Question about Ultra Max Aquascape AquaBasin, Pond or Water Garden Ultra Submersible Pump Kits
Aquascape SFA 3000 shutdown
I have a Aquascape SFA 3000 in my pond. It shutoff the other day and when I removed it from the skimmer the impeller was off of the shaft and wedged between the shaft and the housing. I put it back together and it ran very noisy for a while and quit again. I assume that it is burnt up, but at the cost of these pumps I would like to have it rapaired. Is there an affordable way to repair these? Is there a rebuild kit? Something to conserve costs. The pump was in the pond when I bought it. It is very likely over 2 years old.
  • robt28 Nov 08, 2008
    My Aquascape 3000 pond pump just died shortly after 2 years use. Is this typical and are there better substitutes.
  • jrmat Apr 05, 2009
    I use two of these pumps in my pond. They have both suffered from burnt-out bearings after about three years use. They were filled with water. I cleaned them out dried them out, resealed them and they work for a month or two, but basically they must be replaced as far as I know (maybe with a Matala MKH150). I do not know if they are any more durable though.
    Problem Solver:
  • 4 Answers
Bad pumps, bad brand.
Posted on Nov 08, 2008
Pump is making a grinding sound. it has been pulled and is debris free. the pump is approx.5-6 years old
Check the impeller shaft for cracks and rough patches. harlok_6.jpg If the impeller shaft is still smooth and in one piece the main motor bearing is damaged or worn out. A main bearing is not replaceable as accessing it would compromise the motor housing.
Apr 20, 2011 | Aquascape Designs Nursery Pro Ultra Pump
My Aquascape 4500 pump immediately trips the GFI when I plug it into an outlet. This happens both when it is submerged and out of the water. The impeller is not obstructed.
The seal has failed allowing water into the sealed motor unit and it is now shorted to ground...in other words the unit is shot and needs to be replaced.
John
Apr 07, 2011 | RTO AquaScape 4500 GPH Pump
My pump has locked up is there any way to fix it
No,
They are made overseas and there are NO parts available to replace anything damaged inside your unit. Unfortunately your choices are a new unit from Aquascape or a new unit from another manufacturer. In our experience none of the units are 'great' for durability but aquascape lasts as long as any others, some others are worse.
Oct 26, 2010 | Aquascape Designs PUMP AQUASURGE 3000 ()
Impeller shaft broke at impeller. moytor started to make loud noise . removed end of pump to find impeller at bottom of housing.
i have the wsame problem. A new pump will run me 550 I dont think I could replace the impeller shaft
Oct 17, 2010 | RTO AquaScape 4500 GPH Pump
Shuts off intermittantly, impeller moves freely
Does it come back on after resting/cooling down. If does peobably kick out on heat overload and is resetting itself. If impeller is free spinning with NO roughness or side play in bearing probably too much head pressure,pumping too far or too small pipe wich will cause excessive pressure making pump work to hard
Apr 10, 2010 | RTO AquaScape 4500 GPH Pump
Rebuild kit for the Aquascape SFA3000 Pump???
I have had the same problem everyone else has had with these pumps. I did serious research on these pumps and came up with a rebuild kit some parts bought some I make. I did mine 2 years ago and still working like a champ and have done over 20 locally with no problems. If your pump is noisy or the impeller has fallen off (typical) due to water getting in the unit and causing the bearings to fail email me and I can rebuild your pump. The process is simple send me the pump I will look at it and see if it can be rebuilt at NO CHARGE if it can be rebuilt you will save over 60% of a new one. Don't spend $349 - $599 on a new one let me look at it for free if I can rebuild it great if not you will have to buy a new one. I am not a dealer for any pumps so you will not have to worry about me selling you a pump and if you want the old one back pay the shipping and it it all yours.
Jun 18, 2009 | Ultra Max Aquascape AquaBasin, Pond or...
Aerate a pond
I live near Memphis TN so don't have that pesky "frozen water" problem. However, I do aerate my 2,500 gal goldfish pond with a Oase Biosys Skimmer (free standing/ floating skimmer) which is powered by a Laguna fountain pump. I attached a small pipe on the discharge end of the pump & set the pump so that this pipe is a few inches below the water's surface. The discharge provides a small fountain effect that keeps the surface moving while aerating the water. The skimmer keeps the leaves / debris off the top of the water the pump keeps the water moving...and moving water will not freeze. Hope this helps
Raincreek
Dec 24, 2008 | Aquascape Designs Aquascape - AquaForce...
Aquascape 3000 Pond Pump
I have had similiar experiances with these. My most durable pumps are 1. Atlantic water Garden Tidal wave 2 pumps. - ( 1 pump repaired in the last few years out of hundreds sold) 2. Pondmaster - most models. The pondmaster (Danner Mfg. customer service is fantastic- no hassle problem resolution). The pumps get better every year and THREE year warranty.
Nov 08, 2008 | Garden
Ultra Max Aquascape AquaBasin, Pond or Water Garden Ultra Submersible Pump Kits Logo
1,196 people viewed this question
Top Ultra Max Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you an Ultra Max Garden Expert? Answer questions, earn points and help others
