Drills / Drivers
Problem for Drills / Drivers
Generic problem for all Drills / Drivers
Dewalt dc 988 drill housing
By mueller536 on Oct 25, 2008
I need to find a housing for a DC 988 18v cordless drill as mine is smashed can you please help?
Best Solution
posted on Oct 25, 2008
Helpful)
stug_57u
Rank: Wiz
Rating: 90%, 50 votes
If you are in America/Canada go to dewalt service net http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1. make sure you check the type number as there are some variations across the model range. You should find the type number either just after the model code or on the top right of the rating plate.
If in U.K. then go to https://service.toolcommerce.com/products/HomePage.aspx?BrandId=2&language=en-GB&country=GB.
You should be able to ID the part and find a dealer from these sites.
Was this helpful?
Yes
No
Popular Solutions for Drills / Drivers
Questions and Unsolved Problems for Drills / Drivers
Answer
what is the best impact driver
Answer
I have a DCD940KX 18v Dewalt drill driver with the one click drill chuck. It does not keep drill... (More)
Answer
I have p211 ryobi 18v vsr drill/driver,the drill seems to work fine but the break feature does not... (More)
Answer
My DC759 drill was apparently assembled without the bearing clip so the nose pulls out chuck, shaft... (More)
Answer
ryobi 12v charger doesn't work. I used a multimeter to check out that the voltage dropped very low.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Drills / Drivers:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
