Question about Canon i475 InkJet Printer
Print head cleaning xerox phaser 6125 - Canon i475 InkJet Printer
My Xerox Phaser 6125 smears black (!) toner, extra obvious and totalley unacceptable on double sided printed sheets. Different types of paper all show the same problem.
This would normally be the cleaning unit to blame. If in doubt go,to the Xerox.com website and investigate further.
Good luck.
Sep 24, 2013 | Xerox Phaser 6125 Laser Printer
Xerox Phaser 6125 prints pink
you cal also try to clean the laserwindow of the Magenta imaging unit
Nov 08, 2012 | Xerox Phaser 6125 Laser Printer
Our phaser 6125 is making a lot of noises when it is printing. Any suggestions?
Open the front tray of the printer and check if something is broken. If there is, ask yourself if you can fix it, if not, send it to Xerox support.
Phaser 6125 does a lot of noise in all the prints. Are you sure its not the normal noise?
Aug 17, 2011 | Xerox Phaser 6125 Laser Printer
Xerox 6125 prints out grey instead of black. Changed black cartridge from an OEM copy to an original Xerox, still does it
you have the wrong drivers installed ie monochrome i have had this in the past with other printers make sure you have the colour ones
Jun 06, 2011 | Xerox Phaser 6125 Laser Printer
My black cartridge still has ample ink in it, but printer will not even print in black because it says other cartridges are low, such as magenta and cyan. can I still print documents in black without...
All you need to do is open the "properties" link, then set the print to black & white. It then doesn't matter what you have left in the other cartridges
Jan 31, 2010 | Xerox Phaser 6125 Laser Printer
How to refill xerox phaser 6125?
Just found a supplier for toner and reset chips for my new 6125. Don't know where you're based but in the UK you can use the following link:-
http://www.zinetic.co.uk/Xerox_Phaser_6125_Toner_Refill_Rainbow_Pack-details.aspx
In the US, a possible source from EBAY is:-
http://cgi.ebay.co.uk/4-Xerox-Phaser-6125-6125N-6130-6130N-Toner-Refill-HY_W0QQitemZ380126889100QQcmdZViewItemQQptZBI_Toner?hash=item588154048c&_trksid=p3286.c0.m14&_trkparms=72:1683|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
Good luck.
MJN
Apr 07, 2009 | Xerox Phaser 6125 Laser Printer
I need an Apple Mac driver for the Xerox Phaser 6125 printer
Hi there, I found a driver that will work for this printer. I currently have the Xerox Phaser 6125 as well. Its called the FujiXerox Fuji DocuPrint C525 Driver and can be found here:
http://www.fujixeroxprinters.com.au//en/support/Downloads.aspx?product=5452&category=5726&os=124&dl=108
The original thread that helped me is here: http://www.openprinting.org/show_printer.cgi?recnum=Xerox-Phaser_6125
Hope this helps, DreamGirlB
Mar 21, 2009 | Xerox Phaser 6125 Laser Printer
Xerox Phaser 6125 Color Printer
I called Xerox and it seems that it's because the imaging unit is defective. They are seeding me one free of charge. Hope you can do the same...
Sep 20, 2008 | Xerox Phaser 6125 Laser Printer
Canon i475 InkJet Printer Logo
217 people viewed this question
old marine
old marine
