Question about Vacuums
Dyson DC 25 power switch replacement - Vacuums
  • 3 Answers
It a fairly straightforward procedure. Remove the accessory hose to expose 4 torx screws from behind that hold the front switch cover in place. After removing the screws, gently pull the front switch cover and carefully pry two plastic tabs apart using a small screwdriver that "snap" cover in place. The switches will be exposed. The electrical connectors each have a tiny lock button at the base of the terminal that you need to push to remove. Otherwise they won't pull off easily. Assembly is reverse with one note: You'll have to hold the plastic cover and push buttons together so they don't fall out as you place the the cover back on. Once you get it on, the plastic tabs will hold until you install the torx screws. Be sure to retest the push buttons to make sure there was no binding in reassembly.
If I may add one more thing- I believe all DC25's carry a 5 year warranty and switch failure is covered. I replace these routinely. If you call Dyson, they will likely refer you to an authorized repair center for replacement at no charge.
Regards
Posted on Feb 17, 2012
  • goetzsun123 Jan 13, 2013
    I have the 4 screws but I cannot get the cover playe ogg I have the dyson slim 322-us-a 23518
  • Steve Rulison Jul 23, 2014
    I found that I can pull the switch out by prying it out with a flathead screwdriver. Turns out the only thing holding it in is a clip.
Dysonteam
  • 167 Answers
SOURCE: the brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 22, 2010
  • 389 Answers
SOURCE: Reset Button on my Dyson DC 25 Animal
What do you want to reset? Do you mean the motor has stopped working? There is no "reset button". The motor has an automatic cut-out, which will operate if the motor gets too hot and will reset itself when it cools. If the motor will not work when it's cool, then you have an electrical problem which will probably need professional attention.
Posted on Apr 09, 2009
ThinkVacuums
  • 144 Answers
SOURCE: I have a Dc-25 Dyson ball,The beater bar does not
check to see if the belt is broken or loose and have a technician look at the clutch to see if its burnt out.
Posted on Oct 23, 2009
Testimonial: "it was somethimg simple, the wheels were'nt releasing. thank you. Bruce"
SOURCE: Dyson DC 25 Ball - no power to motor
Same problem here. We noticed a loss of suction for about 5 minutes and the suction stopped. Beater bar still rotates but ZERO suction.
Posted on Apr 18, 2010
  • 101 Answers
SOURCE: Dyson DC25 rotating brush doesnt work
There is a reset button on the side of the brush bar head. Press it.
Posted on Dec 20, 2010
Dyson 25 canister release spring
It should be placed behind the catch (button). If the button retainers are not broken off, just place it under the catch and snap it back into place.
Dyson Helpline:
1-866-MY-DYSON
or
questions@dyson.com
Jun 13, 2016 | Dyson Dc 25 Animal
My dyson dc 25 sparks near the rotator roller attachment, what can I do?
Hi Cindy, it's Jack at Dyson.
If you can see sparking coming from inside the cleaner head, please do not continue to use your machine until we can help resolve this. It's likely the cleaner head will need to be replaced - once we've taken a few further details, we'll be able to confirm if this is covered under your Dyson parts and labour guarantee.
At your earliest convenience, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) for further assistance.
Dec 16, 2014 | Dyson Dc 25 Animal Upright Bagless Vacuum...
My dyson dc 25 turn on but can't stay on unless you hold the red button on?
If it use to click on and off, but does not anymore replace the switch.
Aug 31, 2014 | Dyson Vacuums
Dyson 25
www.dyson.com/support.aspx
Jul 08, 2014 | Dyson Dc 25 Animal
I have to hold down the power switch for my dyson (DC 25 all floors) to work.
hi.
it sounds like the catch on the switch is stuck or broken.
it may be worth spraying it with an electrical switch cleaner to see if that helps.
if not, you will have to replace the switch as they are not repairable.
switches can usually be bought from electrical repair shops .
the switch and wires are basic enough, but unclipping the plastic around the switch can be tricky, and usually involve at least one hidden screw on a dyson, so you may want to consider getting an experienced repair engineer to do the job, to avoid damaging the plastics.
May 04, 2011 | Dyson DC25 All Floors Bagless Upright...
Mar 14, 2010 | Dyson DC25 All Floors Bagless Upright...
The brush bar wont spin on my dyson dc 25... i
Kind regards
Darran
Jan 08, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
Vacuums Logo
457 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
