Question about RCA RP5010 Digital Voice Recorder
Can't record anything new
The voice recorder says it's full, how do you erase? or what needs to be done?
You can either use the "Digital Voice Manager" (loaded from the recorder when you first plugged it into a USB Port... OR, when you brought up the files in the recorder, clicked on the folder with setup). Or, if you just want to clean out everything from all four (A-B-C-D) folders, you can format the chip. Turn the recorder "on", press and hold "erase" until it flashes, press and hold "record" until it flashes "format", and press and hold "erase". "WAIT" will show on the screen until the chip is formatted, and you now have a clean chip - 128 meg or thereabouts.
Posted on Nov 07, 2008
I have a new Sony Microcassette Transcriber M-2000 and cannot figure out how to ERASE a tape that I've transcribed. The Operating Instructions don't mention that feature, either. Can you help me?
Hello sorry the M-2000 don't have the ERASE feature but your only option is to get a tape eraser you can get one at http://www.tvps.com/Products/ECS-ME20-Mini--Micro-Cassette-Eraser---New__VE-ME-20.aspx just think positive your unit will last longer the eraser prolong the life of units just pass the microcassete once on the eraser and is done full erase :)
Apr 14, 2011 | Sony BM-850T Desktop Cassette Transcriber...
My WS 100 says FULL and won't either let me put it
The recorder should be formatted only by using the internal FORMAT function found in the recorder's Menu. Using a computer to format the recorder may corrupt or delete system files needed to run the recorder, so formatting via the computer is not recommended.
Individual files can be deleted from the recorder while it is connected to a computer without negative effects.
Feb 04, 2010 | Olympus WS-100 Digital Voice Recorder
Erase recorded files on my Cenix VR-P490 voice recorder
You have to select the file to erase hold the erase button and when "ERASE" blinks in the display you have to press the erase button one more time. Do this for each file you wants to erase.
Jan 20, 2009 | Panasonic RR-QR150 Digital Voice Recorder
WS-110 memory full but no files
well, i resolved this myself by going to the sub-menu, and formatting the recorder to its original state. thankfully, i backed up the files on my computer first, so i didn't lose any data, although i did have to go in and re-set all my preferences on the recorder.
lesson: don't MOVE files from recorder to computer. copy them instead, and do the actual erasing from the physical recorder itself.
i don't know if this was the most elegant solution, but at least it did get my recorder up and running again. i'd love to hear if there is a better resolution out there.
Nov 28, 2008 | Olympus WS-110 Digital Voice Recorder
Sony icd-320 handheld voice record.
The erase button is on the right hand side of the recorder. When you are on the message that you want to delete, then hold the erase button down. The message will start to play and an erase message will flash. Push the erase button down again and it will delete the message. Continue to do this for each message until you have the desireable amount of free space.
Oct 25, 2008 | Sony ICD-P320 Digital Voice Recorder
Cant erase
To select your message to erase depress REC/STOP button. Then "scroll" thru recordings by using the "rocker" style switch on the upper right side of recorder labeled INDEX. When you have the recording on the LCD display you wish to erase, depress the ERASE button for more than a second and release when the display starts blinking "ERASE" - then depress the ERASE button again and the recording will be erased. Do the same for each numbered recording to fully erase all recordings.
Apr 08, 2008 | Sims SVR-B445 Handheld Digital Voice...
Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose a folder.
Every time the FOLDER button is pressed, it cycles through folders and the List display will appear (+P20).
Press the + or button to choose the file you want to erase.
Press the ERASE button. The “Cancel” indicator flashes.
Press the + button to choose “Erase”.
5
Press the OK button. The display changes to “File Erase!” and erasing will start. “Erase Done” is displayed when the file is erased. File numbers will be reassigned automatically
Apr 04, 2008 | Olympus DS-30 Digital Voice Recorder
My recorder says "full" when i try to record, but i have deleted everything!!??!!
Solution for this problem is to Format the recorder. Step 1 is to turn on unit. Step 2 Press Erase " Delete will flash on the display. Step 3 Press and hold Rec for 3 seconds "Format" will flash on the display. Step 4 Press and hold Erase, the completed percentage will show on the display (formatting is now in progress). Step 5 After formatting is completed the remaining time will show on the display. You should now be able to record. Make sure that you hold the ERASE button in step 4 until Formatting shows 100% complete.
Feb 23, 2008 | RCA RP5030 Digital Voice Recorder
How do you delete old recordings?
find the recording you want
press the erase button (front of the recorder(top left))
after pressing it let it go
then press it again
that recording is then gone
voila
Jan 22, 2008 | RCA RP5010 Digital Voice Recorder
RCA Digital voice recorder model RP5022B
have you tried formatting it? press erase till it flashes delete, then press and hold record for 3 seconds till it says Format, then press and hold erase till it says wait..it should fix it if that's the problem
Dec 15, 2007 | RCA RP5008 Handheld Digital Voice Recorder
RCA RP5010 Digital Voice Recorder Logo
69 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
