Question about Toshiba Satellite P25-S507 Notebook
Toshiba Satellite blank screen
Internal monitor screen is blank.It was left on overnight, in the morning wouldn't come on.The hardware power management software (Toshiba's) is set to turn off the monitor after 30 minutes of inactivity.On top of that the OS's screen saver is set to blank after 60 minutes.When the touchpad/keys was tapped the monitor turned on but stayed blank as if the blank screen saver was on - a faint glow of the blank screen (visible in darkness) was the indicator.After the laptop was turned off and on , the same faint glowing blank screen comes on, nothing else , not even BIOS booting info.No visible output whatsoever.A DVD inserted played normal except no visible output - screen blank, sound played only.I got a tip that the computer is stuck in a twilight-like state between hybernation and some other state and to remove the battery for a complete power-off cycle - did that and it didn't help.I suspect either a hardware failure or hopefully just software.No external monitor is available for further testing.OS: XP Home Edition service pack 2.Laptop: Toshiba Satellite P25-s507 ( PSP20U-OOVY3V)
  • bum0max Nov 10, 2008
    UPDATE: external monitor works, so it's not the video card.Based on my research of similar problems
    posted on the net it's the inverter.The internal monitor flickers faint glow on and off when the monitor's 'close' miniature button is pushed .Please advice somebody, it's been many days and not one answer :(.
  • frenchbass Dec 18, 2008
    Same as above, except my screen stayed blank after switching from
    external s-video. Switching still works. PLEASE PLEASE help!
  • 70 Answers
Its a inverter circuit fault.
Posted on Aug 23, 2009
Toshiba satellite L355D screen is black
Try to remove the memory and clean..
place it back.
if not refix all the connections. or try change the monitor maybe monitor is dead.
Dec 21, 2012 | Toshiba Satellite L355D-S7815 Notebook
Blank Screen
The bad thing about this is that it could be a software related issue or a hardware issue. If you're willing, you can disassemble the unit and check for a damaged or loose connector to the monitor. If there doesn't appear to be any issues there it may well be that the screen has gone bad or there is something wrong with the driver/setting on the unit itself that is causing the screen to saty off. I'd move forward with the hardware issue first though.
Jun 09, 2007 | Toshiba Satellite R15-829 Tablet PC
Monitor will not power on
The monitor has entered permanent sleep mode. After four years of service, it probably is not worth repairing
Oct 21, 2012 | HP W2408H 24-inch Widescreen LCD Monitor
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Feb 27, 2009 | Toshiba Satellite L25-S119 Notebook
Auxiliary monitor
sure..that can be connected, and then accessed with Fn(bottom left near space bar) and usually F7 even though it may be different on yours..look for the one that shows a monitor in blue..that should do it..
Oct 16, 2008 | Toshiba Satellite A205-S4617 Notebook
Black Screen
hi, try boot to safe mode, check the display properties, settings and the refrsh rate. if not solved, reinstall the graphics controller driver..
thanks
Aug 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Monitor
there are internal wires that need to be serviced by a licensed technician .....
Jul 13, 2008 | Toshiba Satellite A215-S7462 Laptop
Toshiba satellite p25-s509
I think this is already a hardware problem, it could be your LCD or your systemboard, try connecting an external LCD or monitor thru the VGA -out & check if you have a display. If not, it might be your systemboard that's causing the problem & this may require service.
Hope this helps.
Jul 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite monitor problems
Sounds like the memory module is bad. Return it or get a warranty replacement.
Aug 14, 2007 | Toshiba Satellite Satellite 5200 Series 15...
Toshiba Satellite P25-S507 Notebook Logo
1,790 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
