Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
The suction is coming out of the wrong spot.
The suction is coming out of the accessory tube, not from the floor part. The rollers also won't go - I suspect because there is no suction coming out.
  • Official Brand Answer
  • 2,572 Answers
Hi Laura,
I'm glad to hear you were able to fix your machine. If you need any further assistance with your DC17, please visit our online support page for this model:
http://www.dyson.com/support/help.asp?article=2&product=DC17-ANIMAL
Alternatively, if you'd prefer to speak to someone in person, please contact our free Helpline on 1-866-693-9766, or email us at askdysonUS@dyson.com.
Best wishes,
Jack
Dyson Online Customer Support
Posted on Feb 17, 2012
4 Suggested Answers
  • 389 Answers
SOURCE: There is no suction to the floor sweeper. The
Sounds like you have two separate problems here.  If the brush bar does not rotate, probably the belt is broken. This is easily replaced, but you need to be precise about which model you've got so you get the right belt.
Loss of suction is due either to a blockage or, quite often, to a split in the short length of clear plastic hose that leads back from the brush bar enclosure.  Repair is possible but replacement is better.
If you need more help, post here again.
Posted on Apr 21, 2009
  • 43 Answers
SOURCE: no suction in floor attachment *& brush not turning
Lay the machine on the floor with the front side down. Undo the 3 large plastic screws with a coin of some sort, then remove bottom panel. On the back of carrage where the roller bar sits their should be a clear plastic tube check this tube is free of dirt. Check around inside the carrage for hair string etc. Check belt for breaks and swelling in the rubber pull ont roller bar and check the end caps on the roller can spin freely. If not pull off the end caps these will be very tight and wash out all dirt and fluff, dry thourley and lubricate centre pin and end caps inside the roller with baby oil or wd-40. replace roller bar and belt, turn roller bar twice slowly to centralise the belt, replace bottom panel making sure that the clips on front are sitting in their holes. fastern the plastic screws and leave two hours before usage
Posted on Nov 11, 2008
  • 183 Answers
SOURCE: Dyson DC21 All Floors Stowaway
Simply answer Yes it would be but try and make sure the the old head is clean before dumpin it just in case
Posted on Jul 28, 2010
Brush roller works on carpet setting but not on floor setting. have already cleaned roller. suction is great. just won't do anything on floor setting (all 3 settings)
Check the arms that make the roller go up and down to achieve the settings. There may be something clogged in there.GOOD LUCK FRIEND
Sep 14, 2014 | Electrolux EL8807A Precision BrushRoll...
Vacuum roller won't turn and there's no suctions. Red light Doesn't blink
go to http://www.dyson.com/
get the support and download the model, troubleshooting, video for your trouble.
God bless you
Sep 16, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Brush does not turn. suction with the handheld unit it fine but when used as a floor sweeper it hardly picks up anything
these stick mmachines do not have a tremendous amout of suction at the best of times but if it has a full bag, or full dirt container, or dirty exhaust fiters it will take away from the air flow as well. take a flashlight and look up in to the tube of the floor attachment to see if you can see something blocking the tube.If there is no obstructions it may have a roller bar that spins on the bottom , so turn it over and turn it on and if it has a roller bar and it is not spinning it probably needs abelt . If there is no roller bar and no blo0ckage chances are it is just weak at the floor tool as the air a further to travel all the way up from the floor so it takes away from the air flow again. good luck.
Oct 07, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
No suction on floor part
From your problem description, you may have a blockage in the foot. Check the intake under the vac by the roller.
May 01, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Kenmore progressive 360 vacuum cleaner has low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Kenmore 35912 / 35913 Progressive Upright...
No suction
Feb 28, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
Eureka 4870: Brush roller turns even in hose setting.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
Jun 21, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
No suction in floor attachment *& brush not turning
Oct 17, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
57 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
