Question about Denon Audio Players & Recorders
Denon dp-30l ii
Automatic arm
5 Suggested Answers
  • 120 Answers
SOURCE: Denon dp-35F turntable.
It apears the lead wiring contact arrangement is typically generic. Green over Red and Blue over white. I searched Google by images and found the wiring arrangement in a detailed photograph of a Denon headpiece with cartridge installed.
So always remember to draw a diagram before disassembling something.
Posted on Apr 12, 2009
  • 189 Answers
SOURCE: I have a Denon DP 60 that lost the counterbalance
HELLO
My advice to you would be to find a DENON dealer in your locality who will make enquiries for you. If you don't have a dealer near you, look for DENON on the web.
I wish you all the best with your problem!
Posted on Nov 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: How do you adjust the
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
Posted on Apr 14, 2011
AJIN G
  • 6694 Answers
SOURCE: Which thickness setting should I use when playing
hi,
There are only two types of records available like 17 and 30. the size 30 will be as same as the turn table plater's size. 17 will be in half sized of the 30.
OK
Posted on Oct 29, 2011
Denon dp-26F when i tried to play a record the arm just skated all the way across the record. is there a way to adjust the arm so it plays correctly?
The short answer is that you need a new stylus as the one you have is either broken or worn away so that it won't stay in the groove. It could also be out of place. Rubbing your finger on the stylus you should be able to feel it digging in. If you can't it's gone!
Nov 16, 2014 | Denon DP-26F Turntable
Denon dp-29F won't turn
hit it with a hammer...............
or the other option is to switch off the unit at the wall, then switch it back on again.
Dec 06, 2013 | Denon DP-29F Turntable
In my DENON DP-300F tone arm don't come back after playing record. It just stays in the end of record? How can i fix it?
A lot of decks don't actually do that anyway. But if it previously did this then it's probably a mechanical problem. Removing the bottom of the turntable might show up the cause of the problem.
Dec 08, 2012 | Denon DP-300F Turntable
Denon DP-297 Turntable Tone Arm Skating
There should be a weight on the end of the arm, this needs to be adjusted. Some have numbers on them, increase the number shown. To get it to work right you will have to do it by trial and error. Increasing the weight in small steps, then playing a record. The trick being so it stays in the groove, but not too much so it rumbles on the sound. You will need to repeat the process several times till it sounds right and stays in the groove.
Jan 10, 2012 | Denon DP-29F Turntable
Which thickness setting should I use when playing my 33 rpm records on my Denon DP 297 fully automatic turntable? 17 or 30?
hi,
OK
Oct 22, 2011 | Denon DP-47F Turntable
I have a Denon DP 60 that lost the counterbalance ring (on the end of the Arm). I would like to purchase a replacement
HELLO
Nov 07, 2009 | Denon DP-47F Turntable
Denon dp-35F turntable. What is the tone arm lead wiring layout? The cartridge is labeled RWGB, but not the tone arm.
Apr 10, 2009 | Denon Audio Players & Recorders
Denon DP-47F
You might have a bad cue motor/ass'y. Did you buy this new, or used? Are you the original owner? Did this just start happening? Have you done anything different (moved the unit, cleaned it, etc) to the unit?
If the cue ass'y is bad, then that would require professional servicing.
- TWEAK AV LAB
Nov 25, 2007 | Denon DP-47F Turntable
94 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
