We have desktop and a laptop the laptop was down for a bit well we have it fix but now we can't use are wireless internet because we have forgot the password we have try 192.168.1.1 and 192.168.1.2 and192.168.1.10
    Scholar:
  • 80 Answers
Goto the website of the manufacturer of the router and there will be a trouble shooter on there. It sounds daft but most have a default password which are the same as everyone elses!!
Posted on Oct 25, 2008
Need the intel basic download and tip on conecting to the internet 7/64 bit
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. There should be an option to "automatically connect" when it detects the network. Look for a checkbox. create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options in the connections tab tick in the box never dial a connection below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them Power on the laptop computer and wait for the operating system to boot before proceeding. Right-click the wireless icon in the lower right corner of the desktop. From the pop-up menu select "Enable." This activates the wireless Internet options but it does not turn on the wireless receiver. Push down on the wireless button or wireless switch on the top of the keyboard. After a moments time the switch or button lights up, signifying the computer is ready for an Internet connection. Right-click the wireless icon again. From the pull-up menu choose to view all available wireless networks in the area. A window appears with all the networks your computer receives some sort of signal from. Select the wireless network you want access to, type in the password (if required) and click "Connect." Momentarily the laptop computer connects to the Internet.
you should be able to, it depends on the laptop, the os, the wireless adapter, and the settings .
Click start Control Panel - Network Connections - right click on 'Wireless connection' (or similar) and click 'enable'. right click on the network in the bottom toolbar select open network sharing center you should have the options to either connect or disconnect or set up a network connection this will vary depending on your operating system
Feb 09, 2013 | Lenovo B570 15.6 inch Laptop - Black Intel...
I can't go to my internet. It is bothering me with username &password what I forgot
I'm a bit confused, When you open Internet Explorer, What ask you for a username and password? OR , Is it the Laptop , at boot that's asking for a username and password? Or , wireless?
Jan 08, 2013 | Acer Computers & Internet
Hello My WNA3100 Wireless adapter keeps dropping my connection about every 4-10 minutes and the solution is to unplug the adapter and plug it back in. This has become more than a slight annoyance and
desktop or laptop computer ?
try moving your computer to a different area to gain maximum frequency / range
Click start control panel network and internet look for wireless
"Allow the wireless LAN radio to be turned off when inactive" might be ticked untick it
click start Control Panel - Network Connections - right click on 'Wireless connection'
if this fails to fix the problem
try unplugging the usb wireless device
uninstall the netgear software in the add/remove programs in the control panel reboot and then reinstall the software then plug in the usb wireless adapter
hope this helps
Oct 04, 2012 | NetGear WirelessN 300 USB Adapter WNA3100
Looking to connect awireless laptop printer and need the WEP or WPA key for the wireless network
WEP or WPA Key is the password for your wireless network.. it's the same password you used to connect your laptop to the wireless.. if yo forgot what it is, you might need to contact the manufacturer of the router or your internet service provider to reconfigure or re-setup your wireless network.. hope this helps a bit.
Sep 08, 2010 | Office Equipment & Supplies
I have a desktop and a laptop (new for xmas) and I want to set up the laptop to the wireless-N Router Model WRT160N. I am set up with internet through a bundle system through our television. Do I plug the...
first a couple of things.
if your router has wireless support your laptop (if new) should have a wireless adapter built in, so basically your destop computer can be wirely plugged into the router and your laptop shoud "connect wirelessly" to your adapter
so this is how your set up should look like
desktop
--cable-- = - cablemodem - = linksys router = ----- wire----- desktop
laptop
--cable-- = - cablemodem - = linksys router = ))wireless))) laptop
you need read up a bit, here are some links that will have info you need
manual for wireless configuration (select the proper revision for your router and check user manual)
configure wireless network for vista
read up and if you have any questions post back.
hope that helps.
Dec 26, 2009 | Computers & Internet
NETGEAR Wireless G USB Adaptor Problems
I contacted Bigpond after my whole internet collapsed due to my amature abilities in fixing the internet. >_<" yet they fixed my internet connection by disconnecting my current (DLINK DIR-300) router from the network. hmmmm... the technician also confirmed that my current broadband modem (2WIRE 2071-A) isnt capable of supplying a shared connection to more than one computer!! she also directed me towards a modem with an inbuilt wifi router that "supposedly" is the best option right now. (2701HGV-W) I'm a bit shaky and the stupid NETGEAR adaptor problem still exists - im willing to buy the new modem if its guaranteed to abolish this problem and give me a better internet wise outlook - please any suggestions will be appreiciated =)
Apr 23, 2009 | NetGear Wireless-G USB Adapter...
Do Desktops pick up internet connection like laptops do? Im planning on purchasing a desktop pc however im not sure if i can pick up internet like my current laptop does, U see i just moved in and dont...
Hi there.
You hit the nail right on the head!! desktops don't come wireless enabled so you will need a wireless card installed into it.
I recommend a wireless PCI card as a Dongle are not that good and can be easily broken.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | HP Computers & Internet
Our internet went down
look on the back of your wireless router there should be a little pin hole under it says reset push the button inside that pinhole and hold it for about 30 secs remove it and let the router do its thing it will start back up and you will have to reset all your settings on the router but this should fix your problem
Mar 27, 2009 | Toshiba Satellite A100-S8111TD Notebook
I just got my first notebook it is a compaq evo n400c with a belkin 802.11b (32 bit cardbus)wi-fi card. i am trying to find out how i can get/have internet access where ever i go. how do i go about setting...
Hi Obadiah,
U can take ur laptop to any of the hotspots and u need to turn on the wireless switch in ur laptop so that u can automatically connect to the wireless internet..i think u r aware about hotspots...
If u want to use internet in ur home..u can buy a wireless router..there are lot of companies providing wireless routers..u can buy Linksys..model no is Wrt54g..this wrt54g is a wireless router where u can connect 4 wired desktops and 20 wireless laptops..its cheaper and best.u need to buy a internet connection to connect this router...I suggest u to go for a cable Internet..Cable internet providers are comcast,shah.go for comcast.Hope this info will be useful for u.for further clarifications revert back as soon as possible
Jul 09, 2008 | Belkin Computers & Internet
Computers & Internet Logo
27 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
