Question about Frigidaire FRT17B3A Top Freezer Refrigerator
Spacer broke on frigidaire refrigerator and door will not close
5 Suggested Answers
  • 105 Answers
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
Posted on Apr 17, 2009
  • 93 Answers
SOURCE: Refrigerator gurling noise when door closes
There is a water evaporation tray in the back of the frig. Air pressure fron closing door makes air bubble thru tray. Its not a problem.
Posted on Aug 29, 2009
  • 306 Answers
SOURCE: My frigidaire refrigerator door is sticking. I
Sounds like the door hinges have gotten loose and let the door drop. With the door open can you move the door up and down? If hinges are tight you should NOT be able to.
Posted on Apr 30, 2010
cautionflag1
  • 116 Answers
SOURCE: Hi, I have Frigidaire side
It is probably a cracked lower bushing or loose lower hinge. If the hinge is tight, then the bushing is probably bad. It is not a hard part to change. Empty the door then then remove the top door hinge. The door should lift off the lower hinge and expose the bushing. Put in a new bushing, grease it a litte with some Vaseline or equivelent and reinstall the door. This link has an exploded view and part # of the bushing (#22 on the diagram). http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150332&diagram_id=1239787#d1239787
Hope this helps
Posted on Jan 30, 2011
My fridge door is not closing tightly without force
The bottom hinge has spacers. Perhaps a spacer or two have worn out. Remove the bottom hing and see if there are any spacers if not a hardware store could get a couple for you. Install them and this should raise the door hopefully to clear the liner. The only other thing is the hinge pivot is just worn out. This is more complicated to repair
Jul 30, 2014 | Kenmore Refrigerators
My refrigerator door does not come up high enough to push in the button when it closes, so the alarm keeps beeping to signal that the door is not shut. I thought if I removed everything from the door,...
You may have one of two problems, you either have too many spacers on the top hinge or not enough spacers on the bottom hinge. With the door on, measure the amout of of distance the door has to come up in order to close properly, say it's 1/4". That being the case, remove door from fridge and install a 1/4" plastic washer over the bottom hinge pin which holds the door in place. It may be necessary to remove a spacer from the top hinge in order for the door to close properly after installing the new bottom spacer, or you may get lucky enough to just take one from the top hinge and put in to the existing hinge spacers on the bottom. Reinstall door and check for proper closure and allignment. Hope this solves the problem.
Kenny
Dec 28, 2013 | Kenmore Refrigerators
I have a sears kenmore elite refrigerator. It is a side by side. The doors don't line up when closed. The freezer side is about 1/4" higher. It looks funny when closed.
there are plastic spacers located at the hinge on the bottom of these units, and they break after wear and tear , they are also beveled so they help the door close,, check to see if yours are in good order, if not you'll have to replace them,, to do this you remove the top hinge,, its just a couple of screws that hold the hinge on under the plastic deco cap ,, once you've done that Lift the door off the lower hinge,, install the spacers, and place the top hinge back once the door is reset
Aug 25, 2011 | Kenmore Side by Side Refrigerator
Fridge door not closing properly
This section of this refrigerator door repair guide will walk you though repairing a refrigerator door on a side-by-side refrigerator. On most side-by-side refrigerators there is a cam that lifts the door up when you open the door so that the door has a tendency to fall down and back into place while it is closing. If the refrigerator has a cam and it is working properly, the refrigerator door will rise up when you open it and lower when you close it. If this cam is broken the door will not close properly. A lot of refrigerators have two cams, one screwed on the door and one on the hinge. You may have to replace the entire hinge to replace the lower cam but the cam on the door can always be replaced. You will have to order the cam by model number and can do so on this website AppliancePartsPros.com.
On side-by-side refrigerators without cams there will be a spacer on the door hinge. If this spacer is missing replace it. Note that any plastic spacer will work as long as it will go on the hinge pin and is not too thick. Never use a metal spacer because this will cause wear on the door and it will eventually squeal when closing.
As on top-freezers the door gasket may be ripped and if so refer to the bottom section that talks about door gasket replacement.
Sometimes the door can get warped out of shape. If the door is closing at the top and not at the bottom or vice versa the door may be warped out of shape. You can fix this by twisting the door back into shape. Take you foot and place it at the bottom and pull the door out at the top or place your foot inside the door at the bottom and push at the top with your hand depending on which way you need to twist the door. Note don’t over do it twist it a little and if it isn’t enough twist it a little more. If it gets worse you may need to twist the other way.
hope this helpout ......
Aug 12, 2010 | KitchenAid Superba Architect KSCS25INSS...
The door does not close and door shelves are broken. I would like another one the same as what I have but don't know where to find it.
Do you mean, another one that is broke, the same way; if not, juse put the name of the refrigerator, in your search engin box, on your computor and hit enter.
Jul 04, 2010 | Frigidaire Refrigerators
Aug 28, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer door
Hi, before you put this part on, have you tried adjusting the door hinge at the tp of the refrigerator? The part you described sounds like the door stop and I do not thing=k this will solve your problem. The top hinge can be loosened and then push the top of the door away from the other door. Please let me know if this helps at all or if I can assist you further.
Thanks
Vic
May 21, 2009 | Frigidaire FRT18P6BS Top Freezer...
Ice build-up on the inside top of of freezer door
This is a problem that the factory has released a bulletin on.They have released new hinges, and insulation for inside the door. So far I've only seen the bulletin for Kenmore upright freezers made by Frigidaire. Since it is a Kenmore the bulletin is a Sears Service Flash but the units are identical. For sears its SF46-517. They may extend the service to Frigidaire units but you'll have to contact Frigidaire about that.
Nov 04, 2008 | Zanussi Z57 / 3 Bottom Freezer...
INTERIOR FRIG LIGHT
replace the switch before the seal, nothing wrong with gasket., you may need to raise the refrig door a bit by , remove the door and install a small spacer to raise the door slightly for better contact
Oct 22, 2008 | Frigidaire FRT21H8 Top Freezer...
Frigidaire FRT17B3A Top Freezer Refrigerator Logo
88 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
