Question about Nakajima AE-740 Typewriter
How do I reset my Left Margin, It is stuck
I've downloaded your manual, and I'm pressing on the Margin Release button and using the backspace button, but it just beeps. I cannot get my left margin beyond the center. Help? How do I reset this?
  • Nakajima Master
  • 3,594 Answers
PRESS BUT DON'T HOLD the MAR REL key.
DickyO
Posted on Mar 12, 2012
  • 3594 Answers
SOURCE: return sticks
Try putting a few drops of light oil on the shaft that the carrier rides on and the pulleys that the cables are on (WD40 works well) also look for debris under the carrier.
Merry Christmas
DickyO
Posted on Dec 28, 2007
  • 3594 Answers
SOURCE: CAN'T GET THE MARGINS TO RELEASE
Return to L. mar. touch and release margin rel. key backspace to desired location press l. mar key
DickyO
Posted on Mar 27, 2008
  • 329 Answers
SOURCE: Margin Release
Try holding down on the MR (margin release) key and turn on. Machine will print a few lines with all the letters. Turn off and then on and try. Also make sure someone has not switched the key tops for left marging and right margin, I have seen this "joke" played on people. Can you set either margins?
Posted on Aug 13, 2008
  • 3594 Answers
SOURCE: I have the left margin stuck in the middle of the
I'll try, return to the margin, touch and release the mar. rel key, backspace to the place you would like the L. margin, press the L. margin key.
DickyO
Posted on Oct 14, 2009
  • 3594 Answers
SOURCE: Cannot release the margins or tabs
Go to the margin, touch and release the mar rel key, space or backspace to desired location, press the margin key you are moving, done.
DickyO
Posted on May 15, 2010
How do you reset the margin on SC-XE6000 when right margin is stuck mid-page width?
Press and hold margin release key while sliding carriage to the left using the carriage release on the end of the carriage, behind the platen (roller) knob, there is one at each end. Put the carriage where you want it and press margin set to reset margin position.
Nov 20, 2014 | Office Equipment & Supplies
My Nakajima AE-710 margin release does not work. How can I reset to factory settings?
When using the margin release DON'T HOLD IT DOWN just press and release. if this dosen/t work turn off the machine and see if the carrier will move both ways relatively freely if not look fot debris and spray a little WD40 on the silver shaft that it slides on.
DickyO
May 08, 2012 | Nakajima AE-710 Typewriter
How do I release the right margin on the typewriter?
Look above the 3 key, you will see M REL that stands for Margin RELease. Move to the margin you want to change and wail holding the ALT key and press 3. Repossition the print head by using the BACKSPACE or SPACE BAR then again hold ALT as you select the new Left Margin or Right Margin (4=L MAR or 5=R MAR)
Nov 10, 2011 | Brother ML-300 Typewriter
Occasionally, I still have to use a typewriter for some forms. I inherited a Xerox 6015 Memorywriter but I have no manual. Is there one online that I can download? Specifically, I'm trying to figure...
hit the carriage return key to put carriage at left margin. then hit your margin release key, then backspace key to put your carriage where you want it. then hit left margin key and that should set new left margin. good luck.
razors
Jun 06, 2011 | Office Equipment & Supplies
The return is stuck on 80 on the guide. I cannot
Turn the T/W off and slide the carrier back and forth. If it goes to the left then you have the L. margin set at 80.
Return to the margin, press and release the margin release key, backspace to the desired location, press the L. margin key.
DickyO
Mar 18, 2010 | Nakajima AE-710 Typewriter
Changing margins
To change or reset margins, the keys involved are the ALT key to the left of the spacebar, the #keys 3,4, & 5.
The ALT & '3' keys are used to bypass the set margins.
To bypass the left margin, move the carrier to the left margin. Press the ALT & '3' keys at the same time. Release them then backspace the carrier to the point the new margin is wanted. Press the ALT and '4' keys at the same time to set the new left margin.
To bypass the right margin, move the carrier to the right margin. Press the ALT & '3' keys at the same time. Release them and spacebar to the point where the new right margin is wanted. Press the ALT & '5' keys to set the new right margin.
The main thing to remember is to move the carrier to the point where the new margin is needed. ALT + 3 bypasses old margins, ALT + 4 sets the left margin, & ALT + 5 sets the right margin.
Feb 24, 2010 | Brother SX-4000 Typewriter
I am using an AE-830 and have the left margin stuck in the middle of the page. How do I release and set back to the left? Thanks
Move the printer to the margin using return button. Press the margin release button, backspace to where you want the margin to be, then press the left margin set. All should be good.
Oct 13, 2009 | Nakajima AE-830 Typewriter
How to set margins on Olympia compact s - is there a manual available?
use the "margin left" key to set left margin, and the "Margin Right" key to set the right margin. Move to where you want the margin to be and press the right or left margin keys. to go beyond a margin (to set margins "outside" the current settings, press the MAR REL (Margin Release) button while at the current margin
Oct 02, 2009 | Olympia Office Equipment & Supplies
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
Sep 05, 2009 | Office Equipment & Supplies
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
Nakajima AE-740 Typewriter Logo
127 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
