Question about Husqvarna Chain Saw Models 51, 55
Trouble starting hard to start and won't idel
    Scholar:
  • 136 Answers
You should check the carburetor to see if you don't have any vacuum leaks or gas leaks. You may have to replace the gasket under the carb. Before doing that , check to see if your choke is working right.Also check the filter and hose inside the gas tank to see if they are good. The filter unclogged and the hose not leaking.
If it is none of the above, the carb probably gave out. You may need a new one.
Posted on Dec 02, 2013
Yamaha kodiak 450
Your float adjustment is incorrect, asis your fast idle
Jul 02, 2013 | Motorcycles
97 lumina won't idel bAckfires throw moter how do I fix it
Hi Shane, I'm glad to help!
Shane, I'm not there to do a diagnosis but it sound like you may have a rocker arm that may have came off. You can pull the valve cover off the side where the noise is and see if that has happened. Not sure, but you need to start somewhere right. Hope this helps and have an awesome day Shane.
Apr 12, 2013 | Cars & Trucks
I have an '09 toyota camry and the navigation system won't work, tried to hard start the system by disconnecting the battery but it still won't work. Does anyone know how to fix this?
I think you will need to access the Nav System with a professional
scanner or scan tool & then use manufacture trouble charts, to even know what the system is supposed to do, & how to diagnose it
Hopefully a repair shop, if they want the job,otherwise blow out
your wallet at a dealer
Mar 27, 2013 | 2009 Toyota Camry
Truck will run 1/2 mile and quit
Interesting.
When it stalls and won't start, are you missing spark to the plugs or fuel to the injectors ?
Oct 02, 2012 | 1994 Chevrolet K2500
Still waiting for an answer about my Chrysler 2002 Town & country. QUESTION : Fan won't blow when car is ideling will start after I start driving again.
I would need more info to give any advice.
I assume you mean the blower for the ac and heater.
How is it not working but works on high ?
And what power are you turning off that makes it blow harder ?
Jul 12, 2012 | Cars & Trucks
97 chevrolet 6.5 turbo silverado will not start
Could be an injector pump or several other things.
Glow plug problems will make it hard to start but not run rough.
One bad injector won't make it not start.
Any trouble codes ?
May 01, 2012 | Cars & Trucks
Car won't keepidel1989 300e Car won't keep idel, starts up runs for a while but cutsoff
first ensure your spark plugs, wires, cap and rotor/coil packs are in good shape. once thats done check for a check engine light, sometimes they come on then go off but a code will be stored regardless. once you have made sure your getting good spark and there are no trouble codes the issue is most likely a dirty throttle body or fault IAC (idle air control) valve or throttle positioning sensor. hope this helps, good luck
Mar 15, 2012 | 1989 Mercedes-Benz 300-Class
Won't start unless spray fuel change fuel pump did'nt help when it starts idel rough throtle up slowly it go about 3000 rpm start trying to die if you floor it from idel it will die but spray fuel...
Then its got to be a problem with the fuel delivery. You need to check that you're getting fuel from the tank.
1) Does fuel get to the filter? If not, is there an airlock or debris in the fuel pipe
2) Does fuel get past the filter? - If not, replace the filter.
3) I'm not sure if you have a carb. or injectors, but one or more of the injectors could be blocked. If a carb., fuel inlet jet may be blocked.
4) Finally, is the air filter good and clean.
Jul 01, 2011 | 1990 Ford Bronco
Husqvarna Chain Saw Models 51, 55 Logo
74 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
