Question about Mitsubishi M-VR1000 Receiver
Mitsubishi vr-1000 turns itself on after we have turned off with universal remote
We turn off all devices including receiver with universal remote and some time later just the receiver comes on. problematic with two small kids and neighbors as it happens often during the night.
  • ian sawyers Feb 17, 2012
    thanks but it is a receiver not a car. Thanks anyway
  • Stephen Larkin
    Stephen Larkin May 03, 2016
    I HAVE ONE IN MINT CONDITION IF YOUR INTERESTED
Get rid of the remote ,get it taken out of the vehicle , i take it that it is also an alarm system as well , if so you could find one day you wont be able to start the vehicle , and immobilizers have a have a great sense of humor they always stuff up when you are out somewhere or its raining
Posted on Feb 17, 2012
Can't get Mitsubishi tv remote to work with my
These are universal remote setup codes for Sony TV. 0128 0013 0002 0071 0380
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 04, 2012 | Televison & Video
Kenwood VR-405 receiver
Try cleaning the little window where the
IR detector is on the receiver, and clean
the transmitter led on the remote also
If that does't work then it may
be a defective IR circuut problem
IR led or resistor or possibly IC
Dec 22, 2007 | Audio Players & Recorders
After a power outage, everything worked except the A/V Receiver did not come on unless we manually turned it on. The Help feature did not correct the problem.
Since the Harmony remote has no way of being affected by a power outage, I would say that this is more an issue with your receiver itself. There was probably a power surge, and the IR receiver may have been damaged. I would try the original remote, or call the manufacturer to see if there is any way to reset the receiver.
Jul 22, 2011 | Logitech Harmony 1000 Advanced Universal...
I need a code to to turn my tv combo vcr its RCA and so is the the universal remote
An RCA 4-device Universal Remote codes for an RCA tv/vcr combo are 1000, 1003, 1004, 1005, 1006, 1007, 1019, 1054, 1055, 1082, 1096, 1098, 1099, 1100, 1101, 1102, 1103, 1129, 1179, 1181, 1188, 1190, 1196, 1202, 1203, 1212, 1215, 1233, 1257, 1258, 1266, 1278, 1279, 1281, 1286, 1352 . These are the possible codes that RCA gives.
Mar 10, 2011 | RCA 4-Device Universal Remote
Need code for mitsubishi tv
THE codes for programming RCA Universal Remote Control to a Mitsubishi TV are 006, 011, 014, 019, 022, 027, 041, 056, 061 and 068.
But then if it will not work on these codes you can try these steps for you to be able to program your remote control without the code.
  1. Manually turn ON your TV
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the TV button you want to set up.The TV button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the TV turns off, press and release ENTER.
  7. With the TV on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 13, 2010 | RCA Universal Remote Control
I have a kenwood vr 406 and a kenwood rcr0609 remote. After some time, the remote stopped working , so we got a new remote. This worked about a day. The remote itself seems to be working, because I can...
Kenwood receivers recently have a commonly known problem with its receiving IR diode within the receiver, to fix this you will have to re-solder the connection on the receiver panel within the faceplate of your kenwood receiver.
Instructions to fix it are at the following link if you are willing to open up your receiver and repair it. lots of people have reported this fix as successful so it is widely believed to be a design flaw in the VR line-up of receivers as it has occured in all the VR families so far.
good luck.
Jan 20, 2009 | Kenwood VR-406 Receiver
IR receiver on unit not working?
Sounds to me like the issue is the rx in the unit. It can be fixed with very little work if you can locate the part. Let me take a look and see if I can locate the part number for you. Although I have to say that Kenwwod can keep a tight lip on their parts lists.
Nov 22, 2007 | Kenwood VR-309
It seems to be a general problem on Kenwood Receivers. Pls check this out http://www.moerk.org/kenwood/ or this http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/
regards sgershoj
Nov 06, 2007 | Kenwood VR-505 Receiver
179 people viewed this question
Top Mitsubishi Audio Players & Recorders Experts
Todd Arndt
Todd Arndt
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
