Question about Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5
I have a ingersoll rand t30 model 10fgt serial 30t 538337 10hp kohlor gas motor all it has is 2 pop off values one is 260lbs and the other is 60lbs but has no pressure gauge or regulater can you help me figure out where the pressure gauge should be located on the compressor thanks frank
  • 76 Answers
SOURCE: Help with 1967 Ingersoll Rand 223 30T Compressor
wow does it still make air
Posted on Jun 22, 2009
Testimonial: "Very helpful, quick responses to questions and good advice."
  • 76 Answers
SOURCE: Ingersol T30 won't shut off and blows pressure release valve
the wire juction box on your compressor has a pressure switch that may be wound in to tight take the cover off the box there should be a switch with a machine screw with nut and washer and spring back this nut off and see if that helps if you go to far you just crank it back in until the switch hit although it may be the other way around you may have to tighten to lower the pressure some of them are made that way if this does not solve your problem send me a picture of the switch and can solve it from there
Posted on Jun 26, 2009
  • 583 Answers
SOURCE: ingersoll rand compressor T30 model 7100
I would wonder A if the wiring was heavey enough to carry that sort of load with out overheating B if the motor is big enough to do it for the same reason( ?what is the duty cycle?) C if the receiver is big enough to allow reasonable time between shut down and start up --- remembering that at start up the motor pulls double the current to start up and if it doesn `thave sufficient time to cool alittle before being called on to do it again and that would prompt the question ,does it have sufficient ventilation? these are all queries that would need addressing before I would try to offer a solution ,one thing is certain ,--there is something wrong
Posted on Aug 17, 2009
  • 17 Answers
SOURCE: I am looking fo a manual for ingersoll rand t-30
http://company.ingersollrand.com/Pages/default.aspx
Posted on Dec 31, 2009
  • 1383 Answers
SOURCE: How do I adjust shut off pressure on an Ingersoll
The best way to go about the task of adjusting the pressure switch is to remove the cover to switch and note the brand/model number. Sometimes instruction are under cover of switch. With switch information, look for mfg. instructions. You will most likely see one or two springs with lock nuts. Do not turn them yet. Most pressure switches are sold with factory adjustment and are sold in pressure ranges. For two stage compressors as yours, the pressure is usually factory set at much higher (150-175) pressures than single stage which is usually about 120 -125. If you change the pressure setting it will also change the differential cut on pressure. The factory will actually use different springs to achieve desired pressures and are color coded. There are too many different brands of switches to recommend how to change pressure setting. You may discover that you can only change the pressure just a small amount (+or -15-20psi ). If you find the information about your switch, make sure that you count the turns exactly so that you can return to factory settings if things go wrong. You can extend the life of the comperssor by lowering the pressure as more amperage /heat is produced to achieve higher pressures. Good luck
Posted on Sep 23, 2010
WILL T21 SELECT OIL WORK IN A MODEL 2475
The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
I have an old IR 30 T that needs repair where do I find a manual for this
You may find your parts manual for your compressor here http://www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Just scroll down the page, the manual for an IR 30 is there, also on that website, you may find the problem to your compressor
Sep 29, 2012 | Ingersoll Rand - Rand Type - 30...
Whare can i get picture of ingersoll rand type 30 model 234 with serial no 645261
Hi Omran,
The capacity of your compressor is 7.46 if the motor drive is 2 hp. 9.79 if the motor drive is 3 hp.
Hope i can help you.
Sep 13, 2012 | Ingersoll Rand - Rand Type - 30...
I have an ingersoll rand 30t model 253 compressor 80 gal tank. what should the start and stop pressure settings be? what is the run time to fill tank and cycle off?
Hi
I'm not sure but I operate my'n at about a 145/150 top and about 110/120 min.
However others my have a differant perspective
Cheers
John
Jul 09, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
I NEED THE WIRING DIAGRAM TO HOOK-UP AN INGERSOLL-RAND TYPE 30, MODEL V 234 N4, SER. # 30T 37128 I UNDERSTAND THAT IT CAN BE WIRED FOR 110 VOLT OR 220 VOLT POWER.
The wiring diagram is on the outside of the
motor case, on most motors,on the label
Also on the inside of the wiring connection
cover
May 25, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
Ingersoll Rand - Rand Type - 30 Reciprocating Air Compressor - 5 Hp, 230 Volt 1 Phase, Model - 2340L5 Logo
873 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
