ? As to repair the same in UK is much expensive then India...I can't find the parts here in UK...you know any sources ?
-   i put the cd with upgrade for playing dvix with the ha9_ec85.bin and system told me to push play for update, i do it and system say upgrating, after 1 minute drive open and cd was out and i stop system as i thougt that finish,after this the system not respondind at all and i see a lot of green lines in screen,but nothing was as before the system denay even to insert dvd drive inside or close and reopen the all system..and the only i can see is the green lines........
-   grdimis67
2 options comes in my mind... Put software upgrading CD manually in player and let it finish software upgrade process. If this trick doesn't work, you need to replace digital process board or need to replace on board ROM, if you can. let me know if you need further info.
Comments:
Oct 26, 2008
- Hi Shah ji, Below is picture of Digital process board (DMB11) which you can easily see inside your player. Please mention your country name to provide you Board Part Number because this board contains regional codes info etc.
Oct 26, 2008
- Do you live in usa or any other country? I want to know your country name to provide you details like part number and where you can get it. DAV-DZ100 is made for many regions and you would be aware of DVD region codes. Let me know above said info to proceed further.
Oct 27, 2008
- Hi, You need DMB11 Board as per following part number.
Need the remote control code for Sony DVD home Theater system DAV-DZ 750k so I can program my...
(More)
Need the remote control code for Sony DVD home Theater system DAV-DZ 750k so I can program my Samsung TV remote control
I moved recently; my mini home theater system, Sony model DAV-DZ100 worked before; at my new...
(More)
I moved recently; my mini home theater system, Sony model DAV-DZ100 worked before; at my new location, when I tried to read a CD or DVD, the message CANNOT PLAY appeard in the small window of the receiver.
Reading the 'operating instructions' book, I then realised there was a procedure to make a 'MECHA LOCK' (mechanical lock) I suppose on the CD-DVD device.
How to repair that?
