Question about Plumbing
How to remove overtightened screw - Plumbing
  • 957 Answers
You can get what is called an easyout that will take out the screw
Posted on Jun 07, 2014
How to remove the spark plug and cleaning proceedure
Use the correct size plug spanner. Take off the lead and unscrew the plug. Clean it with a soft wire brush and carefully set the gap to .015 inch by carefully bending the side terminal. Screw the plug back in until it is tight. Do NOT overtighten or you will strip the plug's screw thread.
Feb 06, 2014 | 2011 Hero Honda Pleasure 100
Fitting hugger 2013 street triple
Easy - follow instructions - do not tear the brake lines, put copper grease on all bolt/screws you use, do not overtighten them. if you have to remove chain guard keep it for when you sell.
Dec 11, 2013 | Triumph Street triple Motorcycles
How do i remove the hard drive from my acer aspire 3004wlci and reinstall another i need step by step instructions please
wear an antistatic earth strap remove the power lead from the power in put on the computer
remove the side panels on on our computer you will see 4 screws 2 either side unscrew these then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten)
hope this helps
http://www.fonerbooks.com/laptop_1.htm
Sep 27, 2011 | Acer Aspire 3000 Notebook
How do you replace the third brake light on a 1997 chevy cavalier convertible?
There are two screws that hold it in, remove them (phillips head most likely)
gently remove the light (may need to use a flat head screw driver and a rag to gently pry it out)
with the light all the way out, twist out the bulb socket.
If you are just replacing the bulb, remove the old bulb, insert a new one, and repeat the steps in reverse order. DO NOT OVERTIGHTEN the screws.
Hope this helps
Sep 08, 2011 | 1997 Chevrolet Cavalier
Broken primer bulb, i cant get the cover off to replace the bulb
Look for recessed screws that hold the top cover on. Sometimes they use torx screws or allen heads, so you might need a different tool than a standard screwdriver. If the cover edge is under another part of the housing, you will need to remove that part first. Be careful to note where the screws came from, some are specific lengths. When putting them back in, don't overtighten. Unfortunately, some are just screwing into plastic, and can easily strip out the hole if overtightened. Ryobi may have exploded view diagrams of your model online.
Aug 27, 2011 | Ryobi Garden
How to change air filter on a 2002 jetta tdi
Air filter changement for 2002 VW Jetta 1.9 TDI:
1. Unplug MAF Connector.
2. Unscrew two Air Filter Housing screws - Phillips driver.
3. Screws do not come out fully. They remain loose in the Housing.
4. Remove Air Filter Housing. Lift up/towards. Rest on battery cover.
5. Remove old Air Filter.
6. Clean Filter Housing. Damp cloth.
7. Check upper half of cover too.
8. Insert new Air Filter. Ensure the edges are seated.
9. Reposition Filter Housing. Clips on leading edge down/in first.
10. Two screws (don't overtighten).
11. Reconnect MAF plug.
Aug 30, 2010 | 2002 Volkswagen Jetta TDI
Oil leak from small round cover held in place by 2 socket head cap screws on yamaha V -twin 1100 front cylinder
sounds like a tappet cover, it will have a "o" ring seal.
This is a very simple repair, purchase a new seal from yamaha, remove the two screws and replace seal, make sure everything is clean when you reassemble. you dont need to overtighten the screws to much
Jun 15, 2010 | 2005 Yamaha V Star 1100 Silverado
How to replace throttle position sensor on a 1995 pontiac grand prix gtp
Remove all parts to access the throttle-body, typically the sensor is on the side with 2 screws.  Remove the wired plug and then the two screws.  Assembly is the reverse being careful to fit the flat piece of the throttle-body into the groove of the sensor. Do not overtighten.
Replace connector and other parts.
Typically the sensor is on the drivers side of the throttle body. May be a torx screw, or phillips (star).
Good luck.
Canada Rocks!
Jun 11, 2010 | 1995 Pontiac Grand Prix
Overtightened the coolent temperature sensor and it broke.
Take the piece that broke off to any auto parts store and they will have an extractor that will remove the other piece. good luck.
Feb 01, 2009 | 1997 Honda Civic
Drain screw
He, if the repair was done within their warranty period, try calling their service department. It should be covered...beyond that, I would say that someone either overtightened or cross threaded the drain screw. You might warm up (but not fully presurize) and see if you can loosen it 1/4 turn counter clockwise (no further) and let it cool before removing.
Aug 05, 2008 | Rowenta DG-980 Iron
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
