Question about Jenn-Air Ovens
Jenn-Aiir S125 oven won't heat up, only gets warm.
Oven only gets warm. This just started happening.
SOURCE: Jenn Air oven Model D156 won't turn on
get a new range
Posted on Aug 11, 2008
localwonder
  • 6784 Answers
SOURCE: Jenn air oven problem
HI. this is a Communication error between boards. Check the wiring harness that links the Power relay board to the Main board. if the harness is fouled on any way, replace it asap. if the harness is in good condition, replace the power relay board.
Posted on Jul 27, 2009
fixyourboard
  • 310 Answers
SOURCE: Our Jenn-Air double oven is 10 yrs old. Will not
There are 3 things that can cause this:
1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out.
Regards,
Bruce
www.fixyourboard.com
Posted on Oct 10, 2009
jonniewalker
  • 1031 Answers
SOURCE: replacing heat elements in oven
To replace oven heat element follow the steps below carefully
Turn off the power to the oven at the breaker box.
  • Step 2 Take out the screws holding the element bracket in place. These will be on the back wall of the oven, or sometimes on the top.
  • Step 3 Pull the element toward you a little bit until you see the wires behind it.
  • Step 4 Unscrew the leads and take the bad element out.
  • Step 5 Hold the new element up while you attach the wires to it. Don't stretch the wires any more than you have to.
  • Step 6 Line up the element while tucking the wires back in. Be sure not to pinch the wires between the bracket and the back wall.
  • Step 7 Fasten the brackets, making sure they're tight.
  • Step 8 Restore power to the appliance.
  • basically to install the elements , place it in the same position as the old one. Connect it the same way the old one was connected, using the same screws to hold it in place. Just about all the other components of an electric range or oven
  • Posted on Jan 03, 2010
    Testimonial: "Thank you very much! "
    jumptrout51
    • 3361 Answers
    SOURCE: jenn-air ww30430w dual oven, lower oven, lower
    Most likely a bad element. Turn off the power to the oven. Remove the racks.
    Use a phillips screwdriver or 1/4 inch nut driver to remove the mounting screws at the back of the oven cavity to remove the element. Carefully pull the element out and remove the wires. Do not let the wires fall back into the holes.
    Use a volt meter set for continuity. Touch one meter lead to one terminal on the element. Touch the other meter lead to the other terminal. If you get NO reading the element is bad.
    A new element will correct your problem.
    If the element reads as good you have a wiring problem or a bad control.
    I have a Jenn-Air oven model S125. I think it's about an 1987 model. The stove-top and flat/griddle work great but a few months ago I notice the clock quit working and the oven no longer works. Any...
    The replacement clock is no longer avaliable from Jenn Air however in my appliance repair career i run across many still in the field and have included a link for this place in Ohio that will rebuild it and send it back to you. What you would need to do or have a company come and do is remove the clock and ship it to them.Their is a curcuit in the clock that ties into the oven and its very probable that the oven not working is related to teh clock. http://www.appliancetimers.com/index.php?page=db_timer_page&Timer_id=7052&Manufacturer=Jenn-Air&Appliance=Range-Stove-Oven&Model=712024 this is their link contact them and see if they can rebuild yours. If you, or even a repair company remove it to be shipped off to rebuild, take time and make a drawing of where the wires on it go so they can be reinstalled properly once its back to you freshly rebuilt.Also be sure to insulate all the wires taken off since some will be live and if come in contact with metal without proper insulation they could short out something else.
    Aug 11, 2011 | Ovens
    Jenn air gas oven won't light off/heat up
    Thanks for choosing FixYa and welcome. you have a electric oven or a gas oven that won't heat or doesn't heat properly, here are some things you will need to check. The most likely cause of a oven not heating correctly is a defective heating element. You have two types of heating elements in your oven. The bottom element(s) are the baking elements. The element(s) on the top are the broil elements. If you don't see the bright red glow from the element, chances are they are not working or not working correctly. If a heating element is bad, you need to replace the entire element. If your oven is warm and not correctly hot, one of the elements may be bad. In most ovens, when you preheat, both elements are used. This would make the oven to appear like it is working correctly but it is not. If the elements are not working, they might not be getting power. Test the wires to the elements with a voltage meter to make sure they are getting power before you decide to change them out. Many electrical ovens have a sensor that monitors the oven temperture. Ovens that have this sensor usually contain a digital display on the oven. The sensor could be defective. Those without the sensor use the basic mechanical system to control the oven temperature. You also want to check the thermostat sensing bulb. Make sure the bulb is good and has not come loose. Now, if you have a gas range oven that doesn't heat properly, first, you want to check your bake igniter. It may have burned out or it could be not working properly. It will be located near your burner. It is also possible that you are not getting gas to the burner. If so, it may be the gas safety valve or the igniter. You need to check your selector switch and thermostat as well. They may be defective. Always make sure you test the parts for power with a voltage meter of some type before you decide to change the part. If you have a part that appears to not be working, it may not be getting power because of a bad wire or broken connection.
    Jun 13, 2011 | Jenn-Air Ovens
    What does F1 mean on the display panel on my Jenn Air gas oven? It won't allow me to heat up the oven, and the igniter is fine.
    F1 code indicates that:
    a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode or
    b. The ERC is receiving information to run multiple heat functions simultaneously.
    Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
    1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
    2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel -don't spray directly onto the surface of the touchpad.
    3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
    4. If these tests all check good, then replace the ERC.
    Hope this helps.
    Jun 03, 2011 | Jenn-Air Ovens
    The ovens turn on but do not get hot--it gets warm but the burners never turn red --- it takes 3 hours to cook a chicken
    If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    Jul 17, 2010 | Jenn-Air Ovens
    Both upper and lower oven elements won't heat beyond warm (100 degrees) Jenn-Air Model# SVD48600P
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    heatman101
    May 15, 2010 | Ovens
    Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
    The most common failure in any electric oven is the heating element.
    Jun 20, 2017 | Ariston Technologies Ariston FO98P...
    Very old Jenn-Air wall oven (model w100) will not heat
    nope..no fuses...time to research a new oven.
    May 28, 2008 | Jenn-Air Ovens
    Need part number for oven bulb
    looked up the bulb part is no longer available, but it looked like a regular appliance light bulb, remove the old one no diffrent then any appliance bulb you can buy in the supermarket if need be
    Feb 19, 2008 | Ovens
    Oven and stove top not getting hot.
    The most probable cause is that the heating elements are getting 110V instead of 220V. Check the voltage to the heating elements.
    Sep 07, 2007 | Ovens
    Jenn air single wall oven model jjw8530BAB - exhaust fan not working properly
    in not sure but i think that fan runs off a thrmistor that goes to the contol board.open the oven door and look on the right side of the oven see if theres a metal looking bulb.
    Aug 19, 2007 | Jenn-Air JJW8530C Expressions Collection...
    Ovens Logo
    Top Jenn-Air Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Craig Butler
    Craig Butler
    Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
