Question about GE Refrigerators
I have a GE profile Fridg PSS26NSTASS where is the defrost timer located
Apparently the defrost themostat is in the rear of the freezer section behind the panel where is the defrost timer located or is it on the mother board
  • Joe McGoran Feb 17, 2012
    Thanks for the help That's what I kind of figured the timer being built into the mother board I took the defrost thermostat out and checked with a ohm meter and it's open when cold below 32 degree's so theres the prblem the heater won't come on
  • John Tripp
    John Tripp Feb 18, 2012
    Great Thanks for the Rate! Yes I really never had any problems related to the timing of the defrost cycle on your model. Mostly the defrost heater and then sometimes a defrost thermostat. You can manually force defrost by turning the temperature up warm on controls and carefully jump J11 with J9 on the motherboard located here=>http://appliancepartsseabreeze.com/GE_Ar...
    And clamping a amp probe around jumper to see the amp draw. And with most of the defrost heaters you can just about see when a defrost heater is burned out because the glass around heater is smoked over. Take care and again Thanks, JT
  • GE Master
  • 4,654 Answers
The PSS26NSTASS does not have a defrost timer. The defrost on that model is controlled by the motherboard=> WR55X10942 Board Assembly Main Control On your model if not defrosting it will most likely be caused by the=> WR51X10055 Defrost Heater It also does not hurt to replace the=> WR50X10068 Defrost Thermostat
while inside freezer changing out the defrost heater. Click here=> PSS26NSTASS Freezer Components
In that photo location 230 is your defrost heater and location 240 is your defrost thermostat. Here is a=> PSS26 Service Manual if you don't already have Adobe Acrobat Reader Click HERE I will be here should you have any questions, Thanks Sea Breeze
Posted on Feb 17, 2012
  • John Tripp
    John Tripp Mar 13, 2012
    Thank You for the Rate! John Tripp
  • 183 Answers
SOURCE: Freezer won't stay defrosted
defrost heater is behind the freezer rear panel along with the defrost sensor,check doors are sealing correctly, usual fault on this unit isdefrost sensor
Posted on Sep 02, 2007
docjohn174
  • 943 Answers
SOURCE: On a standard frost-free fridge's
hi thanks for the question did you remove the funnel shaped piece cause thats where it builds up remove thst piece an clean thanks the appliance doc
Posted on Sep 18, 2008
woodchuck789
  • 4070 Answers
SOURCE: Side by side freezer and fridg. Freezer ices up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Dec 08, 2009
dmftrucker
  • 1922 Answers
SOURCE: freezer side ok, refrigerator side not
check to make sure the damper door in between the freezer and refrigerator section is opening fully as you turn the cold control knob colder,some freeze up due to ice formation if so remove it and clean up ice on damper so it can open fully
Posted on Dec 24, 2009
woodchuck789
  • 4070 Answers
SOURCE: bottom freezer section iced up solid.-- Fan inside
DEFROST PROBLEM
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Posted on Feb 19, 2010
12-14 yr old ge bottom freezer. freezer is working, fridge is warm.
not all refrigerators are the same can you look inside the fresh food section around the door or on the back of the refrigerator and provide a model number?
Appliance 911 Sea Breeze
Sep 30, 2015 | GE Refrigerators
FRT211NLHWO FREEZER 22 DEG FRIDG 50 DEG
Lets begin by placing defrost timer into forced defrost. The defrost timer is inside the fresh food compartment and behind the control panel above the top shelf. Click Here=> 215846602 Defrost Timer
sea_breeze_274.jpg Try turning the timer clockwise slowly until you hear compressor and fans stop. Allow to remain here for 30 minutes. The timer if good should come out of defrost itself but if not it is a clear indication that the timer be replaced. You also should hear a crackling or sizzle coming from the freezer with door open. Also water should drain down to a condenstate tray below refrigerator into a tray that compressor fan warms to return back into air inside your home. If not timer causing the ice blocking airflow then we have the defrost heater and defrost thermostat to examine. They are located behind the rear panel inside freezer The=> 5317842502 Defrost Heater
And also the Defrost Thermostat=> 216872200 Defrost Thermostat
sea_breeze_276.jpg Testing the defrost heater can be found here=> 5317842502 defrost Heater Testing
I have laid these parts out as the timer being the most likely reason for warm temps in fresh food and freezer. If you have any questions I will be here to answer them for you, If helpful please rate, Thank You, Sea Breeze
Oct 30, 2011 | Refrigerators
Refrigerator not cold
Your problem could be a defrost component issue (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
Apr 13, 2010 | GE Profile PSW26P Stainless Steel Side by...
Alarm sounding every 6 hours or so - fridge not cooling - just located ice in the rear of the hole in thr freezer section
defrost system quit. heater, thermostat,or timer is bad check heater and thermostat for continuity if good replace timer make sure to test themostat while it's cold
Dec 27, 2009 | Fisher Refrigerators
I have a Kirkland Whirlpool fridg # ST14CKXK000 will not cool
Good day, here's a list.
1. The fan motor behind the rear panel in the freezer compartment not running. Replace.
2. Auto defrost system failed. This causes blockage of the airflow to both compartments. Usually can be identified by frost building up on the rear panel of the freezer section.
2A. the defrost system is made up of 3 parts.
First, the main defrost heater located in the freezer section, behind the rear panel.
Second, the defrost thermostat, a small round disk located in the same area as the main heater.
Third, the defrost timer, located on the roof of the fresh food compartment.
3. Failure of the sealed system, including loss of refrigerant, restriction preventing refrigerant from flowing thru the coils properly. The sealed system has a factory warranty of 5 years.
The ability and background to use a VOM meter are necessary to perform tests on 1, 2, 2A.
Need a qualified tech to perform tests on 3.
Nov 09, 2009 | Refrigerators
Ge fridg and freezer not cold; just cool; TFX 20JR; what could the problem be?
The problem is probably the defrost heater . This model is at least 12 yrs. in age . Pt # WR51X442 is the part number for the heater and harness kit . These parts are located behind the inside rear lower freezer panel . First , make sure the freezer fan is working . If not Pt # WR60X10008 is the freezer fan motor .
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator freezer is heavily frosting I cleaned it out and it is still frosting. What should I do?
Sir,
If the freezer fan is running (when the compressor is running), read on, otherwise replace the freezer fan. The defrost system has failed. There are three components, and I recommend replacing all three. These include a defrost timer (usually located somewhere in the food compartment, on the rear of the fridge, or behind the kickplate), and a defrost heater and defrost bi-metal (both located in the freezer section where the coils are. I recommend you unplug the unit overnight to allow the ice to melt before doing this repair.
You have a defrost problem which is common to all frost free refrigerators. To get you through until a diagnosis can be made, remove all the food from your freezer section and then the rear evaporator panel. With a hair dryer, remove all the frost you see behind the panel. Put it back together and your unit will work again for about 5 days until it start building up with frost again.
Thanks
Good luck
Aug 17, 2009 | GE Refrigerators
Fridge is warm and freezer is cooler than normal
Possible bad defrost timer. Locate timer underneath the fridge and manually turn the knob. Element should come on and start defrosting. If defrosting starts then the timer is bad. Check also the element and thermostat.
Jul 05, 2009 | GE Profile 21.6 cu. ft. Top Freezer...
GE side by side (purchased 2005; don't know exact model)
Defrost timer issue is my guess. It is generally located behind the rear inside panel in the fridge section. I'm guessing about $150-200 or so to fix it.
Jul 24, 2008 | GE Profile PFS22 33" Artica French Door...
Sep 02, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
649 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
