Hooking a Linksys wireless router and SpeedStream router together
I have a Linksys wireless router and am using shared printer privileges with one of my desktop computers. I just acquired a SpeedStream router (not wireless) with a parallel printer port built in. I would like to hook this in to my wireless router so that other computers on my network can use its printer function. I may also later want to use the router to add other computers to the network. Do I just hook the new router unto a lan position, or does it need to go in the modem WAN?
  • 1,269 Answers
Connection should be from LAN port of Speedstream going to Internet port of Linksys router. That should be it.
Posted on Oct 27, 2008
How do I configure for wireless?
Siemens Speedstream 4100 is just a modem, if you want to connect to the internet wireless you will need to set up your speedstream modem with a wireless router.
It can work with almost all the wireless routers available in the market, but I would recommend a Linksys wireless router.
Dec 31, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Can i hook my printer to this router Linksys wireless-g 2.4ghz
You want to connect a printer to the network.
If you have Ethernet port on the printer then you can connect it to the router with the ethernet cable. IF it is wireless printer then you will need to connect to the wireless network on the printer. In both the cases you will need to set up your printer as a network printer. If you contact the manufacturer of the printer they will tell you how to do it.
If you do not have ethernet port on the printer and it has only USB port and it is not a wireless printer then you will need a print server. You can purchase a wireless print server and you can set it up so that all the computers will be able to print onthe same printer.
If you have only the USB port and you don't want to use print server, then you can connect your printer to one of your computer. Enable File and printer sharing on all the computer. If you go to and search for file and printer sharing, you will get steps to enable file and printer sharing.
If you want to check the wireless settings of the router, you will need to open the set up page of the router .
Click here for more information about router and networks
Mar 21, 2010 | Linksys Wireless-G WRT54G Router
I have a WRT54GS router,also have A Wireless G Adapter, can i use
If you have the printer connected locally to a computer on your network, you can share it out and then connect to the printer share name via the network. Your other computers must be connected to your computers via wireless or wire.
Dec 27, 2009 | Linksys Wireless-G WRT54G Router
turn on the wireless option in the router...
plug your computer into the router type in
username: admin
Password: public
go to wireless tab
turn it on
Also you have to be in range!
Sep 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Home Network sharing issues using 2wire wireless modem
Did you manually assign the IP address to your shared devices? If so, the Linksys and the 2wire have different IP schemes.
2wire Gateway IP address:
Do an ipconfig /all on your computer and compare it to the ip scheme on your devices.
Feb 07, 2009 | 2wire 2700HG-B Router (2700HGB)
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Router connections
Is your speedstream router also your high speed modem? If so, you will have to go into the settings on the Linksys and change its IP Address subnet from to (or you can use a different number than 2) You will then need to reboot both routers (and possibly the computers) and try again. The easiest way to get into the Linksys settings is to connect it directly to the laptop via network cable, then type in in the web browser. No user name and admin is default password. (Make sure you change that, and the name of the wireless, and the security settings)
Good Luck!
Dec 08, 2008 | Computers & Internet
Static routing "Advanced Routing" on Linksys WRT55AG
Any reason why they're not both on the same subnet?
Jun 15, 2008 | Linksys WRT55AG Router
What are the step for setting up you computers to a network using a Linksys router. I have a 2 PC's and a laptop that I would linke to net work together. My first computer is connect to the Wireless-B...
Hi Ed, if your using windows you can open network connections & run network setup wizard. Follow the instruction for a home network for the wireless PC's & notebooks. Once the network is setup for all PC's than you can install the printer cd software in the PC's that you want to access the printer. Each PC & notebook will have access to the printer through the network.
The PC that that is connected to the printer needs to be shared.
Open printers and Faxes. Right click once on the printer & left click sharing. Agai follow the instructions.
Lastly,I strongly suggest you setup security for your wireless. If you do not anyone close can tap into your network connection. Follow linksys instruction to setup security. If you run into a problem you can call linksys for free advise from a pro. Their number is listed in the manual.
Good Luck! Take your time.
Have more questions, feel free to ask.
Apr 04, 2008 | Computers & Internet
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
266 people viewed this question
David Payne
David Payne
