Question about Proform Exercise & Fitness
I have a ProForm crosswalk treadmill and have had it for a year, just recently it's making some clanking sound. I checked the motor and nothing seems loose. What should I do to eliminate the sound?
    Top Expert:
  • Proform Master
  • 12,223 Answers
Dear Sir:
First you must LUBRICATED your crosswalk treadmill according with the schedule of maintenance in your instruction manual.
If you do not have go to the web; www. proform. com go customer service then parts % manual, give your model etc, and download for free, and follow the schedule in your use manual.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Posted on Feb 18, 2012
  • 16 Answers
SOURCE: Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Posted on Apr 14, 2009
SOURCE: Proform Owners Manual Crosswalk Advanced 525x
Proform Owners Manual Crosswalk 380 Treadmill
Posted on Sep 25, 2009
  • 10865 Answers
SOURCE: Need to replace 15 amp fuse on ProForm Crosswalk
Remove the fuse and take it to any auto parts store where they will match it up for you. Regards, Joe
ps - kindly rate my answer. thank you.
Posted on Feb 04, 2010
  • 18 Answers
SOURCE: We have a Proform Sport 1000 treadmill which when
There is a belt between the front roller and the motor (drive belt) that is under the motor hood. The trick is to watch the front roller when you get on the walking belt. If the front roller stops with the walking belt, then the drive belt is loose and needs to be replaced or tightened. If you have already adjusted the walking belt, and you can hear the motor, it's the drive belt. There will be 3 screw on the front of the machine, and a couple of screws under the main frame. Tip the unit over to find the screws, and take off the cover. You'll be able to see where the slip is.
Posted on Mar 10, 2010
Proform treadmill motor shuts off after a second or 2
There may be a problem with the LCB or motor.
I repair this brand for the distributer in Australia.
Dec 14, 2013 | Proform Crosswalk 500 Treadmill
Knocking noise when machine running
see the video and fix it. This happen because the lack of maintenance according to the schedule. God bless you
Apr 03, 2013 | Proform Crosswalk 395 Treadmill
Hello i have a proform crosswalk sport treadmill and when i turn the speed on it shows a reading for a couple of seconds, but doesn't come on. The incline works just fine. The motor will turn manu
adjust the REED switch see the diagram attached m clean it+test for open or faulty with DVOM, tight the connector very well,However try to RUN the software calibration and fix it. see the diagram attache too for speed sensor, adjust it and test it , clean it, and tight very well the connector.God bless you3_22_2013_4_18_58_pm.gif3_22_2013_4_19_19_pm.gif3_22_2013_4_19_33_pm.gif
Mar 22, 2013 | ProForm CrossWalk Sport Treadmill
White powder-like substance on belt
Dear Sir:
LUBE the deck belt, is lack of maintenance, maybe you have to change the deck belt, this produce enough friction and shut down the machine for to protect the electronic system.
2) lube THE ROLLERS bearing , according with the maintenance schedule.
3) Clean any EXCESS of wax, and LUBE very well.
4) Test the input motor if there voltage the motor need repair.
God bless you
May 09, 2012 | Proform XP CrossWalk 580 Treadmill
Proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
Apr 28, 2012 | Proform Crosswalk 500 Treadmill
I have a 1992 Proform CrossWalk Dual Motion Cross Trainer. Motor still works great. There is rubber covering the roller under the moving piece. It has come off on the right side. Can this be replaced?
Really, I have had my crosswalk for over 20 years. I can't complain. I am passing it on to my son and getting a NEW Proform treadmill. Their longevity has sold me.....
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
Recently purchased the Crosswalk 570. Assembled
recently purchased a crosswalk 570 treadmill and used it and it worked fine but when we tried to use it today the machine made a strange noise under the hood. we noticed that the belt on the track was slightly rubbing against the hood. How can we fix it?
Jun 11, 2009 | Proform 575 Crosstrainer Treadmill
Exercise & Fitness Logo
177 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
