Question about Canon ZR100 Mini DV Digital Camcorder
No picture during playback
I tried to play a tape today to see what was on it and I get nothing but the blue screen on my LCD display and through the viewfinder. It is playing the tape, according to the counter/timer on the screen, but I can't see anything at all except the blue screen, no picture shows up. When I change the setting over to record, everything works fine, picture is normal. I have had the camera about a year and a half and never had any problems with it before today. I tried a different tape and got the same results. Any other ideas? Thank you. Angela
Thank you, I actually found the solution to this problem. We called Canon and they tried, but ultimately could only suggest that the unit needed to be cleaned. The gentleman we spoke to had not heard of this particular problem. But we decided we had nothing to lose, so we bought a Mini DV cleaner at Wal-Mart for less than $20 and it actually worked. Hopefully, this post will help someone else if they run across the same, apparently rare problem. Thank you, Angela
Posted on Jan 07, 2007
Only thing I can think is the tape may be blank. :) GOOD LUCK
Blue screen on lcd screen
The playback head is probably dirty and cannot show the picture - the screen is blue. Run a blank tape in the tape drive and execute a record all the way through the tape. Then play back a pre-recorded tape to verify it plays back ok.
Nov 11, 2010 | Sony DCR-HC30E MiniDV Camcorder
During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
Apr 18, 2009 | Canon ZR40 Mini DV Digital Camcorder
Sony CCD-TRV65. Blue screen during playback
Just bought the exact one from a yard sale for 20 bucks. Had the very same problem with the blue screen on playback. What i did is replace the battery in the small bay when you open the viewfinder. Try playing your tape again and it will work!
Feb 01, 2009 | Sony Handycam CCD-TRV65 Camcorder
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
Playback
That's dirty video head! Try to playback new tape for five minutes, do it for 2 to 3 times, this will serve as your videohead cleaner. eject then reinsert then playback, eject again for at least 3 to five times. most camera has a built in videohead cleaner that activates during eject, initial play and reinsert mode. you can even try to play the whole blank tape! thats 1 to 2 hours of playback! If the problem is still there after doing those things, you need pro fix then.
Sep 13, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Blank screen during playback
your camcorder video head is dirty, use a brand new tape and playback for around 5 minutes or more, this will serve as your video head cleaner. you may try at least five times doing this: insert, play, eject,play, eject again. your camcorder has a built in videohead cleaner and activates only during insert, play or rec, and eject mode. If the problem is still there, manual videohead cleaning is needed, use clean bond paper and lighter fluid, damp the bond paper (Size about 1" by 3") with fluid and rub with care the videohead (not the bond paper!The vhead should be the one turning not the paper)by slowly turning the videohead against the paper. Be careful cause this is dangerous that you might brake the videohead permanently. apply only a slight force to the head.
Aug 29, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Lost LCD Screen
You MAY just have a dirty playback head. Purchase a head cleaning tape (Bestbuy, Target, etc., for about $20) and try cleaning your playback head. Colored lines is ONE symptom of a dirty head. A blue screen is ANOTHER. I had that symptom yesterday (9/7/07), got a cleaning tape and solved the problem. I can now again see on the LCD display what I recorded on the tape. Good luck.
Aug 21, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Jul 30, 2007 | Canon ZR100 Mini DV Digital Camcorder
Canon ZR100 Mini DV Digital Camcorder Logo
227 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
