Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My light doesnt come on when i break the sensor....and my learn light blinks none stop
Just had my springs replaced...now my sensors dont turn on my light and when the garage door gets completely open the light goes out but stays on when it closes like it should...both lights are tight....i also have noticed my learn light is blinking non stop
    President:
  • 3,197 Answers
Random blinking of the learn light is normal.
To have your lights come on automatically when you walk into an open garage, you must START with the lights ON. If you don't want that feature and you want to turn it off, you must START with the lights OFF.
To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Posted on Feb 17, 2012
Does about 8 stiches, and the red light flashes and it stops
This indicates a thread break, but if thread is not broken I would rethread the top as there is a thread break sensor on the take up spring that could have been missed in threading. If that does not solve then I would have a look at take up spring and attached sensor
Aug 20, 2014 | Singer Izek Computerized Sewing Machine
95 mazda 626 flashing o/d off and no speedometer
These guys are breaking parts every time you go there. Would never have replaced the ecu. It was the crank sensor to begin with. Replace the vss yourself. It is easy.
Jul 18, 2017 | Cars & Trucks
How to shut off Brake wear sensor after pad change
If the brake pads were worn enough to activate the warning light the sensor or sensors must be replaced. There is no reset for this.
Oct 24, 2009 | 2004 Lexus LS 430
Hold light blinking, check engine light on, engine slows down
check tps sensor (throttle position sensor in backside of the throttle cable) and map sensor (manifold absolute pressure on front little 1 inch sensor with vacuum line) make sure there plugged in. the ecm (engine control module driver side inner fender) and tcm (transmission control module under dash) both need the data to know when to upshift and increase fuel/air. Otherwise the computer runs default values and guesses off of other sensors giving poor performance. also disconnect battery for 15 min. usually resets aveo service lights if you dont have a scanner.
Jul 13, 2009 | 2004 Chevrolet Aveo
ABS light is on and Track-Off light is blinking
"ABS light came on and Track-off light started blinking"
This happened after I replaced the rear struts (shock absorbers") It turned out to be the left rear wheel sensor ($156.75). I must have damaged it when I replaced the strut. The way to check the 'rear' sensors is to remove the back seat to gain access to each sensor plug (2 prongs). Unplug it and check for continuity. If there is no continuity then you have a bad sensor, or an unlikely break in one of the wires. I checked for a break in each wire but they were fine.
Mar 12, 2009 | 1999 Toyota Avalon
Anti-lock brakes come on just before I stop when payment is dry
did you check the alb sensor? You might also have the "return spring" stuck in the emergency brakes. Sometimes they break causing the brake to lock, which in turn activates the alb. Also, check the brake oil level, in some cars alb dont work properely if the oil level is too low. Good Luck
Anton
Mar 09, 2009 | 1997 GMC Sierra K2500
Breaks pulsing
Does the abs light come on when pulsating? if yes then maybe you have a bad ABS sensor or it just the sensors cleaned . Where they turned under spec .which means more likely to heat up and warp or crack
Mar 03, 2009 | 2002 Chrysler PT Cruiser
Motor moves 5 in" and reverses and light blinks 5 times
In the manual it says if you can hold the wall button down & door closes. You have a short in the wiring to the reciever eye. Try substituting some new bell wire in its place, or test the wires for continuity.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sensor
There are spring tabs on the inboard side(engine side) of the reservior that are part of the sensor and you have to squeeze together in order to slide the sensor out. The springs run up and down as compared to the master cylinder. Good Luck
Aug 24, 2008 | 1999 Chevrolet Malibu
Intermitten remote sensor issue
Evidently 2 good remotes point at the problem being the remote sensor on the TV itself. I have about 4 remotes I can adjust volume w/ including the remote that came w/ my samsung. The TV exhibits the same behavior w/ all of them.
Per the samsung site, the "test" for this (remote vs sensor) is to us a digital camera, (including the kind that's on most cell phones) to "see" if the remote lights up. Just point it at the camera/phone, and press any button. You should see a bright flashing light on the camera/phone's LCD screen. If not, REJOICE! All you need to replace is the remote or batteries in it. If you do see the light, good luck if you're not in warranty. I've been unable to find any procedures for replacing this kind of item.
Nov 13, 2007 | Samsung DLP HL-P5663W 56" TV
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
163 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
