Question about Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker
Crate flexwave 15r music volume
How to turn the volume down on the output as in music from a cd player?
2 Suggested Answers
tim_lammers
SOURCE: crate flexwave 120 tuner and
Hi there,I have the same problem with my flexwave 120. I opened the amp to measure several capacitors on the small effect circuit board. If one of this capaciters have internal short circuit, wich will effect the others causing effects to fail. I removed them one by one to find possible short circuit. All capacitors were ok. I think the problem is in the processor wich is to diffucult to replace. I think it's easier to replace the effects circuit board. But where do we find this board??10_29_2011_6_25_35_am.jpg
Posted on Oct 29, 2011
Flexwave 120H Speaker wire shorted amp won't work
Solid state amps are very subject to blowing out the output transistors if speaker leads get shorted. Take it in for repair.
Aug 31, 2011 | Crate FlexWave FW120H Guitar Amp Head with...
CRATE GX- 212 HUMS WHEN TURNED ON AND CHIRPS WHEN SHUT OFF. NEED SCHEMATIC AND ADVICE TO ISOLATE THE BAD CAP IN WHICH CIRCUIT THAT IT IS OSCILLATING.
Witth an oscilloscope analyze the ripple voltage across C67, C70, C14, and C12. Pay close attention to the last two of these which are on +/- 15 volt lines.
The "chirp" when shutting down is LIKELY normal and would probably be from teh DSP effects unit as it goes down. The voltages go out of the operating range and the device essentially goes nuts for a second or so.
Sep 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Volume fading in and out
If you play this loud the amplifier MAY be going into a thermal pprotection area. It would be about as loud as a typical boombox when at safe levels.
If you need louder than that, you need a bigger unit.
If the volume always is strong after letting it rest and cool and then fades as you drive it hard, this is the probable cause.
Aug 16, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate GTX-30 Guitar Amp Schematic... The thing blew, and I need to replace two components...
Hi. use this link to check for the schematics.
crateamps.com/support/discontinued.php
or
music-electronics-forum.com/sitemap/f-60.html.
take care.
May 31, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate Flexwave 120h (Half Stack) volume issues
Perhaps you have a bad capacitor on your volume control?
You can get an ESR meter and test your exposed isolation caps for leakage? The have to be removed so unplug the unit if you are gonna do any work inside the cabinet.
Also, try a shorter or higher quality guitar cable. This will cut impedance between the pickups and the amp.
Good luck and be careful!
Mar 08, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
I have a Crate GT 15, not getting anything to the speaker when I plug in.
Do you have electronics experience? Inspect the amp for broken or cold solder joints and any burned components. Check to see if the fuse blew and that the output IC's or transistors (not sure what Crate used in these) are not bad. Check your speaker wire as well.
Jan 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Buzzes and feedback
Make sure the "ground lift" option is used on the direct box.
DO NOT UNDER ANY CIRCUMSTANCES use a headphone output jack as the output of this unit. The headphone jack is for HEADPHONES that have no return to ground. Use of this as drive to a sound board is sure to cause problems and in some cases can fry these amps due to the circuitry.
The cable used to go to the direct box should be very short and high quality.
You should source the power for this unit from the SAME source and receptacle as your sound board if at all possible.
Nov 08, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, techmail@loudtechinc.com.
They hooked me up with parts and schematic for my Crate G212XL.
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Loss of power while playing
If you can solder, try resoldering any connections on the board that appear grainy or have rings. It is likely that after the unit has been working for a while, the heat is causing a marginal connection to open up.
Keep us posted.
Dan
Feb 16, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate FlexWave FW15 Guitar Amp Combo, 15 Watt Single 8 Speaker Logo
55 people viewed this question
Top Crate Music Experts
rjivaro
Ben Armstrong
richie46
Are you a Crate Music Expert? Answer questions, earn points and help others
